I took some measurements and it looks as though I will fit the rear surrounds between the panels and posters if I push the panels togethers and move the posters very close to the corner.
The rear surrounds will be within Dolby spec at about 144 degrees.
It will be a pretty tight fit but think it should work ok.IMG_20190624_180531376.thumb.jpg.932b93daa8cef2ba0966396567c05a21.jpg
Edited by Mr_Gadget
