Audio Connection
SOLD: Bryston 14BSST2 Power Amp with 600w in excellent Condition
Item: Bryston 14BSST2 Power Amp with 600w in excellent Condition
Price: $7500.
Item Condition: Pre owned
Reason for selling: Clearance
Payment Method: Pickup - Cash, Credit Card on pick up, Direct Deposit
Extra Info: Can post at extra cost
Bryston, renown manufacturer of amplifiers markets products with a full gamut of power output ranges. The 14B SST2 is a stereo power amplifier rated at 600 watts per channel output into 8 ohms. If you have speakers that are not very sensitive (e.g., 85 dB/w/m), then yes. The reason is the overhead. Most of the time, regardless of the music, the power delivered to your speakers will be less than 20 watts per channel. But, with powerful transients, such as the leading edge of a steel string guitar, crash of a cymbal, or a big crescendo, the power demand can easily go to hundreds of watts. That is because for 10 times the wattage, the sound only doubles in loudness. So, if you are using 20 watts, and along comes a demanding passage, you had better have at least 200 watts or more in reserve. Otherwise, it will either clip, or the amplifier will limit the output and it won’t sound as if the passage is as loud as it should (dynamics are an important part of the “you are there” listening experience).
Edited by Audio Connection
Has the price of this increased as it was initially advertised here & on eBay at $6500?
    • By Timos
      Item: Paradigm PW600 Premium Wireless Speaker
      Price: $650 negotiable
      Item Condition: Brand new, still in box
      Reason for selling: Bonus with my new Anthem receiver and I don't need it.
      Payment Method: Pickup, Cash, Bank transfer
      Extra Info: As described, still new in box and happy to ship at buyers expense.  RRP $999.
    • By Believe1980s
      Item: LUXMAN DA-100 USB DAC & Headphone amp (Made in Japan)
      Price: $750
      Item Condition: Mint / 99% New (see photos below) No dust, no scratch, no dot.
      Reason for selling: Upgrade
      Payment Method: Pickup - Cash, COD
      Sampling frequency ... COAX / OPT input: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
      Sampling frequency ... USB input: 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
      Digital Input: USB (B type), OPT (light), COAX (coaxial)
      Digital output: OPT (light), COAX (coaxial)
      Analog Output: RCA unbalanced 1 system, headphones 1 system
      Brand: LUXMAN
      Manufacturers Part No. DA-100
      ☆ USB: 96kHz / 24bit
      ★ coaxial-light: 192kHz / 24bit
      Compact 2-channel PCM system D / A Converter ◆ A5 document size
      ◆ Adopt bar Brown latest chip PCM5102 with a built-in 32bit processing and high-quality buffer amplifier to the DAC chip
      ◆ is equipped with two types of digital filters with different easily switchable FIR and IIR characteristics
      ◆ Equipped with USB port (B type), you can enter the USB digital audio signal from the PC / Mac, etc.
      ◆ digital input, the sampling frequency of 32kHz ~ 192kHz (USB is up to 96kHz), 16bit, 20bit, corresponding to the number of quantization bits of the 24bit (USB is 16bit, 24bit only)
      ◆ The digital inputs including USB available through output, equipped with a digital output (DD converter function)
      ◆ Built-in high-quality headphone amplifier circuit equivalent to that of the top models DA-200
      ◆ installation of low phase noise clock module with reduced noise near the oscillation frequency
      ◆ The digital inputs, low jitter reduction by high-precision clock of DAIR with a built-
      The sampling frequency display by the three-digit 7-segment LED with excellent visibility ◆
      ◆ plenty of adopting the round pattern wiring board and original custom parts of Luxman tradition, etc.
      ◆ Equipped with RCA output terminal of 18mm pitch gold-plated finish that corresponds to the large plug connection
      ◆ USB connection to the PC since Windows XP, corresponding to each of the OS standard driver later MacOS10
      Also possible ※ display does not switch upright of the body by attaching accessories leg of the (foot) on the side ◆
    • By OakenShield1
      Item: JVC JL-A1 Turntable with Ortofon 2M Blue Cartridge
      Price: $400
      Item Condition: 5/10
      Reason for selling: Surplus
      Reluctantly putting up my grandfathers old turntable, it hasn’t been used for years. I’ve just fired it up and it seems to work ok, belt seems a little loose so might want to invest in a new one. Pretty good stylus, doesn’t have a lot of hours in it. Will be way less than 100. Pickup only in Vermont as I don’t have any packaging for it. Got a couple of places where the laminate is lifting up (as pictured) everything else seems to be pretty good on it.
      Welcome to inspect
    • By 075Congo
      Item: ATACAMA Isolation Gel Pads (Set of 😎 Clear Version
      Price: $20 including postage
      Item Condition: USED
      Reason for selling:  now using Herbies Audio Garage Thin Fat Dots
      Payment Method: Bank Transfer
      Extra Info: For use on the top plate of Speaker Stands to minimise vibration entering speakers. New 3M Double-sided adhesive tape fitted to all 8 Gel Pads. RRP is currently $50. SNA Donation after sale
    • By henning
      Item: ATC CA-2 Preamp
      Price: $1100
      Item Condition:7/10
      Reason for selling:Surplus
      Extra Info: A very nice little preamp. This one has the optional Phono board suitable for MM/MC (internally adjustable for gain and loading). Have original box, manual and remote. I acquired this with some Microphones and have not used it much, the phono stage is very nice, probably a little better than some of the  well-regarded $1200 stand alone phono stages I have tried.  Some scratches on the top as per pic. The only little niggle is that occasionally, the standby switch needs to be pressed more than once to put amp back in to standby but this does not occur when using the remote control. It has been like this for some years and isn't getting worse.
      Happy to post at buyers expense.
