Audio Connection
DALI OPTICON LCR speakers pair in black ex display condition
Item: DALI OPTICON LCR single speaker in black ex display condition
Price: $765.00
Item Condition: EX display
Reason for selling: Clearance
Payment Method: Pickup - Cash, Credit card on pick up, Direct deposit.
Extra Info: Can freight at extra cost
The OPTICON LCR – a wall-mount model that’s combines the best of all technologies into a slim wall mounted cabinet that works wonders with sound. Second to none in terms of flexibility and performance. With airy highs, a detailed mid-range and a surprising bass, this on-wall speaker delivers a larger than life performance.
PRODUCT DETAILS
Capable of operating as either an independent 2.0 system or as the centre channel in a larger set-up, the rotatable OPTICON LCR fires out its audacious audio via a 6½ inch low-loss Wood Fibre Woofer.
Added to this is our rotatable Hybrid Tweeter module and, finishing the ear-delighting effect, an advanced bass port configuration built into the back panel which uses the wall on which it is mounted to extend its acoustic properties. The result is truly astounding bass response despite a compact cabinet, without the need for an additional subwoofer in your sound set-up.
Whether you want one loudspeaker on your wall to handle all your audio needs or a centre loudspeaker to add that something extra to your surround system, the OPTICON LCR is your sound solution.
UNADJUSTEDNONRAW_thumb_2f0a.jpg.6b72cb2ef729c9f8e870e557cc786a6c.jpgUNADJUSTEDNONRAW_thumb_2f09.jpg.9fb24cbc0ee5609a1dcde06fcd911fb7.jpg
    • By mwhouston
      Item:  DIY full range single driver speakers
      Price: Price drop $520 (was $550)
      Item Condition: As new 10/10
      Reason for selling: more speaker projects to come
      Payment Method: Pickup - Cash, Paypal, COD Only, can deliver if in 40k radius.
      Extra Info: Tall, slender and deep boxes with large port at the bottom. A single full range Mark Audio 12P in the boxes designed by Mark Audio. Well braced inside and dampened with bitumanised heavy Al foil and Dacron. No Xover, none needed. In my room they go down to 40hZ and treble is clean and extended. Metal grills held on magnetically. Quite sensitive at 92db work well with low power tube amps. See link for specs below. Not overly heavy. On carpet sliders.
      http://retro-thermionic.blogspot.com/2018/08/voxuno-12p-with-markaudio-drivers.html
      https://www.madisoundspeakerstore.com/approx-8-fullrange/markaudio-alpair-12p-8-paper-cone-full-range/
      Photos: See below.
    • By JimmyDee
      Item: Wharfedale Crystal 2 - 5.1 Surround Speakers & PowerCube 12+ Subwoofer
      Price: $400
      Item Condition: Great
      Reason for selling: Surplus
      Payment Method: Pickup - Cash, Paypal, EFT
      Extra Info: Great condition
      Center - WH-1.1; 10-120W; 4-8 Ohms
      Left/Right - Crystal 2-40; 150W; 6 Ohms
      Surround - WH-1.1; 10-80W; 4-8 Ohms
      Subwoofer - Powercube 12+ ; 150W; 25-170Hz Freq Response
    • By VeritasGeorge
      Item: Altec Speakers 886B Made in USA 8 OHMS
      Price: $250
      Item Condition: 7/10
      Reason for selling: Time To Let Go
    • By VeritasGeorge
      Item: Gold Note A3XL Bookshelf Speakers
      Price: $3700
      Item Condition: 8/10 Small Dent on corner
      Reason for selling: Upgrade
    • By Audio Connection
      Item: Audio Physic Scorpio 25 Plus + floorstanding speakers in excellent condition
      Price: $4,500.
      Item Condition: Pre owned
      Extra Info: Can post at extra cost
      Here is one from Audio Physic, very elegant looking speakers that has a striking design of the cabinet. The built quality is superb and solid. The woofer chamber a high-strength, open-cell Ceramic foam with a pore proportion of more than 85% replaces the previous damping material which has more control, more precision and more deep bass, with optimised frequency dependent damping in the midrange driver chamber with higher resolution, better spatial imaging and increased homogeneity - Revised crossovers with selective measures against micro-vibrations and much higher resolution, better spatial imaging.
