mr gooner
Some enlightenment required
Hi all
Noob here. My current setup is a Rotel RA630 integrated amp paired to Monitor Audio Bronze 5 floor standing speakers.  As I'm looking to purchase the Yamaha WXC-50 to use a streamer would it be possible to connect an active subwoofer to WXC-50 & then run it through the Rotel. Reading other queries here it seems that the WXC-50 can be used in
"player" mode when connecting to an integrated amp but I'm not sure whether it will work when connecting an active subwoofer as well.
you can connect subwoofer to integrated amp if the Yamaha is used as a steamer only. Have a look as Rel or Svs subs connections.
Hi
Thanks for this. So with further reading my understanding is that I can use the line level outputs on the powered sub (RCA) & connect these to the Left & Right Pre Out connections on the Rotel using RCA cable.
I think it depends of the sub, if the sub has 2 RCA inputs L&R than 2 cables from preouts but if the sub has 1 than only 1 cable RCA from L or R preout. For music it is recommended to use speaker level outputs so if you are planning to get a sub make sure it comes with those inputs.
The subwoofer I'm keen on only has line level outputs. I've read about some people using line level converters but opinions seem to be mixed on this. Have also read about SVS wireless audio adapator kits. So i guess my next question is, hypothetically speaking, with all variables been equal, how much better would speaker level outputs be when compared to line level ouputs. Is it that noticeable?
Thanks again.
Edited by mr gooner
Thanks again.
It makes a huge difference in setting the crossover point.
Ok. I'll start looking at other subs. Thanks for taking the time to reply
    • By Lincolnbl
      Items:
      Mission M73i Floorstanding speakers (in Beech colour)
      Mission MC72 Center Channel (in Charcoal)
      Mission M70 Surround Speakers (in Charcoal colour)
      Velodyne CHT12R Subwoofer
      Yamaha RXV3800 AV Receiver
      All items have been well cared for. Never abused. Non-smoking house.
      Price: $950
      Item Condition: Used. Well looked after.
      Reason for selling: Upgrade time.
      Payment Method: Pickup - Cash
      Extra Info: Selling as a set at this stage. But if interested in individual components reply indicating your interest and will consider a split if most stuff goes.
    • By audio_file
      Item: Rotel RA-820
      Price: $150
      Item Condition: Scratched
      Reason for selling: Replaced
      Payment Method: Pickup - Cash, Paypal, Bank transfer
      Specifications from https://www.hifiengine.com/manual_library/rotel/ra-820.shtml:
      Power output: 25 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 40kHz
      Total harmonic distortion: 0.4%
      Damping factor: 20
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 75dB (MM), 95dB (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 66 x 271mm
      Weight: 5.5kg
      This was used for PC desktop speakers driving KEF Q1 speakers.
      I tried it on my Spendor SP2/3R2 and it had no problem driving these.
    • By GeneralHicks
      Item: Rotel RA-1062 Integrated Amp
      Price: $170 - SOLD
      Item Condition: Excellent operating and cosmetic condition
      Extra Info: Great little Rotel amp, built in phono stage, has had my Rogers sounding great these last few years. Comes with remote.
    • By JayNTH
      Item: YAMAHA CA-2000 Integrated amp
      Price: 1200 plus postage if required.
      Item Condition: Excellent working condition.
      Reason for selling: Reduce my collection.
      Extra Info: This beautiful vintage Yamaha amp CA-2000 was imported from Japan audio shop for my Yamaha ns-1000M and just having played a couple of times then sitting back on the shelf gathering dust, hence it time for someone who love the natural sound of this serious seri of Yamaha amp to enjoy it. This amp can be run on class A  30 wpc at 8ohm output, very impress sound, deep base, very clear sound stage. The amp is in excellent working condition, never been repaired or restored, all the electronic components are original, outside no scratches, no marks on the cabinet, front face very clear and clean.
      Note: This amp is 100v need a step down transformer to run.
      Link for specs:
      https://audio-heritage.jp/YAMAHA/amp/ca-2000.html
      Model Stereo integrated amplifier Effective output (0.03%, Aux) 20Hz to 20kHz: 140W + 140W (4Ω, Class
               120W + 120W (8Ω, Class
               30W + 30W (8Ω, Class A)
      1kHz: 180W + 180W (4Ω, Class
          130W + 130W (8Ω, Class B ) ) Total harmonic distortion (20Hz-20kHz) Phono1, 2 → Rec out (5V): 0.003% or less
      Phono MC → Rec out (3V): 0.03% or less
      Tuner, Aux → Pre out (3V): 0.005% or less
      Main in → SP out (60W, Class B, 8Ω 😞 0.01% or less
                 (15W, Class A, 8Ω): 0.005% or less
      Tuner → SP out (60W, Class B, 8Ω): 0.01% or less Power bandwidth (0.03%, 8Ω) Class B: 10Hz to 50kHz
      Class A: 10Hz to 70kHz Damping factor 45 or more (8Ω, 1kHz) Frequency characteristic Phono 1, 2 MC (RIAA deviation):
      30Hz
      - 15kHz ± 0.2dB Tuner-Pre out: 5Hz-100kHz +0 -1dB Tuner-SP out (8Ω load): 5Hz-50kHz +0 -1dB Input sensitivity (rated) / impedance Phono 1: 2mV / 47kΩ, 68kΩ, 100kΩ
      Phono 2: 2mV / 47kΩ
      Phono MC: 50μV / 10Ω
      Tuner, Aux: 120mV / 50kΩ
      Main in: 1V / 50kΩ Maximum allowable input (1kHz, 0.02% distortion) Phono1, 2: 310mVr.ms
      Phono MC: 7.5mVr.ms
      Tuner, Aux: 20Vr.ms Output level / impedance Rec out: 120mV / 600Ω
      Pre out: 1V / 500Ω Tone control characteristics Bass (125Hz⇔500Hz): ± 10dB (20Hz)
      Treble (8kHz⇔2.5kHz): ± 10dB (20kHz) Subsonic filter 15Hz, 12dB / oct High filter 10Hz, 12dB / oct Noise level / SNR (IHF-A Network) Phono1, 2: 82dB
      Phono MC: 71dB (input 50Ω short)
             68dB (input 0Ω short)
      Tuner, Aux, Tape: 100dB
      Main: 118dB Residual noise 0.07mV or less <Meter part> Instruction range -50dB to + 5dB response speed 100μs Return speed 0.95sec <Others> Power supply AC100V, 50Hz / 60Hz Rated power consumption 300W External dimensions Width 461x height 170x depth of 360mm weight 20kg
    • By Kiwi_steve
      Item: Yamaha Rx-A2060
      Price: $1100
      Item Condition: 9/10 (10/10 being new)
      Reason for selling: Upgraded to Marantz 6013 for 11.2 channel
      Extra Info: Unit is in immaculate condition, no marks, scratches or blemishes of any kind. Comes with original box with all accessories.
      Amazing amp, only ran atmos speakers off on board amps for the majority of the time as my floor speakers run off rotels. Good amount of punch, ran it a 5.2.4 configuration.
      If you want specs google is your friend.
      Has latest firmware updates for dolby vision etc.
      Not faults or issues.
      Low ball offers will be ignored, possibly trolled 😏
