Stephen0804
Cable Spaghetti Help
Being an audio visual and technology fan, one tends to have many devices and of course lots of cables to go along with it.
So in my listing/watching entertainment unit i have a mess of cables behind. I tried once before to reorganize and manage them better but it's still a disaster back there and over time i have added and removed devices making it even more of a mess, not to mention the potential for interference between cables etc. due to coils.
Therefore i believe that the best course of action is to pull every cable out and start over.
So my question is would it be best making all cables custom myself to the exact lengths? As to remove all excess. If so is there like a universal type of connection method? Or am I going to have to buy a termination tool for each type of connection? ie. Hdmi, usb, rca, power, ethernet etc.
Or is there some better way to organize cables that I'm overlooking?
What do you do to organize your cables? Or is it out of sight out of mind type thing?
Thought i would ask you guys before i started researching about cables and connectors and the tools to terminate said cable's/connectors.
Thanks in advance. i will now commence the Googles while i await your replies 😁
so after a few hours of Googleing looks like finding the hdmi connectors is going to be a challenge, or any connectors for that matter. I can find a few solder on hdmi connectors, but not any idc type ones that you just put the wires in and crimp which splices in, this type make a better more reliable connection without introducing unnecessary resistance.
i just assumed that the connectors where like ethernet cables but obviously it's not a easy for other cable types grr back to the drawing board.
is there perhaps someone like an electrician that comes around and does all the av wiring for you? at a cost obviously
Do a rough connections first and group the cables in functional bunches.
One would be power, another RCA/XLR audio signal, yet another high speed data like HDMI and ethernet.
See what lengths you need for each and then buy them.
This is how mine ended up looking like:
I left a bit of slack to facilitate movement for working on them (connecting / disconnecting new things):
Terminating RCA/XLR/power/ethernet is easy but not so for HDMI or USB as there is a limited selection available.
Power cables are available in 0.5m, 0.75, 1m and multiples of those for less than $1 a piece.
So are ethernet cables.
HDMI cost about $5 to $10 depending on length.
These are wholesale prices and if you cannot access them, become friends with someone who can. Like any electrician and or computer tech.
Hope it helps.
Roman
@rockeater that's some nice cable management you have there.
i might have to also consider mounting my power boards on the wall as you have done.
Just buy the cables too difficult to make, such as HDMI.  Go for exact lengths, plus enough to move equipment because you always seem to need to get to it!  Nothing worse than holding a 25kg amp and then realising you've run out of slack.
I just use velcro ties and as @rockeater said, group by use.
When I had both my HT and stereo sharing the mains and subs, it was an absolute nightmare.  I use Cable Buddies to tag both ends of cable and tie up slack.  Not cheap but they make life simpler especially when you take things in and out when re-organising the setup.
https://www.amazon.com/Cable-Buddy®-5-pack-Black-Organizer-x/dp/B00288OOQI
I have since separated the systems and drastically simplified the stereo setup.  That is one way to get rid of spaghetti junction.
Edited by Snoopy8
Typo
yeah, those velcro ties are handy i bought a heap last time i tidied the cables up.
i might get some of those cable buddies they look pretty good.
https://firstchoicecomms.com.au/product/velcro-25m-roll-19mm/
Cheapest way to buy velcro for wrapping cords - you can cut to any length required, rewrap as required. Fix to cabinets with screws etc. Can be purchased at many computer cable/electrician suppliers.
@Sentient has a good project underway which may offer some ideas
However neatly you organise your cables, eventually you will need to remove something in the future.  I label every cord/plug/interconnect with a tagged cable tie.  It makes it much easier to identify what is what.  Wallwarts are labelled using white electrical tape, biro and texta writes on it ok.
Can’t see a single cable from where I sit
Well 1
Well 1
well neither can i but, i know they are there haha.
anyway here are some pictures of my war zone 😅
Bloody hell
i know right lol, it definitely needs a redo
Well 1
There are a few nice disks obscuring the cables!
While on this topic, I've heard it's generally a no no to run signal cable and power cables in parallel due to EMI.
Is it then OK to run multiple power cables bunched together? Bear with me guys, I'm no Electrical engineer
As far as I'm aware it's OK to bundle all power cables together, and it's OK to bundle all the signal cables together. But not OK to bundle power + signal cables together.
But note that I'm not an electrical engineer either!
https://www.bunnings.com.au/cobra-assorted-cable-tie-tube-1000-pack_p4430496
I bought a couple of white Solidsteel racks on special (https://www.selby.com.au/brands/solidsteel/solidsteel-s5-5-hi-fi-rack.html) and the long white ties are perfect for tying cables to the rear of the rack. Cheaps as chips and can just cut them off and replace them if necessary.  The ties that is , not the racks, which are not cheap as chips
    • By auvz
      Item Condition: Excellent Shipping Options: Shipping is included in price. Suburb or Town: Melbourne State: Victoria Payment Method: Bank, PayPal Reason for selling: No longer required (hasn't been used in a while) Further information:
      RCA cable with low capacitance
      https://www.bluejeanscable.com/store/audio/LC1-design-notes.htm
    • By vunn
      Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Harrison State: Australian Capital Territory Payment Method: Paypal, Bank transfer, Cash on Pickup Reason for selling: Order wrong cable Further information:
      Review as below
      https://6moons.com/audioreviews2/wireworld/4.html
      Shipping is included in sale price Australia wide. Paypal will pay as friend, so no need to pay fee. Will contribute to SNA.
    • By hiradi
      Item Condition: used Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: St Marys State: Tasmania Payment Method: EFT Paypal Reason for selling: NLR Further information:
       This is one of the original Ortofon cables , blue , SPK 300 , 3.7 meters long with real bananas on each end ...if you need spades , I have some Neotech's here which I could fit....bought this cable recently here on SNA but plans changed ...so bargain here !!!!
      PS
      Have a slightly dearer Organic Audio Speaker Cable and a very good Power Cable also for sale if you want to combine ...!!! Thanks Helmut
    • By Audionutz
      Price: $$980 Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Central Coast 2251 State: New South Wales Payment Method: Cash, EFT, PayPal friend Reason for selling: Too short now
      Priced for a quick sale, these are $10k new!
      Purchased these last year & been simply amazed by their refinement & the improvement they made in my system. Sad to say, they’re now just too short for my current setup.
      This is the reference loudspeaker cable from ETI Eichmann with this topping the 5 models in the range (Q Ref, Q3000, Q100, Q500, Q100). This worked perfectly with my Martin Logan Monolith/ME 850’s.
      It is a hybrid technology using both pure silver and copper: " The hand-wound 99.99% solid silver ground conductor uses what ETI calls ‘Ground Nulling Circuitry’ (GnC). Keith Eichmann’s research has produced a proprietary Ground Nulling Circuit (GnC™) which actively works to maintain a quiescent zero Voltage state across the ground, protecting the signal conductor from ground induced capacitance and inductance. This facilitates smooth uninterrupted signal flow from one component to another, effectively isolates them and allows them to perform their tasks without interference. With each higher model in the range, the GnC™ grows in size, complexity, and sophistication."
      There was a review in six moons of the lower model (Q100) in the range (http://6moons.com/audioreviews/eti/1.html
       "ETI cables present a very black background against which music emerged with ease, clarity and flow. There may be something to this ‘ground nulling circuitry’ biz. My cable collection seems to constantly proliferate so there were plenty of contenders for comparison purposes. The ETI cables shone for their utter transparency and strict neutrality. There were no embellishments nor imbalances that would reveal or expose certain frequency anomalies. Music just flowed unimpeded, unedited and unsoiled.”
      They have been advertised used when you can get them for $3k in Europe and North America. I am selling these for what I paid. I consider them very good buying at this price & I’ll probably regret selling in the future ...
    • By Masseey
      Hello friends,
      Started using Fiio E17 as DAC to my stereo listening with vintage Rotel Amp.
      Currently connected mobile using 3.5mm jack out from to Fiio AUX in to fed source from Tidal. Which is 14/48khz
      Now wish to fed from mobile 3.5 mm jack/ android USB C to Fiio S/PIDF in. So it will fed 24/96.
      Do we have wire with like 3.5mm to S/PDIF in or USB C to S/PDIF in.
      Along with DAC I got few connectors attached images
      Any help will be much helpful.
      Excuse me if it's a invalid question.
