niss_man
Sansui AU555a Rebuild, restore, modifications and distortion results thread
I recently was able to aquire an Early Sansui (most likely 1971 model) AU555a from Gumtree. I have previously helped a mate get his late fathers AU555a rebuilt and modded a few months back and really enjoyed the sound these things produced so jumped at the chance to get one for myself with intention of holding onto it for many years to come. Another overhaul was on the cards before it even was in the house.
     Just recently I did learn to test for distortion measurements by reading this thread (mods please remove if you don't allow links to other forums but it is useful info). https://www.diyaudio.com/forums/solid-state/338511-howto-distortion-measurements-rew.html
Also these mods not done out of my own genius so I take no recognition for that. Other more knowledgable folk have done rebuilds on these before and I found a handy thread over here https://audiokarma.org/forums/index.php?threads/leestereos-restoration-upgrade-of-a-sansui-au-555a.816754/ .
Anyway this thread will be mainly photos and maybe some useful info so that other prospective diy incensed individuals want to have a go at something like this, it may help them.
As you can see the front face is in spectacular condition. No scratches for something nearly 50yrs is pretty good I must say.
Looks like it has been services a couple of times. Last time in 04.
Cover in excellent nick apart from a scratch.
Ends of cover have splits (delamination of ply). I ended up putting some super glue in the split and clamping them together.
Original inside before clean. This is for it's age a very clean amp with not much dust build up. It must have lived a good life. The only down side I can see is a bit of tarnishing on the gold metal base plate and tone control cover.
Amplifier board before touching.
Now comes the fun stuff
Time to put some new parts in this baby and get her back to new spec.
This is a measurement of distortion of my chinese signal generator. it shows 1.22% THD on top left corner. So if I measure my amplifier and get 2% distortion. The actual amp distortion is 2 - 1.22 = 0.78% THD. See how crappy my signal generation distortion is I have decided to build another super low distortion signal generator, but that is a project for another day being put under an ever increasing project pile.
123302445_AU555aLCbeforemodsextoscilator.thumb.png.72bc225bd3e0d4b989f77ba668aec532.png
Left channel before restore. THD = 1.5 - 1.22 = 0.28% THD. all measurements were taken at 1v output into my external Behringer soundcard.
2046751487_AU555aRCbeforemodsextoscilatorafterwarmup.thumb.png.de5549def61d7ba27745b74bef8eb64c.png
Right channel. = 2.11 - 1.22 = 0.89% THD. Now thats a bit different to the left channel. I am begining to suspect dodgy transistor/s somewhere. Maybe in the Tone control/pre stage board.
Also with this test you can see this channel has more 3rd order harmonics a 3KHz compared to the left.
1033040584_LCPowersuplyharmonicsbeforemods..thumb.png.39070ef192f04ac50eac6a7053c93f73.png
This is the power supply harmonics as tested on the LC output before any mods.
1317734713_RCPowersuplyharmonicsbeforemods..thumb.png.43bcb071a1ecb864354bd59fa47bcaf4.png
This is the RC power supply before mods. Pretty much the same.
Parts replaced in the power supply include all the capacitors, a out of spec resistor and a couple of old diodes. It is funny how large the old capacitors used to be. The replacements are the same diameters (I wanted them to fit in the same clamps) but are not as long but still the new ones are all of greater capacitance and voltage ratings than the old ones. These caps have 2 - 3 times the capacitance of the originals with a smaller form factor. Upgraded PS. Tick!
1570779463_LCPowersuplyharmonicsaftermods..thumb.png.7009afe194b23f3b74e439c57cc7c37b.png
579859804_RCPowersuplyharmonicsaftermods..thumb.png.4049d4f8f7976f07cdd91348915ded5d.png
A big difference now. The harmonics have significantly dropped especially that 2nd harmonic at 100Hz gone into the noise floor. The noise floor has also dropped all across the frequency band.
New Nichicon caps in power supply at top.
Tone control board parts. I also replace the transistors on this board with new matched transistors.
Well looky here. As suspected one of the transistors thought it would start to identify as a diode, not that I have a problem with that, just not in my amplifiers thank you very much😋.
The funny thing is when I bent the pins of this transistor (as a dodgy trans..istor identifier), it now showed ok.
1826839089_AU555aLCpresectionaftermods.thumb.png.c78561af520ab86edb565cf937b84825.png
This LC pre section only (links removed at back of amp). This is nice 1.26 - 1.22 = 0.04% THD out of the pre section LC.
1929943005_AU555aRCpresectionaftermods.thumb.png.43ccdd1522f10f9f985c8edc1a7a433e.png
RC has 1.24 - 1.22 = 0.02% THD. Now an excellent result. Again this is pre section only.
This is the Phono stage board. It has been modded to have a more acurate riaa curve and is the same topology as found in the AU-666, AU-777 and later Sansui phono stages.  The modified AU-555A RIAA equalization is accurate ±0.2dB from 20Hz-20kHz.
Amplifier board parts.
Its had a nice clean inside as well. Note the early models have these UFO ceramic transistors. I left them alone as they are excellent Mil spec ones and I like them and they test fine and they look really cool. Pots are changed to multi turn types.
After amp was adjusted and bias set now.....
Final LC measurement is 1.43 - 1.22 = 0.21 % THD back to correct specs
RC 1.45 - 1.22 = 0.23% THD also excellent.
Some final pics before it gets put back into use as the lounge room amplifier.
Wood split gone.
After fixing the splits, I gave the wood cover a light sand and sprayed on a few coats of clear laquer satin finish.  The scratch is still visible in the right light/angle but is better than before.
That cover is sexy
A clean up and de-oxit of terminals and connections. The Black base plate had a sand, service stickers removed and re-painted satin black.
As good as I can get it. Its funny those marks on the tone control metal cover look like an actual hand print. Maybe from the manufacturing process? who knows..
Power amp board.
The pots were originally all quite stiff in their action. Like someone may have put lots of wd40 that had gone tacky with time. So all the pots and switches were removed and cleanned properly to give a nice smooth action.
Simon
Some final power measurement through the oscilloscope using  7.3ohm resistors as load.
Power out both chanels driven just before clipping. 18.8v peak. 18.8 x 0.71 = 13.35V Rms
        Power = 13.3 x ( 13.35 / 7.3)   = 24.2 W both channels driven
Clipping on both channels
Power output one channel driven = 29.6 W
As a final post. There is one other mod that can be done to the power amp stage circuit of this amp called a "Baxandal diode mod". I have performed this mod to @lebone 's amplifier so I will be taking this over to his place and making a direct comparison between the 2 before deciding to do this last mod on this amp. The mod is supposed to drastically improve distortion levels. From what audio memory I have, I thought it made the bass slightly tighter and clarity across the audio band seemed to improve. A side by side comparison should be good because audio memory quickly fades especial in between performing hours of modification.
Great work!!!
That's quite some work to bring this amp back to top spec!
Beautiful looking for something that's a few decades old
Very impressive niss_man.
I am watching this Sansui on eBay. I was wondering if you could share your opinion on this model (AU-519), in terms serviceability and performance.
I have the AU-505. It’s great but would like more power for my floorstanders.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F153529751613
If this the same model I hear at the Sansui meet with more power and sound like the 555a.  It had the issue of dropping one channel I remember.
It was very good.
The 519 is a fine amp - it features the diamond differential circuit and slightly improved resolution over the 517/717, whilst maintaining that lovely Sansui sound.
The 519, like many Sansuis of that era, suffers from corrosive glue on some of the driver board and power supply capacitors which needs to be addressed. The ‘black flag’ capacitors also need to be changed.
The good news is that this amp is worthy of a restoration. If it works fine now, have a listen and then contemplate whether you intend keeping it. If so, go down the restoration route.
    • By olegau
      Item:
      Sansui AU-α607MR Integrated Amplifier Mel
      Price: 1250
      Item Condition: very good.  Recently was serviced.
      Payment Method: Pickup - Cash, Paypal +PayPal fee
      907MRX was the only amp awarded in Japan in 1995. 607DR is similar to 907DR.  The sound is the same but bit less power.
      Copper screws say a lot about the amp quality. It is built as a tank.
      Sansui AU-α607MR was sold in Japan only.  It is need 100V power supply.
      Comes with a high quality isolated 500W small size step down transformer. \
      No remote control.
      I believe that a buyer will not be disappointed.  The sound is so clear that you can hear a musician breath.  But what is most impress me is a high frequency bell sound. I have never heard in my live so nice bell sound.  I have had a lot of amps including many Sansui amps but only this one can do that.  It is just smoothly slow disappearing in air. Amazing! How Sansui could do that? My Luxman makes bells well too, but I prefer Sansui  bells. Sansui  bells sounding like inside a church whereas Luxman is outside one.
      Specifications
      Power output: 90 watts per channel into 8Ω (stereo)
      Frequency response: 0Hz to 300kHz
      Total harmonic distortion: 0.003%
      Damping factor: 150
      Input sensitivity: 0.3mV (MC), 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 70dB (MC), 88dB (MM), 110dB (line)
      Output: 150mV (line)
      Speaker load impedance: 4Ω to 16Ω
      Dimensions: 430 x 162 x 452mm
      Weight: 18kg
      Year: 1996
    • By Cafad
      Item: Sansui 607MR Integrated Amp.
      Price: $1000 (plus postage)
      Item Condition:  Fully functional but several superficial scratches to the face plate (and top plate).  So not as pretty as she could be.  See pics for details.
      Reason for selling:  So very many amps, I just can't keep them all.
      Extra Info:  Mention of it can be found here: https://www.stereo.net.au/forums/topic/127101-sansui-alpha-series-amplifier-reviews/
      But you will have to head towards the end to find mention of this amp in particular.
      More info here: https://audio-heritage.jp/SANSUI/amp/au-alpha607mr.html
      Comes as is with no manual, no remote (Sansuis from this era don't have remotes) and is a 100V model so a step down transformer will be needed.  I suggest looking here: https://www.wallcann.com.au/500w-voltage-converter/
    • By olegau
      Item: Sansui AU-α607MR Integrated Amplifier
      Price: 1250
      Item Condition: very good. BIAS was recently checked and adjusted. All Power supply cups was checked; all meets requirements.
      Reason for selling:
      Payment Method: Pickup,  COD
      Specifications
      Damping factor: 150
      Weight: 18kg
      Year: 1996
    • By surprisetech
      Item:  Sansui A-7 Integrated Amplifier and T-7 Auto-search Tuner combination.
      Price:   $120
      Item Condition:  Quite good for their age.  ID markings have been engraved on the top edges of the front panels as shown in the photos, but these are not really noticeable when installed.
      Reason for selling:  No longer required.
      Happy to post at buyer's expense.  I am very fussy with packing to make sure items arrive intact.
      Extra Info:  I happily used this combo for a few years in a second system until the Tuner auto-search drive cord broke.  By the time I got around to repairing it I'd already put a Rotel RA-970/Onkyo T-4700 combo into that system.  The tuner has since been repaired, 5 new power supply caps have been fitted to the amp, pots and switches cleaned and both items are fully functional.  (Photo of amp internals is before the caps were replaced.)
      PDF files of Tuner User Manual and both Service Manuals can be provided.
      AMP FEATURES
      Discrete class A/B amplification. Inputs for 5 sources including Phono Input. LED Output Power Level Meter. Speaker switching. Loudness control and High Filter switch. Front Panel ‘Tape 2’ input/output connections. Microphone input with input level control. AMP SPECS
      Power/Distortion:  45W/Ch into 8 Ohms @<0.05%THD
      Freq Resp:  5Hz – 60kHz +0.5/-2dB
      Hum & Noise:    PHONO 80DdB          AUX/TUNER/TAPE 95dB
      RIAA Curve deviation:  +/-0.5dB (20Hz-15kHz)
      Dimensions:  430 x 132 x 247
      Weight:  5.8kg
      TUNER FEATURES
      Motorized Auto-search feature. 5-step LED signal strength meter. 3-LED Dial Pointer Tuning Indication. Sensitive front-end and very good alternate channel selectivity. TUNER SPECS
      FM Usable Sensitivity (Mono):  0.9uV
      FM 50dB Quieting Sensitivity (Stereo):  19uV (37dBf)
      FM Alternate Channel Selectivity:  60dB
      FM S/N Ratio (Stereo):  72dB
      FM Distortion (Stereo):  <0.15%
      AM Sensitivity:  300uV/m
      Dimensions:  430 x 87 x 260
      Weight:  3.4kg
    • By surprisetech
      Price:   $150
      AMP FEATURES
      Weight:  5.8kg
      TUNER FEATURES
      Weight:  3.4kg
