getdisdude
SOLD: FS: REL T5 Subwoofer - [MEL]
Item: REL T5 Subwoofer system
Price: 475 - Sale pending.
Item Condition: EUC
Reason for selling: NLR
Extra Info: Needs no introduction, gels with pretty much anything. Never had an issue. Pick up only as i don't have the original packaging etc,
Edited by getdisdude
    • By Keith Raufer
      Item: 18” Subwoofers, Dayton UM18, Sealed Black Oak Enclosures.
      Price: $1400 each
      Item Condition: 6 months old
      Reason for selling: Need Room
      Extra Info: I have 2 Dayton Ultimax UM18 Subwoofers, (subs only, no amp). Finished in a custom 4 cubic feet enclosure, made from 25mm MDF and very heavily braced. The Subs weigh in at just over 50kg each and are wrapped in a black oak veneer. Connections are speakon for simple secure connections.
    • By olegau
      Item: Infinity Primus PS-8 Subwoofer
      Price: 180 ono
      Item Condition: good
      Reason for selling: upgraded to bigger one
      Great sound and, besides a small dent in the speaker cone, great condition.
      Infinity PS-8 Subwoofer
      Features and Specs
      Enclosure  Bass Reflex
      Video Shielded   No
      Woofer Size (inches)   8
      Woofer Composition   M.M.D.
      Firing Direction   Front
      Wireless    No
      Preamp-Level Inputs   3
      Speaker-Level Inputs  Yes
      Speaker-Level Outputs        No
      Low-Pass Crossover Freq   50-150 Hz
      High-Pass Crossover Freq  None
      Phase Switch     Yes
      Amplifier Output (watts)        100
      Frequency Response 35-150 Hz
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
      Metal Matrix Diaphragm (M.M.D.): Derived from the C.M.M.D. material used in Infinity's flagship Prelude drivers, M.M.D. features a stiff aluminum core that provides exceptional strength and rigidity for clean, realistic low-frequency tones.
      Amplifier: The 8" M.M.D. front-firing cone woofer is powered by a 100-watt (RMS) amplifier.
      Surround: For a smoother response and improved durability, the woofer uses a rubber surround.
      Bass Ports: There are two rear-firing bass ports that allow deep bass with high acoustic efficiency and low distortion.
      Gain Control: The subwoofer has a rotary control on the rear panel for adjusting the level of the bass.
      Phase Switch: The subwoofer's phase switch allows you to control the phase of the subwoofer's output relative to the front speakers. If the bass sounds muddy or unclear, toggling the phase control can sometimes strengthen the bass "attack."
      Auto On/Off Circuit: The auto on/off circuit turns the power amp on when a signal is sensed and turns the amplifier off and into standby mode approximately 10 minutes after a signal is no longer received. An LED indicator on the rear panel glows green when the amplifier is on and red when the amp is in standby.
      Low-Pass Crossover: The subwoofer features a continuously variable 50Hz-150Hz low-pass crossover that determines the highest frequency at which the subwoofer reproduces sounds. The crossover has a 24dB/octave slope.
      Inputs and Outputs Notes
      Line-level Inputs: The subwoofer has a gold-plated LFE input and gold-plated stereo RCA inputs. If you have a Dolby Digital/DTS receiver or processor with a low-frequency-effects (LFE) output, you should use the LFE input on the subwoofer. If your receiver/processor does not contain a Dolby Digital or DTS processor but has a subwoofer output, you must use the stereo RCA inputs. If the receiver/processor has a mono subwoofer output, a "Y" adapter is recommended to maximize performance.
      Speaker-level Inputs: The left and right gold-plated 5-way binding posts allow you to connect the subwoofer to a receiver/amplifier using speaker wire.
    • By olegau
      Price: 180
      Item Condition: good working order
      Features and Specs
      Video Shielded   No
      Wireless    No
      Phase Switch     Yes
      DIMENSIONS & WEIGHT
      Width 10.6 in
      Depth 16.8 in
      Height 17.5 in
      Weight 33.07 lbs
      Features
    • By Neilsy
      Item:  Velodyne Digital Drive 18 Subwoofer -- Black
      Price: $2,500 PayPal / $2,350 BT/Cash/cleared
      Item Condition: Excellent
      Reason for selling:   No longer in use, taking up floor space.
      Extra Info:    Selling my gloss black Velodyne DD18. Excellent condition as stated, everything working per new and includes remote, manual, the accessories kit and everything in it. Wear and tear on the mic clip which is normal. Comes packed in original Velodyne packaging and box.
      PM if interested in multiple units, per last picture.
    • By BIG DWIFTER
      Item: Behringer NEKKST K10S
      Price: $350
      Item Condition: Perfect
      Reason for selling: Upgrade
      Extra Info: Very solid subwoofer used sparingly with Yamaha HS8. Only selling due to a sidegrade.
      Perfect condition in every way. Never taken past 12 o'clock on the gain.
      Box and all accessories included. I still have the outer Behringer shipping box too.
      Pickup only as it's very heavy.
