Gazman
SOLD: FS: NAD Pre & Power Amp 1155 & 2200
Item: NAD 1155 Pre & 2200 Power Amp (WITHDRAWN)
Price: $600 ONO
Item Condition: Great
Extra Info: Great package for a vinyl or digital setup, the NAD 1155 Stereo Preamp unit sounds great and has a wonderful phono section. If you're looking for an inexpensive entry into higher-end vinyl performance, this classic little preamp is for you, it has both Moving Magnet and Moving Coil phono stage with adjustable capacitance.
The NAD 2200 power amp is conservatively rated at 100w per channel into 8Ω (stereo), 400W into 8Ω (mono) and and the ability to drive low-impedance speaker loads without difficulty. This amp has heaps of power and has fantastic dynamic headroom with a clean neutral sound and all the power you need when you decide to crank it up
Both units are in great condition with some very minor surface scratches on the edges, see pictures. Both units have been serviced recently.
Pre Amp Specs
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.02%
Input sensitivity: 0.56mV (MC), 1.2mV (MM), 80mV (line)
Signal to noise ratio: 78dB (MC), 80dB (MM), 95dB (line)
Output: 12V (Pre out Max)
Dimensions: 420 x 75 x 276mm
Weight: 4.13kg
Power Amp Specs
Power output: 100 watts per channel into 8Ω (stereo), 400W into 8Ω (mono)
Frequency response: 3Hz to 80kHz
Damping factor: 100
Input sensitivity: 0.7V
Signal to noise ratio: 111dB
Speaker load impedance: 2Ω (minimum)
Dimensions: 420 x 123 x 370mm
Weight: 12.5kg
Edited by Gazman
Withdrawn from sale
    • By SoundGuy
      Price: $12,000 $10,500 $9300
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By Hi-Fi Whipped
      This unit has been mentioned in a number of threads so a couple of us thought it was time for a dedicated thread for users to share experiences and tips and also general discussion providing it stays on topic.
      NAD C658 BluOS Streaming DAC with Dirac Live integration
      Manufacturers Product Page: https://nadelectronics.com/product/c-658-bluos-streaming-dac/
      Dirac Live Website: https://live.dirac.com/
      Front
      Rear
      Features & Details
      BluOS Network Streaming with MQA Decoding ESS Sabre DAC Dirac Live Room Correction Gigabit Ethernet Dual Band Wi-Fi AC/N 2 Way Qualcomm aptX HD Bluetooth 2x MDC Slots for Future Expansion MM Phono Input 2x Line Inputs, 2x Optical inputs, 2x Coax Inputs Balanced Preamp Output Preamp Output Stereo Subwoofer Output USB Socket for adding optional Wireless Output Module IR In with Learning Function Trigger In/Out
      Dirac Live Reviews & Guides
      https://audiophilestyle.com/ca/reviews/dirac-live-2-digital-room-correction-software-walkthrough-r884/
      Nad C658 Product Reviews
      https://hometheaterhifi.com/reviews/amplifier/nad-c-658-bluos-streaming-dac-review/
      https://www.soundandvision.com/content/nad-c-658-network-audio-playerpreamplifier-review
      https://www.whathifi.com/reviews/nad-c-658
      https://www.stereo.net.au/reviews/nad-electronics-c-658-streaming-dac-preamp-review
      Nad C658 Video Reviews
    • By j_davis_1980
      Item: NAD C325BEE stereo integrated amp 50 W per ch 8ohms.
      Price: $250
      Item Condition: good
      Extra Info: A nice sounding amp in good condition. Original remote included. I don’t have the box, hence no shipping.
    • By SpotOn
      Item: NAD C 355BEE Integrated Amplifier
      Price: 325 plus postage if required
      Item Condition:Excellent
      Reason for selling: Upgrade
      Extra Info: Bought this about 10 months ago from another SNA member. Very nice sounding amp and is in excellent cosmetic condition. Comes with original remote and generic power cord.
      Power output: 80 watts per channel into 8Ω (stereo)
      Damping factor: 160
      Input sensitivity: 300mV (line)
      Signal to noise ratio: 98dB (line)
      Dimensions: 435 x 116 x 292mm
      Weight: 8.5kg
      Pick up is preferred but can pack safely and post at buyer's cost and risk if required.
    • By MattyW
      Ok, now that I've had my Wavebourn Edelweiss-3 for a few months and it's nicely burned in it's time for me to prepare writing my review of it which I'll post here over the coming month. I'll post my impressions and experience purchasing this wonderful amp from Anatoliy Lisovskiy, who will be releasing the production series of the Edelweiss-3 power amp, an integrated amp and separate preamp over the course of this year.
      As I understand it the current production version of the power amp and integrated will all be EL34 though allow and pin compatible tube to be used right through to KT120, possibly even KT150. My own amp on the other hand uses WW2 vintage CV1127 radar sweep tubes.
      The reason I initially started looking into a lower powered amp was that 6 months ago I built my first pair of DIY speakers. A pair of shallow cabinet open back speakers which share the performance characteristics of U frame open baffles. Unfortunately the copy darTZeel NHB-108B power amp I was running at the time was far too powerful making my 101db sensitive speakers too loud for regular use so I started investigating lower powered tube amps.
      While looking into various solutions someone on AudioKarma pointed me in the direction of Anatoliy's Wavebourn amps and I got in touch via the Wavebourn facebook group. Over the next month or so I had an interesting discussion with Anatoliy about his amps, and their suitabillity to drive my DIY speakers (Lii Audio FAST-10 full range, Aurum Cantus G3Si ribbon, Skar Audio VX1ST bullet & Lii Audio W-15 woofer) and this led to discussions of his amps variable damping factors allowing suitabillity with a wide range of speakers. A feature which I believe may well be unique to the Wavebourn amps.
      Overall details of the amp are as follows:
      Input: 0 dB (0.775V) RCA, 50K stereo.
      Outputs: low ohm for 4-6 Ohm and high ohm, for 8-12 Ohm load.
      Power: at least 6W for <1% total harmonic distortions.
      Soft asymmetric saturation (inaudible clipping), negative output resistance for damping of woofers (servo-control of speakers).
      Bandwidth: 10 Hz-90 KHz -3 dB, from 20 Hz full power.
      Tubes:
      Raytheon VT127 (CV1127) radar sweep power tubes.
      8CB11 driver/preamp tube (twin video pentode – filament powered from rectified DC for zero audible hum.
      VR150 / Russian SG4S voltage regulator (purple glow).
      VR tube and solid state MOSFET voltage regulation.  The “Edelweiss” series derives it’s name from this. A beautiful flower which grows amongst hard mountain rocks.
      Selectable speaker damping
      In order to support different speaker design types such as open baffles, horns, closed and ported boxes, there’s a damping factor switch that controls output resistance of the amplifier.
       Position 1 is the first on the left.
      1.       High output resistance (like pentode output with no feedback), sometimes referred to as "Current driving mode".
      2.       Similar to SET with no feedback.
      3.       SET with some feedback.
      4.       Negative output resistance for active servo-damping of woofers.
      With a little experimentation I soon found that I prefer the negative output resistance setting, which is actually Anatoliy's own preference. Probably the least tube like sounding setting giving tight, accurate bass where other modes seem a bit looser. This is what I've continued to use since the first week I received the amp.
