Highendlover999
FS: Robert Koda K70 G2 Power Amps and Robert Koda K10 Preamps 240v.
1 hour ago, TerryO said:
If the op is actively and repeatedly taking part in any discussion then surely it is up to him to say if conversation is warranted and or appreciated or not.
cheers Terry
Perhaps he’s obliged as he feels as it will lead to a sale through interaction, which is clearly not the case, as usual here people having a chinwag.
Neo
Neo
This is being Mod watched and we have no issues with it so far.
White Anting is not allowed. Discussion with the OP, that he supports, is.
Please back to the sale , anyone interested on my asking price for this sale please contact me .... welcome
    • By Eagleeyes
      Item Condition: EXCELLENT - Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Victoria Payment Method: Paypal, cash, EFT Reason for selling: No use -or need     Price drop   Stunning xlr cables from Entreq - Energy Transforming Systems, I have a matching Minimus block for earthing that can be used with these for sale separately. 2010 is part of the model name not the year. Also matching speaker cables 2.5 metre in seperate listing.
      1) 1x Entreq Konstantin series 1  xlr balanced cables 1 metre pair
      Specification:
      Separate cable for positive and negative signals Asymmetrical design Positive and negative cables are spun clockwise and anticlockwise respectively. Adapted lengths to minimise the antenna effect. DIC Dedicated contacts so the area on the mass of the contact areas correspond to the cable area. Wood in the contact framework. Non-magnetic and non-conductive. Only pure copper and silver in the signal paths. No alloys Drain wire instead of shielding in order to connect to a pure earth point (External Earth Drain System) Cotton covering instead of synthetic materials EEDS External Earth Drain System - This entails the shielding / drain wire not being connected to the device’s negative pole, but is connected to another external earth point. This way, the cable drains off the interference/noise that the shielding absorbs to the ground outside of the signal paths, instead of the usual mixing it together with the signal wire at the connection to the devices.
      Entreq Konstantin Serie II Infinity XLR Signal Cable
      Our original first line... and in a way the mother to all of Entreq's cables. Now upgraded to Serie II with outstanding price/performance. Konstantin was actually the first in Entreq's product line and gave birth to the principles that they had been working on for years. It's many years on now and the cable has advanced further but the truth and the heart of the design is still the same. The Konstantin is still one of the most accesable all round performing cables Entreq make.
      It doesn't matter if you use Konstantin in an entry level system or a Higher End system, Konstantin always performs very well. It will almost always let your system perform beyond the limits or restrictions of musicality that are often enforced by other cables.
      Konstantin cables have been gently updated during the years. In 2015 the Konstantin line had a total upgrade to Serie II with new developed connectors and improved design. Konstantin line got the award " Most wanted product " 2009. Relative to Discover, Konstantin will offer you more detail and better control.
      Infinity line:
      The way the cables used to drain away the noise / stay currents are designed has an signify effect on the result. Entreq believe this is due to there being such a high frequency and low voltage in the current with which Entreq deal with.  When Entreq developed the Apollo Network cable, Apollo RG 45, Entreq more or less stumble in to one of the most breaktroughing developments so far regarding earth cables and grounding. Entreq test with expose the conductors for very high pressure. When this conductors was used for signal transmission it was not a big hit. But for grounding it´s one of the biggest improvment Entreq ever came across.
      There are many theorys why Entreq get this improvment when Entreq treat the conductors with high pressure. To be honest Entreq dont know which or what it is that makes this big improvment, and frankly speaking Entreq don´t care at the moment. The important is that this is one of the biggest leap in grounding for Entreq so far.
      Another detail is the wood tube on all of the Eartha Infinity cables. Also Entreq are not sure if it´s because it reduce vibrations or radiation that Entreq notice a significant improvment with the wood tube on Eartha Infinity.     Specification:
      Separate cable for positive and negative signals Asymmetrical design Positive and negative cables are spun clockwise and anticlockwise respectively. Adapted lengths to minimise the antenna effect. DIC Dedicated contacts so the area on the mass of the contact areas correspond to the cable area. Wood in the contact framework. Non-magnetic and non-conductive. Only pure copper and silver in the signal paths. No alloys Drain wire instead of shielding in order to connect to a pure earth point (External Earth Drain System) Cotton covering instead of synthetic materials EEDS External Earth Drain System - This entails the shielding / drain wire not being connected to the device’s negative pole, but is connected to another external earth point. This way, the cable drains off the interference/noise that the shielding absorbs to the ground outside of the signal paths, instead of the usual mixing it together with the signal wire at the connection to the devices. Available Lengths: 1.1m, 1.65m, 2.2m, 2.75m, 3.3m, 3.85m, 4.4m, 4.95m
      About Entreq
      Entreq was founded 1999 and are today, a truly Swedish company, they are one of the very few companies that develop, manufacture and produce our own products. Because of this approach you will never see them immitate other brands or their technical solutions. Consequently their products are not only distinctive in their constructive materials & design but also in their connective processes. This control over each and every aspect, in conjunction with their unique philosophy and design brief, means they are able to focus purely, with no compromise, on performance.
      CURRENT MODELS 3 TIMES THE PRICE  https://www.futureshop.co.uk/entreq-konstantin-serie-ii-xlr-signal-cable
      I have matching speaker cables in other listing.
    • By Eagleeyes
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: 3 turntables New English brand made by the inventor and creator of world renowned Roksan turntables.  https://www.vertereacoustics.com/mg1    https://www.vertereacoustics.com.      2019 Demo turntable from importer. During the purchase period and timing of delivery due to CV - almost 2 months I have fallen for something else. I have genuine box and padding, note it does not come with arm cable, you have your choice to make from many brands but Vertere do offer a Redline cable for the arm and infact the tonearm has had this upgrade internally and also to the motor I was informed by the dealer. 2 types of lids are available from the dealer as well.vPrice now firm $6500 price drop
      . Scratch on external power supply lid. English Brand made by the inventor and creator of world renowned Roksan turntables.
      https://www.vertereacoustics.com/record-players
      MG-1 Magic Groove Record PlayervTaking vinyl replay beyond what’s possible in this turntable class, Record Player MG-1 MkII Magic Groove includes and shares critical design elements of the SG-1 Player.
      A superlative design, Record Player MG-1 MkII Magic Groove offers remarkable performance that’s bettered only by Vertere’s RG-1 Reference Groove and SG-1 Standard Groove. As with all Vertere turntables, every individual part is custom built, and has been created using the optimum materials and highest precision standards.
    • By Eagleeyes
      Item Condition: EXCELLENT * SEE BELOW Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: TOO MANY SPEAKERS PRICE DROP AGAIN.   Time to sell I have had enough of them sitting around. . They are seriously good for this price.   Genuine Boxes for freight so easy to send over east weight is 37 kilos each.
      https://www.lenehanaudio.com.au/speakers.html
      https://www.audiocircle.com/index.php?topic=95236.msg951583#msg951583
      *Slight colour variation on 1 woofer , Spoke To Mike Lenehan and said nothing to worry about but if you wanted a new one would be $175 from Mike, Works perfectly I am guessing initial owner had in sunlight maybe. Grills never used in wrappers still and might need magnets but in new packaging and mint condition. Again Mike will fix up if required.
    • By Eagleeyes
      Item Condition: Very good, some polishing surface scratched Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: Upgrading or not streaming
      Antipodes will do a full system software update for $100 plus $100 for return postage. You just need to send to them. You can add extras ssd hard drive too upto another 4 tb of space , or scrap the 1 tb and put in 2 x 4 tb, 8tb or whatever fits.
      They said this week
      ""The updates must be done on site as it involves a new BIOS followed by a complete system software install.
      I am assuming the DX runs the Vortexbox software at the moment based on what you said in the listing (please check this).
      The Antipodes 2 interface and software is a considerable upgrade over Vortexbox , the latest version of Squeezebox Server, and a number of other apps. You can read about it in our online guide:
      https://antipodes.audio/online-user-guide/
      The same software runs on all our servers.
      But the main reason for upgrading is that a Vortexbox server cannot have its software updated, maintained, debugged or patched. If anything goes wrong it cannot be fixed.
      We can copy the music library that is on the DX to the new software."
      Connects to an external DAC via USB. Antipodes in NZ suggested using latest operating system but former owner said he had a later unit using this and preferred the original,  so I kept it.
      A few very light scratches/scuff marks on top of the box that I have tried to show in photo. Selling as I don’t listen to a streamer enough or  via headphones much and I have several other sources for vinyl and digital in the main system.
      Reviews include Positive Feedback: https://positive-feedback.com/audio-discourse/audio-ramblings-the-antipodes-dx-music-server/ and John Atkinson in Stereophile:
      https://www.stereophile.com/content/antipodes-dx-reference-music-server
      and an interview by John Darko: https://darko.audio/2015/05/antipodes-audio-dx-music-server-review/
    • By Eagleeyes
      Item Condition:  Drivers perfect - edges of boxes scratched.  Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, cash, EFT Reason for selling: No use -or need Great heavy weight bookshelf speakers   Item Condition: Drivers perfect - edges of boxes scratched.    Sold by Clifford at Audio Synergy in Perth in early 2000's.   Axis Ls speakers I thought they were ls28 but they look slightly different - anyway hard core little but heavy well made book shelves, Axis have been Australian for years and make wonderful speakers and recently had the award winning voicebox s bookshelves which are stunning.     excellent sound perfect hardly used drivers,  though outside of boxes have a few scratches from moving around inside cupboard as surround sound speakers. etc,
      Extra Info: Great and really heavy substantial little speaker. Punches way above its size.  Awesome for small system or starter system where sound is key on a budget. Can pack to courier Aus wide.
      Photos: Advertisements without photos of the actual item will not be approved.
