corza13
FS: price drop **Genelec 8000 series active 5.0 surround set
Ok. Can't believe I'm doing this.
Price drop to $2200
Oh wow, this is an insanely good price ! almost "buy 2, get 3 free"
Are there any Aussie pro-audio forums with classifieds sections? I would imagine some low mileage Genelec's would go quick there
    • By denimhunter
      Item:            AUDIO NOTE-Kondo io phono cartridge
      Price:           $3800
      Item Condition: excellent (recently retipped)
      Reason for selling: too many cartridges
      Payment Method: Pickup - Cash, Direct bank deposit only
      An early example of Audio Note-Kondo io mc phono cartridge.
      I purchased this from Japan and had the cartridge checked and retipped by ANA Mighty sound in France.  Retipped with Van del haul stylus.  Damper have been checked and suspension rebuilt.
      So this is literally a new cartridge.
      Played for about 10 hours for testing since rebuilt.  They are quite rare and hardly come up for sale.  The cost of the rebuilt alone is in excess of $2000.
      I have quite a few cartridges so just have to let go some to better home.
      Output 0.1 mv with 1 ohm impedance so will work with a minimum of x30 step up ratio and high gain phono stage.
      ANA mighty sound is highly reputable cartridge repairer and builder in France.
      Their Sculpture A3 cartridges were used by Thomas Schick, Frank Schroeder in Sibatone (western electric), Vitus and Thrax demo rooms among others in the recent 2019 Munich high end show.
      Additional info for those interested:
      http://anamightysound.com/
      François from Ana mighty have repaired and rebuilt Koetsu and SPU for me previously.  They are always careful to ensure the original sound signature of the cartridge design are retained, especially for the classics like koetsu and AN/Kondo.
    • By Bunno77
      Item: Cambridge Audio 551R V2
      Price: $500 + postage
      Item Condition: A few minor marks
      Reason for selling: Unused
      Payment Method: Pickup - Cash, Paypal, Bank Trans
      Unused as I have too much gear and don't do surround anymore.
      This really is a beast and outperforms newer AVRs in SQ. Big 1,050W oversized toroidal transformer. It is fantastic at surround and 2 channel performance is very impressive from power output to DAC quality.
      If you don't need/want all the 'features' of new AVRs this is very hard to beat.
      Great for a second complete system.
      There are a few minor scratches on the cover shown in the photos. Would be easily fixed with a texta. Once put into an entertainment unit etc they are not seen though. Comes with original remote. I don't have manual (can be found online here https://techsupport.cambridgeaudio.com/hc/en-us/articles/200926612-Azur-551R-V1-V2) and I don't have the original packaging but can easily bubble wrap and find a suitable box.
      POWER OUTPUT 110W RMS per channel, into 6 Ohms (two channels driven), 90W RMS per channel, into 8 Ohms (two channels driven), 60W RMS per channel, into 8 Ohms (all 7 channels driven)
      THD <0.006% @1kHz
      CROSSTALK <-60dB @ 1kHz
      FREQUENCY RESPONSE 10Hz - 20kHz -1dB
      SIGNAL TO NOISE RATIO >90dB 'A' weighted
      AUDIO INPUT IMPEDANCE/SENSITIVITY 47k Ohms / 175mV or greater
      DIGITAL INPUT IMPEDANCE 75 Ohms (Coaxial/S/P DIF)
      TONE CONTROLS Bass: +/-10dB @ 100Hz, Treble: +/-10dB @ 10kHz
      TUNER FM mode: 87.5-108MHz, 75 Ohm coaxial aerial, AM mode: 522-1629kHz, 300 Ohm loop aerial
      VIDEO LEVELS/IMPEDANCE - Composite (CVBS): 1Vp-p / 75 ohm - S-Video (S-VHS): Y 1Vp-p / 75 ohm C 0.286 Vp-p / 75 ohm Component: Y 1Vp-p / 75 ohm Cb/Cr 0.75Vp-p / 75 ohm Pb/Pr 0.75Vp-p / 75 ohm
      HDMI HDMI 1.4 EIA/CEA - 861D HDCP 1.1 All audio modes supported except reception of native Direct Stream Digital (DSD). ARC and 3D-TV/deep colour pass through supported. CEC and HEC not supported.
      ARCHITECTURE Cirrus Logic CS43122 24 Bit 192kHz capable DAC for Front Left & Right Cirrus Logic CS52526 24 Bit 192kHz capable CODEC for surround channels + 24 Bit 2 channel A/D conversio Cirrus Logic CS497004 dual 32 bit DSP Faroudja FLI2310 scaler
      AUDIO INPUTS 6 x Line Level Analogue Tuner (FM/AM) 7.1 Analogue Input 4 x Digital Co-axial, 4 Digital Optical
      VIDEO INPUTS 2 x Composite, 2 S-Video, 2 x Component Video, 4 HDMI
      AUDIO OUTPUTS 7 x Amplified Speaker, Outputs 7.1 x Preamp outputs
      VIDEO OUTPUT 1 x HDMI
      RECORDING AUDIO OUTPUTS 1 x Line Level Analogue, 1 x Digital Co-Axial, 1 Digital Optical
      OTHER CONNECTIONS 1 x 1/4" / 6.35mm Headphone Outpu (32 To 600 ohms recommended) 1 x IR Emitter In 1 x RS232C 1 IEC type mains inlet
      STANDBY POWER CONSUMPTION <1W
      QUIESCENT POWER CONSUMPTION < 70W
      MAX. POWER CONSUMPTION 700W
      DIMENSIONS (W X H X D) 430 x 110 x 340mm (16.9 x 4.3 x 13.3'')
      WEIGHT 10.0Kg (22lbs)
    • By Mohan Varkey
      Item: Enlightened Audio Designs DSP-9000 Pro
      Price: $1500 or nearest offer (includes $30 donation to SNA)
      Item Condition: Tested early this year, In good working condition, Occasionally has a tendency to reset itself.
      Some minor scratches on the gold plated front panel.
      Outer insulation on the DC chord is perishing. This does not affect performance
      Reason for selling: Surplus to my requirements for the foreseeable future
      Payment Method: Pickup - Cash, PayPal
      Extra Info: :
      Arguably one of the finest DACs available. Purchased second hand in 2006 for mastering church choir recordings. Preserves most of the dynamic contrasts and "air" in live performances.
      Manual is not available.
      No returns accepted
      Pictures
    • By denimhunter
      Item:         AUDIO TECHNICA AT1503iiia tonearm
      Price:       $1050
      Item Condition: very good
      Reason for selling:
      Audio Technica reissue of AT 1500 mk3, 10 inch, broadcast tonearm with removable headshell originally designed for use by Japanese broadcaster NHK.  Med-High mass transcription tonearm suitable for low compliance cartridge. Suitable for SPU as well.   The arm is selling for over $2,200 on eBay and in the US. Original din to RCA tonearm cable is Included.
      I am also selling on a separate listing, Aurealis din to rca cable which will work well with this tonearm.
      Refer to the following for information:
      https://www.lpgear.com/product/AT1503IIIA.html
    • By denimhunter
      Item:         AUREALIS r3i copper din to rca cable
      Price:        $250
      Reason for selling: surplus
      Cable is 1.5m, 5pin din to rca and made in Queensland by Aurealis, an Australian cable company with UP-OCC copper litz wire.  Shielded to minimise hum.  ETI kryo treated silver coated copper rca plugs. Details refer to Aurealis Audio web site below:
      https://www.aurealisaudio.com.au/r3i-shielded-interconnects/
      From the website:
      The R3i CuL is a tonally warm and fully detailed cable.  The Litz wire carries a very broad frequency range which results in more detail, better sound staging and and improved bass end compared to the solid core version of this cable.
      Features
      4 UPOCC copper Litz conductors per channel. These are insulated in PE. Cable damping and insulation in foamed teflon tube Tinned copper braid shield ETI Kryo RCAs (silver plated copper) Finished in a rich red and braid - double thickness
      Bought a few months ago but hardly been used so in excellent condition.
      Retail for 1.5meter cable $390
