Jpp7777
Yamaha NS 333 v NS F50 for fronts in 5.1 setup
Hi..I. Currently have a Yamaha P 60 package which included two Ns F50 as my fronts. I have the opportunity to get some NS333 bookshelf speakers as fronts.
Just wanting some advice. Re is this an actually upgrade to the F50's I currently have.  Thanks in advance
    • By JayNTH
      Item: YAMAHA CA-2000 Integrated amp
      Price: 1200 plus postage if required.
      Item Condition: Excellent working condition.
      Reason for selling: Reduce my collection.
      Extra Info: This beautiful vintage Yamaha amp CA-2000 was imported from Japan audio shop for my Yamaha ns-1000M and just having played a couple of times then sitting back on the shelf gathering dust, hence it time for someone who love the natural sound of this serious seri of Yamaha amp to enjoy it. This amp can be run on class A  30 wpc at 8ohm output, very impress sound, deep base, very clear sound stage. The amp is in excellent working condition, never been repaired or restored, all the electronic components are original, outside no scratches, no marks on the cabinet, front face very clear and clean.
      Note: This amp is 100v need a step down transformer to run.
      Link for specs:
      https://audio-heritage.jp/YAMAHA/amp/ca-2000.html
      Model Stereo integrated amplifier Effective output (0.03%, Aux) 20Hz to 20kHz: 140W + 140W (4Ω, Class
               120W + 120W (8Ω, Class
               30W + 30W (8Ω, Class A)
      1kHz: 180W + 180W (4Ω, Class
          130W + 130W (8Ω, Class B ) ) Total harmonic distortion (20Hz-20kHz) Phono1, 2 → Rec out (5V): 0.003% or less
      Phono MC → Rec out (3V): 0.03% or less
      Tuner, Aux → Pre out (3V): 0.005% or less
      Main in → SP out (60W, Class B, 8Ω 😞 0.01% or less
                 (15W, Class A, 8Ω): 0.005% or less
      Tuner → SP out (60W, Class B, 8Ω): 0.01% or less Power bandwidth (0.03%, 8Ω) Class B: 10Hz to 50kHz
      Class A: 10Hz to 70kHz Damping factor 45 or more (8Ω, 1kHz) Frequency characteristic Phono 1, 2 MC (RIAA deviation):
      30Hz
      - 15kHz ± 0.2dB Tuner-Pre out: 5Hz-100kHz +0 -1dB Tuner-SP out (8Ω load): 5Hz-50kHz +0 -1dB Input sensitivity (rated) / impedance Phono 1: 2mV / 47kΩ, 68kΩ, 100kΩ
      Phono 2: 2mV / 47kΩ
      Phono MC: 50μV / 10Ω
      Tuner, Aux: 120mV / 50kΩ
      Main in: 1V / 50kΩ Maximum allowable input (1kHz, 0.02% distortion) Phono1, 2: 310mVr.ms
      Phono MC: 7.5mVr.ms
      Tuner, Aux: 20Vr.ms Output level / impedance Rec out: 120mV / 600Ω
      Pre out: 1V / 500Ω Tone control characteristics Bass (125Hz⇔500Hz): ± 10dB (20Hz)
      Treble (8kHz⇔2.5kHz): ± 10dB (20kHz) Subsonic filter 15Hz, 12dB / oct High filter 10Hz, 12dB / oct Noise level / SNR (IHF-A Network) Phono1, 2: 82dB
      Phono MC: 71dB (input 50Ω short)
             68dB (input 0Ω short)
      Tuner, Aux, Tape: 100dB
      Main: 118dB Residual noise 0.07mV or less <Meter part> Instruction range -50dB to + 5dB response speed 100μs Return speed 0.95sec <Others> Power supply AC100V, 50Hz / 60Hz Rated power consumption 300W External dimensions Width 461x height 170x depth of 360mm weight 20kg
    • By Kiwi_steve
      Item: Yamaha Rx-A2060
      Price: $1100
      Item Condition: 9/10 (10/10 being new)
      Reason for selling: Upgraded to Marantz 6013 for 11.2 channel
      Extra Info: Unit is in immaculate condition, no marks, scratches or blemishes of any kind. Comes with original box with all accessories.
      Amazing amp, only ran atmos speakers off on board amps for the majority of the time as my floor speakers run off rotels. Good amount of punch, ran it a 5.2.4 configuration.
      If you want specs google is your friend.
      Has latest firmware updates for dolby vision etc.
      Not faults or issues.
      Low ball offers will be ignored, possibly trolled 😏
    • By mrf0ster
      Item: Yamaha CD-S2000 HIgh End CD/SACD PLAYER
      Price: 1300.00 ONO PRICE DROP: $1000.00 FINAL RICE DROP $800.00
      Reason for selling: Funds required elsewhere
      https://au.yamaha.com/files/download/other_assets/6/317696/CD-S2000_NPB.pdf
      https://www.avhub.com.au/product-reviews/hi-fi/yamaha-cd-s2000-sa-cd-player-392553
      The player is in excellent condition, with superb sound quality. It comes with remote, manual and original box.
      "If you’re after a superbly constructed audiophile CD player which delivers high-end performance at a price so low as to be verging on the ludicrous, Yamaha’s CD-S2000 is a tour-de-force. It will play back your CD collection with a level of precision and fidelity that will have you going back for more, and more, and more. (Oh yes… and it plays SA-CDs as well.) "
      SpecificationsCD PlayerType
      Type:Single Disc CD PlayerDisc CompatibilitySACD, CD, CD-R/RW (MP3, WMA)Output LevelSACD / CD 2 ±0.3 V (1 kHz, 0 dB)Output LevelSACD / CD 2 0.3 V (1 kHz, 0 dB)Signal-to-Noise RatioSACD / CD 116 dBHarmonic DistortionSACD 0.0017% (1 kHz), CD 0.002% (1 kHz)Dynamic RangeSACD 110 dB, CD 100 dBFrequency ResponseSACD 2 Hz-50 kHz (-3dB), CD 2 Hz-20 kHzOutputOptical and CoaxialPower Consumption30W
      If you are interstate and interested, please research shipping and organise yourself.
      Dimensions (W x H x D)17-1/8 x 5-5/16 x 17-5/16 Weight33 lbs. 15kg
      Thank you.
      (I know my photo skills need a lot of work)
    • By mr gooner
      Hi all
      Noob here. My current setup is a Rotel RA630 integrated amp paired to Monitor Audio Bronze 5 floor standing speakers.  As I'm looking to purchase the Yamaha WXC-50 to use a streamer would it be possible to connect an active subwoofer to WXC-50 & then run it through the Rotel. Reading other queries here it seems that the WXC-50 can be used in
      "player" mode when connecting to an integrated amp but I'm not sure whether it will work when connecting an active subwoofer as well.
