Ardent music lover and hard core diyer of speakers and amps.
I currently run a frankenspeaker of my own creation.
JBL beryllium compression driver with the M2 waveguide
Acoustic Elegance TD15M with apollo 15" mid in open baffle for mids
Acoustic Elegance SBP15 in sealed for bass
Everything is powered by class D amps and the trinnov magnitude dsp processor.
Source is the Schiit Freya & Gungnir balanced dac/pre
Welcome Chris
Look forward to your franken speaker pictures!
Was just in Singapore a few weeks ago. Stay out of the Adelphi at all costs!
You got some good people in your shops up there. Good to see the scene is alive and well.
welcome Chris. Your system sounds very interesting. Please tell us more about it when you have the chance
Found an old picture, thats when there was 1 bass woofer and the mid was in a sealed cabinet.
The wooden baffle is now standalone with the TD15M mids.
The white cabinet now holds 2 SBP15 bass woofers each.  Im not getting the bass right for these when ported so i just seal them for now.
Amps have also been upgraded to Anaview class D amps.
The Trinnov ensures its minimum phase ~500hz through to 20khz and fixes any room issues below 150hz in IIR.  I listen a flat line eq curve that is a slope ~9 or 12db down @ 20khz compared to 20hz.
As for the sound, im assuming due to the accurate phase and very good constant directivity courtesy of the M2 waveguides, every instrument is right sized.   The beryllium compression driver gives highs that are beyond words.  With no colouration of its own, it is whatever the music is.  In furious drum solos in jazz recordings you can hear quite clearly each stroke on the cymbals and their multitude of nuances.  What you thought was a revelation on home audio ~30mm beryllium tweeters sounds more open, at ease and even more detailed on the compression drivers.  Normally I detect a difference in fidelity (measurable differences distortion levels in REW) between the BE tweeter and whichever midwoofer but thankfully the JBL BE & TD15M both measure equally (and amazingly) low at ~-70db from signal so its impossible (at least for me) to hear when the mid hand off to the compression driver and vice versa.
Being active and corrected to a flat response means every instrument is tonally spot on   Also, im not sure why but only once in a while you can hear and feel the tempo of the music, in particular, Dali CD 4's Pirates of the Carribean OST.  There is a effect of the music jumping out at you with each crescendo.
You can (and we did) listened to all sorts of genres of music from metal to pop on youtube for hours on end without fatigue and the music is generally quite enjoyable.   I could acoustically locate the deliberate imaging of the 5 musicians front of me in a dreamtheater track friend chose.
Another superpower of the system is that you can hear very clearly and enjoy music at very very low levels.  Much lower than my other home stereos.
In short, no regrets building this multi part monster that uses so much parts & cables. Back they were a 2 way with the TD15M, I felt they perform better and is more dynamic than very well tuned Von Schweikert VR11s I was fortunate enough to experience in the MLP playing alot of rock LOUD.
It has drawbacks, whilst I am getting this effortless bass, it lacks the chest thumping punch.  Any low bass material is off very high fidelity but it just lacks the punch in the nads and thump in the chest.
I believe its due to one or all of the 3 things.
  1. The chest thumping i want is unnatural and is tuned in home hifi as deliberate colouration
  2. The bass drivers simply could not be driven hard enough in the home environment to deliver the harmonics to give some punch.  Adding a few db across 40-160hz in various bandwidths, up to 6db in various configuration did not help at all.
  3. The space, a 700sqft concrete open plan living room did not have a fixed air volume for the speakers to couple to.
Currently in pieces whilst i move it from the living room to the study room.  More pics when its back up in its new form that includes a workable solution for the midbass heft that i want.
Edited by fishball79
fix typos
Welcome Chris.
Looking forward to hearing more about your speakers and systems.
Dude, you live in Singapore and you have a system as big as that?
You'll be getting complaints from Malaysia, let alone your neighbours.
Love it!
