Grizzly
Crooked cantilever
Is it possible to straighten a cantilever with some gentle force? It doesn't appear bent but is definitely off centre. What might cause this?Screenshot_20190720-064953_Messages.jpeg
There is some asymmetry of the grey material where the cantilever exits the body. Maybe the suspension has had it.
The grey material looks to be a fabric covering the coils. I took a few more (hopefully better) shots.
I would be tempted to unscrew the cover and check out what is going on inside, though your tinkering instincts may differ from mine. I see what you mean about the grey material- I don’t think it is the culprit.
Justin
Sorry to say @Grizzly but I'd say the suspension has definitely collapsed.
Unfortunately it's most likely a full rebuild or replace job going by the look of it.
Hi mate, could be too little bias applied over an extended period, or it’s taken a hit when lowering onto the start of an LP.
Don’t try and straighten it! Re align to cantilever and check bias/anti skate.
Cheers Keith
Edited by cheekyboy
Hi mate, could be too much bias applied over an extended period, or it’s taken a hit when lowering onto the start of an LP.
Cheers Keith
It's an integral cartridge and armwand so no adjustment can be made unfortunately
Cheers Keith
Can you source a replacement cart for it mate?
If by "Re align to cantilever " ... you mean twist the cart in the headshell so that the (crooked) cantilever is once again tangential to the grooves ... this doesn't sound like a complete fix, to me, Keith.  :no:
Sure, the stylus may well be positioned correctly in the groove - but the other end of the cantilever will not be in its correct position, relative to the coils/magnets.  So the channel balance will be affected.
Hello Andy, re alilgnment would be very small, but having looked closer at the whole set up, I think that a replacement cart would be the best bet, if one is available still. All better than a broken cantilever.:thumb:
Keith
@Grizzly Would be nice to see it tracking something mate. I think the antiskate could of caused this problem.
[mention=106714]Grizzly[/mention] Would be nice to see it tracking something mate. I think the antiskate could of caused this problem.
Antiskate would have pulled it the opposite way, once it's actually in the groove it's closer to centre, but still off a little.
From the last post, I'd skew the anti-skate to the opposite of what it is now.
This could re-align the cantilever over time. Worked for me on a Goldring MM but it wasn't nearly as off as yours.
Otherwise, possibly the dampener is shot, so needs a professional repair.  But if it plays  as it does now...
That thought crossed my mind, and I did try it with antiskate cranked to 11 (as it were) but it wasn't straight even then, and I figured we were getting significantly greater wear on one channel that way. Maybe I'm mistaken?
