bhobba
Sotm SMS200 and Audirvana
Hi Guys
Now I have my Chord TT2 and M-sampler working properly (separate review coming shortly on that) so my final system is nearing completion. I am looking at something better than how I now connect my Mac running Audirvana to the DAC.   I use two methods,   The first is I use Audirvana to stream it to my DAC via my Oppo and SPDF, the second is a long USB cable from my MAC then into the Uptone Regen with one of Ceiseler Audio's (here after called by the owners name, Clay, for ease of use) power supplies.   The regen sounds slightly better, but I do not think either is optimum.   I decided on a Rendu of some sort but to my dismay discovered they are no longer sold in Australia (if I am wrong please let me know).   Asked some friends who all said get the SOTM SMS 200 instead which is still sold here.   Great - rang Clay and he makes a special supply for it.   All was looking up.   But just to be sure I wanted to ensure it worked with Audirvana.   Well that's where the fun started - some say it does eg:
https://www.bricasti.com/images/m5/Audirvana3_setup.pdf
Others say it does not:
https://www.audiosciencereview.com/forum/index.php?threads/measurements-and-review-of-sotm-sms-200-network-player.1846/page-4
'Airplay works via sharepoint in the supplied software package, Audirvana doesn‘t at least to my knowledge. The Sonore Streamers are supported though in Audirvana. I had an UR and still have a MR besides the Sotm - no audible difference if that is your next question :)
So if you want to continue using Audirvana - the Sonore might be your thing.'
Can anyone give me the truth about whats going on?
Bill
Edited by bhobba
Audirvana has UPnP and  should be able to discover the SMS-200 as an UPnP renderer (using MPD).
Did this question ever get answered for certain?
I would think Audirvana - UPnP - sMS-200 Neo would be a bargain proposition for a digital setup.
Sorry, I do not have any of the components to test. But this suggests it could work
https://community.audirvana.com/t/cant-connect-to-dnla-streamer/1466
