Fluz Posted June 12, 2019 Share Posted June 12, 2019 Hi, I am currently attempting to do some research into remote controlled audio FX systems. The idea is for a four button remote to be kept inside of a vehicle (Firetruck as this is for a firestation) and when pressed, send a signal to a PC / Server to play an audio file. I am wondering if this can be done using some sort of bluetooth or IR dongle. When a button is pressed i would like it to speak through our PA: "Pumper BA Operator Required" or "Tanker Driver Required" depending on what button is pressed. Preferably i dont want to be putting together some soft of Rasberry Pi, rather some sort of out of the box kit with software. Mostlikely each truck (3) would have a remote (4 Buttons) sending a signal back and then the PC / Server would play the sound. Any links or suggestions is well welcomed. Thanks, Josh Australia Link to comment Share on other sites More sharing options...
