Item: Dali Rubicon 6, floor standing speakers in black
Price: $3,495.
Item Condition: NEW
Reason for selling: Clearance
Payment Method: Pickup - Cash, Credit card on pick up, Direct deposit
Extra Info: Can freight at extra cost
RUBICON 6 is a floor standing loudspeaker that features two 6½ inch woofers, each sporting its own bass port, gold-plated bi-wiring terminals and our innovative ribbon/soft dome hybrid tweeter module, which also was used in the EPICON series.
The RUBICON 6 is able to deliver more physical bass to fill a larger room, especially thanks to the woofers. The two woofers work together to move much more air, delivering more powerful bass and pumping out audio excellence that fills the room. The driver construction of the RUBICON 6 makes it even more powerful than its smaller siblings with enhanced and controlled performance.
Edited by Audio Connection
Item: Dali Rubicon 8, floor standing speakers
Price: $4,500
Item Condition: NEW
The floor-standing flagship of the RUBICON series, the RUBICON 8, will provide you with a mind blowing large soundstage and an impressive deep, physical bass. Inherited from the EPICON series, the RUBICON series utilizes the same SMC technology and soft dome diaphragm. The RUBICON 8 has no less than three drivers that all kick in at different frequencies. This setup ads up to what in effect is a 2½+½+½-way construction, and generates an amazing range and impressive sound pressure. The RUBICON 8 is for those seeking the extraordinary in size and sound.
Upping the audio ante to the extreme, the RUBICON 8 is quite simply stunning in terms of the epic soundstage it presents. The trio of woofers works by kicking in at different frequencies, making the RUBICON 8 loudspeaker, the pinnacle of your entry into the world of high-end audio at a mid-range price.
Delivering a totally transparent image with a richness of detail that recreates the passion of a live performance, the wider sound dispersion afforded by our hybrid tweeter helps the RUBICON 8 fill even the most sizeable of spaces with the purest audio your ears will ever witness.
Item: DALI RUBICON 2 bookshelf speakers in gloss black
Price: $2,095.
Item Condition: NEW
The RUBICON 2 stand speaker is the perfect blend between compact size and large sound performance. With the solid MDF cabinet, the RUBICON 2 has a perfect working environment for its ultra-light 29 mm soft dome tweeter, 6.5 inch wood fibre low-loss driver, and gold-plated terminals. It is rich on detail with an impressive soundstage and has surprisingly large bass reproduction with both precision and timing.rubicon-2-black-interior-2.thumb.jpg.1519bc2453074d11419530208fe81141.jpgimg121679_5798_3.jpg.5a45dba5d8f4abff2de03e25a7d50c63.jpg
The RUBICON series builds on a well-known design language and takes it to new heights. The RUBICON 2 stand loudspeaker is the perfect blend between compact size and large sound performance. With the solid MDF cabinet, the RUBICON 2 has a perfect working environment for its ultra-light 29 mm soft dome tweeter, 6.5-inch wood fibre low-loss driver, and gold-plated terminals. It is rich on detail with an impressive soundstage and has surprisingly large bass reproduction with both precision and timing.
Item: DALI RUBICON LCR speakers in black
Price: $1,790.00
Item Condition: NEW
Payment Method: Pickup - Cash, Credit Card on pick up, Direct deposit
The wall-mounted RUBICON LCR is simply born to stand out in both sound performance and design with the hybrid tweeter module and the wood fibre low-loss driver. The compact RUBICON LCR delivers a wide dynamic range, a coherent sound with lots of details all together with a bass response that’s unrivaled in its class. The rotatable hybrid tweeter module makes it possible to use the RUBICON LCR as either the left or right channel, or as a centre speaker. The 6½ inch woofer uses the ingeniously designed bass port to reach maximum bass depth. With the RUBICON LCR, we promise you a sound performance that will dazzle you and leave you with goosebumps.
Item: DALI RUBICON VOKAL centre speaker in walnut
Price: $1,695.00
Item Condition: NEW
The RUBICON VOKAL is the centre speaker to complete a RUBICON surround setup. With two 6½” woofers and a hybrid tweeter, the RUBICON VOKAL has the size and punch to match any speaker in the RUBICON line-up. Whether you are watching a movie or listening to music, the RUBICON VOKAL will bring clarity and detail. RUBICON VOKAL is the ultimate centre loudspeaker. Striking an elegant balance between size and performance, the RUBICON VOKAL is powerful enough to match the RUBICON 8, and still compact enough to fit in most living rooms. The two 6½” low-loss wood fibre woofers deliver a clear and well-defined mid-range together with the hybrid tweeter module. It also uses the same soft dome diaphragm and many of the same SMC technologies as used in the EPICON series. The cabinet size helps the RUBICON VOKAL reproduce even the lowest bass frequencies from the gripping action on the screen or stunning musical performances.
    • By RLDK
      Item: Schitt Modi Multibit
      Price: 250 ono
      Item Condition: As new
      Reason for selling: NLR
      Light use. No longer required.
      No blemishes.
      Can ship if required.
      No original box available.
    • By RLDK
      Item: Schitt Mani phono stage
      Price: 200 ono
      Item Condition: as new
      Reason for selling: nlr
      Very light use, less than 10 hours. Wasn't a vinyl fan in the end.
      No blemishes.
    • By dbastin
      Item: Audience Au24SE USB & AES - 75cm ea
      Price: $700 each
      Item Condition: Very good
      Reason for selling: Not in use, need money
      Some of the very finest around.
      "Frankly, there’s nothing to fault ...  The Audience cable seemingly does it all; it is convincingly superior in every sonic criterion ...  if you want a no-compromise USB cable, look no further."
      http://audience-av.com/cables/au24se/
      http://audience-av.com/au24-se-cable-reviews/
      For context, the Au24se USB is virtually 2nd best Audience USB, after FrontRow (no SX model).
      The AES also comes in SX and FrontRow at US$1200 and US$1700 respectively.
    • By longgo
      Item: Yamaha CX-A5100 & MX-A5000
      Price: $4500 for both.   Price Drop --> $4000 for both.  (CX-A5100 RRP $3999. MX-A5000 RRP $3599)
      Item Condition: NEW
      Extra Info: Bought the Yamaha CX-A5100 awhile ago, and received the MX-A5000 from friends as gift to pair it up. But never had any chance to set it up.
      MX-A5000 was purchased as refurbished unit from Excel HiFi and it is in new condition.
      Both unit never been open.
      As these amplifier are very heavy, Pick Up is prefer at this stage.
      Also, i have 13 x 1 m custom made XLR cable to go with this set up if you are interested.
      It's Transparent Musiclink Plus with Furutech FP-601M & FP-602F gold head.
      Each of the Furutech  XLR head cost $105 & $115 each !!
      13 cables cost me around $4000, Asking $2500
    • By ssb102
      Item: 4x Fanless ROON ROCK Servers
      Price: Varies, see below
      Item Condition: Excellent
      Reason for selling: Surplus!
      It's 2020 and it's high time i cleared my backlog of projects.
      I have FIVE Fanless Roon Rock Boxes for sale.
      All totally silent with SSDs running the latest version of ROON ROCK
      Small enough to fit on a bookshelf and use far less power than a full PC or laptop so you can really leave them running.
      Your wife/girlfriend/dog/cat wont even notice.
      3x WYSE Zx0
      (2 Units) 8GB + Ethernet + Wifi $120 ea
      (1  Unit) 16GB + Ethernet + Wifi $150 ea
      (1 Unit left! ) 8GB + Ethernet + Wifi $120 ea
      1x Dell Optiplex FX160 with 32GB SSD
      $200 $150 PRICE DROP
      Intel Atom platform
      Gigabit Ethernet  (via USB 3.0 adapter, FREE)
      Wifi optional extra
      ALL BOOT INSTANTLY AND WORK FLAWLESSLY.
      These SSD sizes are more than adequate to hold the ROON database because with ROON your music is stored elsewhere.
      Priced fairly these are an excellent way to get started with ROON.
      Reasonable offers considered. Discounts for multiple purchases or pickup.
      Lowballers and timewasters will be sent a copy of the Betoota Advocate.
      ARSE mug not included.
      Shipping available just DM me for a quote.
