Krumlov
Centre to match B&W DM310
Hi all,
I have some trusty B&W DM310 speakers in my lounge room. The current centre (not B&W)  I want to replace. Whilst the are plenty for sale most are the new Kevlar drivers and so I am concerned about matching.
So any recommendations? For sale I have seen CC6, LCR6S2 and CC3.  Not wedded to these just came up in the searches.
Thanks in advance!
Edited by Krumlov
19 minutes ago, Krumlov said:
Hi all,
Thanks in advance!
dm310 are really going back... am not sure you will find something exactly close match meant to work with it. though likely id suggest any b&w centre utilised wiht them are likely / possibly a better match than what ever off brand using in the interim ?
especially second hand. id explore. but something you feel in scale and sounds looks similar from B&W back catalog... if it does turn out to be a miss match can always move on....,
in my own experience wiht 3 centre speakers over the years a better centre is a better centre. some brands are closer matches than others ...but while close in character I dont believe need an exact match in brand and series. close can work.
that said if you find another dm310 thats probably THE best match... though won't be in the shape form of a centre possibly looking for :D
ps word of caution. the LCR speakers are meant to work in vertical orientation. turn them horizontal as a centre speaker and it changes their sound significantly ...
Thanks, that’s what I was thinking. Was just wondering if some might be better than others but as you say the time since I bought these will make a precise match difficult.
If no one else has any better advice I will look to grab any B&W centre. Thanks for the heads up on the LCR I will avoid those.
    • By olegau
      Item: Adelaide Speakers Ascension  Woodfox Ribbon 822SRTL Bookshelf /stand mount
      Price: 900
      Item Condition: very good
      Reason for selling:Too big for my desktop. Wife factor
      High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
       Two years old, easy can compete $3000 other brand speakers.
      Audition welcome
      Power 120W
      8 ohms
      Sensitivity 91db
      Dimentions: 500 H x 270W x 315D mm
      Weight is approximately 18kg each.
    • By gypr1961
      Item: Avantgarde Zero 1 XD Active Speakers DSP
      Price: $19,000 negotiable
      Item Condition: Mint
      Reason for selling: Time for a change
      These are the top of the line model, above the pro model and come with DSP, digital and an analogue (A/D card) for turntables etc.
      They are incredibly dynamic! They sound just as good when theyre shaking the house or playing whisper quiet.
      I have all original packing
      As im going to need a complete new system Im happy to look at trades + cash
      Specs can be found here https://www.avantgarde-acoustic.de/en/products/zero-serie/zero-1-xd.html
    • By sufioz
      Item: Krix Harmonix Mark 1 speaker pair
      Price: $999
      Item Condition: Used, about 6 years old. These are my main speakers. I listen to them everyday and love them for the sound and looks. I don't have the boxes.
      Reason for selling: Looking to raise funds towards upgrade
      Payment Method: Pickup - Cash, Pickup-Bank transfer prior
      Extra Info: Note the subwoofer and the isolator feet (isoacoustics gaia iii) in the photos are not for sale. The subwoofer I am keeping and the isolator feet i can only offer for sale only once speakers are sold.
      Specifications:
      Frequency Range 30Hz - 20kHz in room response
      Power Handling Maximum 180 watts RMS amplifier power
      Sensitivity 90dB for 2.83 volts at 1 metre
      Configuration 4 driver 3-way bi-wirable / bi-ampable
      Bass Drivers 2 x nominal 165mm (61/2”) laminated polypropylene cones. 33mm (11/4”) voice coil wound on high powered aluminium former, with ventilated spider and aluminium flux stabilization ring for low distortion
      Midrange Driver 1 x nominal 130mm (5”) coated paper cone. 26mm (1”) voice coil wound on high powered aluminium former, using copper shorting ring and  oversized magnet for lower distortion
      Tweeter 28mm (1”) doped fabric dome. Ferro fluid cooled. Double magnet shielded
      Crossover Point 340Hz & 2.2kHz
      Impedance Nominally 4 ohms
      Enclosure Type Dual chambers - sealed midrange chamber, with bass reflex main chamber, front vented with internal / external flaring
      Dimensions 1060mm high x 220mm wide x 355mm deep
      Material 17mm MDF enclosure, heavily braced Finish Vinyl or lacquered timber veneer
      Volume 44 litres internal
      Weight 28kg each
    • By drainer2011
      Item: Dynaudio Focus 200XDs (decided to keep connect box and iso pucks so only selling speakers now see below price change.
      Price: $4000
      Item Condition: Used. Near brand new no marks at all.
      Reason for selling: NLR
      Extra Info:In perfect condition. Connect box and iso pucks NOT included in price. Price negotiable within reason.
      RRP when purchased in 2017 was
      Dynaudio Focus 200XDs- $7499
      I’llAdvertisements without photos of the actual item will not be approved.
    • By Paul_B
      Item: Whatmough S33i Signatures
      Location: Cheltenham can post at buyers expense. Won’t be cheap they are large and heavy.
      Price:  $6500 open to realistic offers.
      Item Condition: 18 months old still Like new. Have original packaging.
      Reason for selling: no room for hifi equipment
      Payment Method: Pickup - Cash, Bank Transfer
       I’m regretfully selling these but with my move to QLD  I don’t have room for a large hifi system. They are located at my old work The Audio Experts / Whatmough Audio in Cheltenham and can be picked up from there.
      these are a beautiful sounding speaker they are still a current model and retail at $11,499 they perform well above price range.
      If they sell at $6500 I’ll include the upgraded isolation feet.
      Description
      Whatmough S33i 3-Way Floor-Standing Speakers
      Overview
      The Whatmough S33i floor standing speakers are the ultimate speaker in the Whatmough Signature series. Their design and built quality are up to the audiophile standards.  The S33i delivers truly spectacular sound.
      The Signature S33i are based on the Performance Series P33i, with significant improvements to bring them up to Signature Series status.
      Cabinet
      This cabinet design offers more than just great looks – they also offer improved sound quality.  By eliminating internal parallel surfaces, the curved surfaces offer clearer and cleaner sound by minimizing internal standing waves.  Even more significantly, the curved panels are inherently more rigid and less resonant than the flat panels of a conventional speaker cabinet, which further helps to minimize coloration.
      Tweeter
      The Signatures S33i uses the same Ring Radiator tweeter that is used in Whatmough’s flagship speaker, the Paragon. This ultra-expensive tweeter sounds incredibly fast and detailed while also sounding extremely smooth and open. It has a very flat response extending to beyond 40KHz.
      Midrange
      The Signature S33i uses a 100mm cellulous fibre coned mid-range driver. This driver has the speed and transparency no bass/mid driver can match.
      Bass
      The Signature S33i uses two 170mm fiberglass/nomex hybrid drivers especially developed for these speakers. The cone for this speaker is made of Nomex with a skin of fiberglass. This long throw driver uses a 33mm high temperature voice coil and a large double magnet system.
      This driver has very high power handling as well as a very transparent detailed sound quality.
      Crossover
      The S33i uses high grade audiophile film and foil capacitors in critical positions.  Air cored coils are used throughout, wound from a heavier grade of high purity Australian copper.
      System
      The perfect partner in the Signature Series system featuring the S8i in the centre and P12i or PFX3i speakers in the rear for a truly exceptional home cinema surround sound experience.
      The S33i is fully made in Australia.
      Configuration
      3-way bass reflex enclosure using two 170mm hybrid fibre cone long elbow bass drivers, a 100mm cellulose fibre midrange driver and a 35mm dual concentric tweeter with wave guide centre plug.
      Nominal Impedance 4 Ohms
      Amplifier Power Requirement 25-150 watts RMS
      Power Handling
      Transient level in excess of 300 watts with an average level of 120 watts.
      Sensitivity
      88dB input level of 2.83V. (1 watt into 8 ?)
      Frequency Response
      38Hz to 40kHz ± 3dB
      Dimensions
      260W x 1200H x 430D mm
      Weight 45kg each
      Finish
      Real Bubinga Timber Veneer or Piano Graphite
      Warranty 5 Years*
