furtherpale 549 Posted June 16 (edited) Hi I’m a hardcore 2 channel guy. I sorted a NAD758v3 for the Mrs, Dali Ikon Speakers. We have a 70” Sony LED ($2k... so probably considered average in videophile circles). I can wax lyrical on anything 2 channel, HT is a weak point. Seeking recommendations on a 4K UHD/Atmos playing spinner that’s not ‘too good’ for what we have, and not a POS. <$500 preferably, willing to go over if there is a good reason. Fire away! Edited June 16 by furtherpale 1 Quote Share this post Link to post Share on other sites
Janjuc 22,316 Posted June 16 (edited) Hi furtherpale, have you considered the Sony UBP-X700 Compact 4K Ultra HD Blu-ray Player, pricing is around $300 and as you have a Sony already may reduce the need for a number of remotes. I have had a Sony HD player for 8 years and it is still going strong in a second system. Reviews: https://www.whathifi.com/us/sony/ubp-x700/review https://www.cnet.com/reviews/sony-ubp-x700-review/ https://www.trustedreviews.com/reviews/sony-ubp-x700 JJ Edited June 16 by Janjuc 2 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 16 18 minutes ago, Janjuc said: Hi furtherpale, have you considered the Sony UBP-X700 Compact 4K Ultra HD Blu-ray Player, pricing is around $300 and as you have a Sony already may reduce the need for a number of remotes. I have had a Sony HD player for 8 years and it is still going strong in a second system. Reviews: https://www.whathifi.com/us/sony/ubp-x700/review https://www.cnet.com/reviews/sony-ubp-x700-review/ https://www.trustedreviews.com/reviews/sony-ubp-x700 JJ That’s awesome... worth spending more? 0 Quote Share this post Link to post Share on other sites
Janjuc 22,316 Posted June 16 3 minutes ago, furtherpale said: That’s awesome... worth spending more? Hi, I suppose it gets down to what features you want, might be a plan to take some of your favourite disks to a retailer and see if you you can compare different players on the same model as your TV. JJ 2 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 16 4 minutes ago, Janjuc said: Hi, I suppose it gets down to what features you want, might be a plan to take some of your favourite disks to a retailer and see if you you can compare different players on the same model as your TV. JJ Don’t have any yet :0 0 Quote Share this post Link to post Share on other sites
cwt 709 Posted June 16 Another option is the pana 420 furtherpale . It has whats considered very good HDR bitmapping [ either by doing it itself or matching your panels capabilities ] It has the same HCX processor chipset as the dearer 850 and uses an upscaling multitap process to convert 10 bit standard UHD to 12bit unlike others. However if you are going to upgrade your tele to a UHD model that accepts dolby vision ; the sony Janjuc said is compatible ; the pana is not [ you have to go to the .850 for that] ; the 420 can do HDR10+ Both models handle standard HDR10 which is mandatory for UHD discs .. Should mention too ;you need a UHD tele with hdmi 2.0a or 2.0b to receive the WCG and HDR that UHD is all about . Otherwise older tvs may have to bitmap the quality down eg a hdmi 1.4 tv can accept 4k resolution but you need the latest hdcp protocol 2.2 to get the goodies . Have a read of this [ its a bit dated ] to see why hdcp is important https://www.cnet.com/news/hdcp-2-2-what-you-need-to-know/ 2 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 16 (edited) 55 minutes ago, cwt said: Another option is the pana 420 furtherpale . It has whats considered very good HDR bitmapping [ either by doing it itself or matching your panels capabilities ] It has the same HCX processor chipset as the dearer 850 and uses an upscaling multitap process to convert 10 bit standard UHD to 12bit unlike others. However if you are going to upgrade your tele to a UHD model that accepts dolby vision ; the sony Janjuc said is compatible ; the pana is not [ you have to go to the .850 for that] ; the 420 can do HDR10+ Both models handle standard HDR10 which is mandatory for UHD discs .. Should mention too ;you need a UHD tele with hdmi 2.0a or 2.0b to receive the WCG and HDR that UHD is all about . Otherwise older tvs may have to bitmap the quality down eg a hdmi 1.4 tv can accept 4k resolution but you need the latest hdcp protocol 2.2 to get the goodies . Have a read of this [ its a bit dated ] to see why hdcp is important https://www.cnet.com/news/hdcp-2-2-what-you-need-to-know/ My TV is HDR, but I don’t t believe Dolby vision*? KD-70X6700E First I’ve heard the term. Edited June 16 by furtherpale 0 Quote Share this post Link to post Share on other sites
cwt 709 Posted June 16 14 minutes ago, furtherpale said: My TV is HDR, but I don’t t believe Dolby vision*? KD-70X6700E First I’ve heard the term. Found a sony compatibility chart and the page for your tv ; ; https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/specifications https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/articles/00201530 Yes a year out for DV but is compatible with HDCP and HDR10 ; which is the main thing What Dolby vision and HDR10+ do is calculate the hdr scene by scene rather than an average of the whole movie . Good but not worth upgrading a tv for an increment ; especially by a good bitmapping player .. 1 Quote Share this post Link to post Share on other sites
Irek 308 Posted June 16 Sony UBP-X700 Compact 4K Ultra HD Blu-ray Player One remote. 0 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 16 40 minutes ago, cwt said: Found a sony compatibility chart and the page for your tv ; ; https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/specifications https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/articles/00201530 Yes a year out for DV but is compatible with HDCP and HDR10 ; which is the main thing What Dolby vision and HDR10+ do is calculate the hdr scene by scene rather than an average of the whole movie . Good but not worth upgrading a tv for an increment ; especially by a good bitmapping player .. Ty! So UBP-X700? 0 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 16 42 minutes ago, cwt said: Found a sony compatibility chart and the page for your tv ; ; https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/specifications https://www.sony.com.au/electronics/support/televisions-projectors-lcd-tvs/kd-70x6700e/articles/00201530 Yes a year out for DV but is compatible with HDCP and HDR10 ; which is the main thing What Dolby vision and HDR10+ do is calculate the hdr scene by scene rather than an average of the whole movie . Good but not worth upgrading a tv for an increment ; especially by a good bitmapping player .. All good... would change a cable (I have some that cost more than the TV) or a component on the 2 channel system before swapping the TV. we just want to get the best out of what we have without going over the top. 0 Quote Share this post Link to post Share on other sites
cwt 709 Posted June 16 (edited) 8 hours ago, furtherpale said: Ty! So UBP-X700? Trying not to play favourites but since dolby vision isn't in play ;the 420 has comprehensive HDR optimiser settings to better match your panel or even projector and the HCX processor is 2nd generation [better than the 1st in a ubd900 ;their 1st THX machine] which is also used in the 1.5k 9000.... Heres a review that shows how it can take over the tone mapping if you prefer a choice depending on your 6700e;s handling it ; has a handy adjustment on the remote too ; I use a harmony though.. too many remotes😉 https://allhomecinema.com/review-panasonic-dp-ub420-ultra-hd-blu-ray-player/ Edited June 16 by cwt 1 Quote Share this post Link to post Share on other sites
furtherpale 549 Posted June 21 (edited) Ty all... will probably get the Sony for the convenience. I understand there may be better... but HT is realistically a secondary consideration for us (I’ve spent $1k on a single record... and $3.6k on my speaker cable it’s all about the two channel here). ty again... I genuinely value the input. Edited June 21 by furtherpale 1 Quote Share this post Link to post Share on other sites
