Phuong
SOLD: Denon POA-S10 Monoblock Power Amplifiers
Item: Denon POA-S10 Monoblock
Price: $1550 + shipping if required
Item Condition: Very good
Reason for selling: moving to integrated
Power output: 150 watts per channel into 8Ω
Frequency response: 1Hz to 150kHz
Total harmonic distortion: 0.02%
Input sensitivity: 1V
Signal to noise ratio: 120dB
Speaker load impedance: 4Ω to 16Ω
Dimensions: 310 x 207 x 426mm
Weight: 15.7kg
Currently I am using a Denon PMA-1500RII as preamp.
Any information please ask. Cheers.
Photos: .
2 minutes ago, SPACEHULK said:
Hello what state location please?
NSW. Cheers
I owned the matching CD player, twice, built like a tank and the champagne finish is beautiful in the flesh. These would have cost some serious coin when new.
I worked at a shop that sold a lot of Denon and their monoblocks were especially popular at the time. If you pair these with a decent quality pre amp and cables they will deliver glorious sound with just about any speakers you can name.
Not clinical and not cuddly, just open and beautifully defined sound.
I try and refrain from commenting on for sale ads unless im buying but damn this seems like unbelievable value. If i didn't already own 4 channels of decent amplification id jump on them!
Yes, the sound is beautiful, sweet and detail. One thing I don't like is it has no remote control so every time when I want to listen, I have to go to turn on and off. Too many steps. I am getting lazy :).
Thanks for your comment. If I can sell my Luxman 507u, I will keep them. The sound is better than Luxman with half of the price.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED TUBE AMPLIFIER BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By alexb
      Item: Nordost Hemidall 2 Australian Power Cable 1m
      Price: $SOLD
      Item Condition: Mint in original box
      Reason for selling: Selling headphone rig
      Payment Method: Pickup, Cash, EFT, Paypal (buyer pays all transaction fees and postage)
      Mint condition, locally purchased power cable with Australian Furutech 15A plug. Used infrequently for dedicated head-fi rig. Comes with original box, warranty card and user manual.
    • By SBM
      Marantz SR6012 vs Denon 4500
      Looking forward to upgrade my AVR.
      Between above two  AVR which has good hardware configuration?
      Currently using Denon 520BT for 3 years. Happy with the Sound signature.
      Thank you
