Douglas HiFi
SOLD: LUXMAN M700u Power Amplifier
Item: LUXMAN M700u Power Amplifier
Price:
$6590 - ($10 999 srp)
Item Condition: Perfect Condition... Trade-in incl. Original Boxes etc
Reason for selling: Trade-in item
Payment Method: Visa, Mastercard, Direct Deposit
The Luxman Ultimate range is some of the best sounding, beautifully made products on the market.
Here we have a M700-u Power Amplifier in Immaculate condition - it was recently traded in (all original receipts, boxes etc) and this means someone out there can grab a fantastic high end Japanese power amp for a great price.
The Luxman M700u delivers an exquisite combination of rich sonic expression, fine detail, wide bandwidth and dynamic gusto. The stereo output is rated at 120W per channel into eight ohms and 210W per channel into four ohms.  It can achieve up to 840W per channel into one ohm instantaneously. Furthermore, there is also a user-selectable mono mode with a rated output of 420W into eight ohms.
Luxman M700u Features
  • An EI type transformer rated at 550VA supply plentiful regulation ensuring an unshakable response to any load fluctuations.
  • A high-capacity block capacitor delivers lashings of power instantaneously.
  • The Luxman M700u’s low-impedance transmission delivers maximum sonic purity.
  • Single-ended RCA and balanced XLR inputs
  • Heavy-duty speaker binding postsS
  • Switches for stereo/mono modes and phase inversion
  • A remote input terminal for custom installations.
SPECIFICATIONS
  • Continuous rated output (stereo) 120 W + 120 W (8 Ohm)
  • 210 W + 210 W (4 Ohm)
  • Continuous rated output (BTL) 420 W (8 Ohm)
  • Instantaneous maximum output (stereo) 840 W + 840 W (1 Ohm)
  • Instantaneous maximum output (BTL) 1680 W (2 Ohm)
  • Input sensitivity 1.1 V/120 W, load 8 Ohm, Gain 29.0 dB
  • Input impedance LINE 51 kOhm, BAL LINE 34 kOhm
  • Total harmonic distortion 0.009 % or less/1kHz · 120 W, load 8 Ohm, 0.1 % or less/20Hz-20 kHz
  • Frequency response +0, ?0.1dB/20Hz-20kHz, +0, ?3.0dB/1Hz-130kHz
  • S/N ratio 115 dB (IHF-A weighted, input short)
  • Damping factor 350
  • Power consumption 370 W, 110 W (under no signal), 0.4 W (at standby)
  • Power supply 230 V ~ (50 Hz)
  • Max. external dimensions 440 (W) × 190 (H) × 427 (D)mm
  • Weight 27.5 kg
Edited by Douglas HiFi
Updating power spec
OMG.
If only.:sad:
Lotto!
Here I come!
On 23/07/2019 at 5:53 PM, Douglas HiFi said:
Continuous rated output (BTL) 840 W + 840 W (1 Ohm)
Is that correct, coming from a 550VA transformer?
Thanks, so it's wrong above? Should be "Instantaneous max. output", not continuous?
Lovely amplifier.
Edited by BioBrian
Lovely amplifier.
Hi Brian,
indeed a lovely amp.
I have changed specs to Instantaneous... as you are absolutely correct regarding current listed specifications :)
However - those specs I had previously up were copy and pasted from the an earlier blurb from Luxman talking about power in BTL mode.... which they currently spec as:
INSTANTANEOUS MAXIMUM OUTPUT (BTL 1680W into 2 ohms)
-( This seems like an odd spec off a 550va Transformer I agree )
cheers,
Simon Pressman
    • By Class A Audio
      Item:  Martin Logan 35XT Bookshelf Speakers (ex-demo) Gloss Black Cherrywoof
      Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168
      Price: $1300
      Item Condition: Excellent condition, ex-demo from a professional HiFi dealer
      Reason for selling: Clearing stock
      Martin Logan – Motion 35XT
      Larger bookshelf speaker with a Folded Motion® XT tweeter and luscious high-gloss finishes. Voice-matched with MartinLogan ESL speakers.
      What makes the Motion Series sound so amazing? MartinLogan's dedicated in-house engineering team started by utilizing and refining the most advanced, compact technologies and combining them with innovative engineering. The result is an emotionally engaging sound that rivals (and most times trounces) traditional loudspeakers of similar size and price.
      Folded Motion® XT  Tweeters
      The signature Folded Motion tweeters utilize extremely low mass diaphragms that "squeeze" air, and require significantly less excursion than the typical 1-inch dome tweeter, which drastically minimizes distortion while providing a lightning fast response time. The increased surface area also provides a wide, yet controlled sound dispersion to create a realistic and carefully etched sound stage.
      The low distortion Folded Motion XT tweeter boasts a radiating surface 40% larger than those found in the award-winning Motion® Series products. This substantial leap in size increases the bandwidth and efficiency of the high-performance tweeter for effortless performance.
      Specifications
      Frequency Response
      50–25,000 Hz ±3dB
      Horizontal Dispersion
      80°
      Vertical Dispersion
      30°
      High Frequency Transducer
      1.25" × 2.4" (3.2cm × 6.1cm) Folded Motion XT Transducer with 4.5" x 2.75" (11.4cm × 7cm) diaphragm
      Low Frequency Transducer
      6.5” (16.5cm) aluminum cone with cast polymer basket. Non-resonant asymmetrical chamber format. Rigid structured dust cap to reduce cone break-up modes.
      Sensitivity
      92 dB/2.83 volts/meter
      Impedance
      4 Ohms Compatible with 4, 6, or 8 Ohm rated amplifiers.
      Recommended Amplifier Power
      20—250 watts per channel
      Crossover Frequency
      2,200 Hz
      Components
      Custom air core coil and low DCR steel laminate inductors. Polypropylene film capacitors in series and low DF electrolytic capacitors in parallel. Tweeter thermal/current protection.
      Inputs
      Custom 5-way tool-less binding posts
      Weight
      8.4 kg
      Dimensions
      34.3cm x 19.2cm x 30cm
    • By Class A Audio
      Item: Marantz SR5011 7.2 AV Receiver
      Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, Vic, 3168. Ph. (03) 8555 0735
      Price: $1200 + $50 shipping
      Item Condition: Excellent, ex-demo from a professional HiFi dealer
      The Marantz SR5011, a master control hub for 4K movies and music in medium size rooms, is built with the best HDAM audio components in its class, revealing more subtle sonic details than ever before. Marantz's unique circular display technology and curved fascia styling, combined with the SR5011's improved 5.6Mhz DSD playback and 5Ghz Wi-Fi capability, makes it the ideal high resolution music player and home theatre amplifier crossover machine.
    • By Huckles
      Item:  Campfire Audio ANDROMEDA S (sold) with Crystal Cable available still
      Price:  $1850 together or $1350 for Andromeda S and $650 $500 for Crystal Cable (still retails for over $1000).  Prefer to sell together as the synergy is astounding.  Donation to be made to StereoNET if sold here.  Paypal 2.7% on top + shipping.
      Item Condition:  Fantastic
      Reason for selling:  Upgraded
      Extra Info:  Termination is 2.5mm for balanced DAPs and mmxc connection.  Have all the original boxes and accessories, ALO cable was unused.  Purchased in Jan 2019 from Minidisc with receipt to be provided.  Tips are all unused as I used my own spinfits.
      Condition is fantastic, a couple of 'scratches', tiny but even just putting them gently on a table or looking at them in a funny way makes they scratch.  Beautiful finish though.  Sound is fuller in the mids than original andromedas and the treble a little slightly tamed too, which is always a great thing when it comes to sparkly highs.
      More photos of the cable and Andro S to come later this weekend.
    • By Gregory13
      Price: $ 900 +Postage, Paypal fees 4%
      Item Condition: Like New
      Payment Method: Pickup - Cash, Paypal.
      SOLID 100% PERFECT-SURFACE SILVER (PSS) CONDUCTORS
      FEP AIR-TUBE INSULATION (FEP is a Fluoro-Polymer)
      DIELECTRIC-BIAS SYSTEM (DBS, US Pat #s 7,126,055 & 7,872,195 B1)
      CARBON-BASED 3-LAYER NOISE-DISSIPATION SYSTEM (NDS)
      ASYMMETRICAL DOUBLE-BALANCED GEOMETRY
      COLD-WELDED DIRECT-SILVER PLATED PURE RED COPPER RCA PLUGS
    • By ikhuong
      Item: Primacoustic FullTrap - Broadband Bass Trap
      Price: $320 (rrp $729)
      Item Condition: good as per photos, no wall mount kit
      Reason for selling: have baby and need space for her Playpen
       This basstrap has 3″ thick acoustic panel (fiberglass sealed by manufacture) is highly effective from 125Hz and up.
       Lower frequencies pass through the front face and then cause the internal diaphragm (D) to resonate by a thick vinyl sheet.
      Condition as per photo, I only place the bass trap on the floor hence could not find the wall mounting kit. You can mount it easy by getting some wood in Burning and cut in 45% at one Edge. Due to this reason, price was discounted as another 10% for your DYI interest.
      Otherwise, it is totally fine and best to place in the corner between floor and wall to achieve  best results.
      There is no box, pickup only, cash payment upon pickup/inspection.
      https://www.primacoustic.com/fulltrap/specifications/
