xchewyrep
Downsizing my home theatre setup
I'm going to be moving from a dedicated home theatre room to an apartment so I need to sell my Richter Harlequin floor standing speakers and unicorn centre for a mini system or book self speakers.  Unfortunately the apartment is still  under construction  and can't get access for any pre wiring.  Any recommendations for a decent  speakers.  I have a Yamaha RX A1050 receiver.
Kef LS 50 W. Very popular at the moment.
I really like those speakers.  Heard them at Clef Audio and very impressed.  Aren't they more for just music though.  How could I use a centre speaker with these as they are wireless.
A friend has the Kefs setup in an apartment and he loves them.
Just had a listen to Kef R3 bookshelf speakers.  These are a contender.
could use a set of these all around including for centre speaker :) just check though you can buy them as singles...not always easy with speakers :D
That would be one very expensive way of doing things.
Good choice, and not too crazily priced either.
Or for a cheaper solution, look for the Usher 520. The LS 50 is nice.
The Monitor Audio brand also carries something similar at a much lower price point, with a bright colored woofer..
what did you end up using pete ? as think you ended up going this ways too ? might help the OP :)
I know, but sometimes when you downsize a good ways to get some quality back in there is using it all around :) gotta make for what you loose some how ....
Focal Dome 5.1 system is one way of getting the quality in an apartment situation, for anyone who wants high-end performance but cherishes their floor space, this system in laymen terms is 'the ducks nuts'
Just my 2c of wisdom.
focal has always done nice job with the domes.... first decent 5.1 setup I heard was with theirs their little sub even was pretty good quality. B&W do similar wiht the mt2 but not heard in action really to comment :)
I'm using the 520 for the side surrounds.
I used Kefs before, nice but the treble was a bit hot..
560205439ad30.jpgThey look very cool, wife friendly.
Thanks I will check them out.
