Hi, I've been struggling to come up with the best solution to my speaker location position.
Due to room constraints I can't realistically put surround speakers to the side of listening position and in walls are not likely to happen either.
Is it a crime to have the side surrounds further back angled to couch (see photos). In theory it should be better than using my in ceilings ( these can be setup as Atmos top middle in future).
I was going to use these as surround backs but may forgo this if I can't put side surrounds on the side of couch and just end up with a 5.1.2 setup.
Edited by Mr_Gadget
personally I dont really understand what is the bother of having them(side surrounds) wall mounted just back of the back to future posted in the first photo ? I wouldjust use some bi-poles there. so not firing right in your ears
the speakers you have floor mounted I would just utilise as rear speakers there in rear location  in a classic 7.1 orientation.
https://blog.dolby.com/upgrade-home-theater-system-dolby-atmos/
the in ceilings I'd re allocate for atmos heights :)
The problem is the right surround would constantly get knocked when walking past the couch. I don't want to keep removing them off the wall when not in use.
I dont know what you rest of your surrounds are but you could even consider the krix dynamic on wall.
https://www.selby.com.au/krix-dynamix-on-wall-main-speaker.html
https://www.krix.com.au/dynamix-mk3/
there quite narrow at 245mm wide so won't be imposing too much visualy on the space.
I wouldn't put them super high up. say 300-600mm above head height would still give enough height differential for any in ceiling atmos heights
just dont put them on ear level. slightly above is just fine atmos will still work fine... eg above shoulder level then wont brush pass !
as long as enough of a differential ... it will be fine... I imagine you have at least 600-900 mm to walk past on the right side ?
3 minutes ago, betty boop said:
just dont put them on ear level. slightly above is just fine atmos will still work fine... eg shoulder level then wont brush pass !
Just under 600
Just now, Mr_Gadget said:
Just under 600
thats enough.... i would suggest if you go above shoulder level with something :) dont forget something like the krix wall mounts point down as it is :) narrow at the bottom and widens up above....
keep it so not next to couch but like on the other side along the back side edge... will be fine...
I have right side surround on a pillar about 640mm from side of couch and above shoulder level and works well with heights I have :)
I had similar issues when I did my recent room build and used the Krix Dynamix betty suggested above - see here for photos.
with the krix having the inverted arrangement with tweeter below also helps for the differential for heights.... every little bit helps :D
Problem with left surround location is that I run out of wall :)
rubbish !  :Pjust move the pictures aside to right a tad. the surround is only 245m wide ! even the gap between the picture and upright as it is looks wide enough !
where there is a will there is a way. if you dont want to do it you'll find 101 reasons why not :D
No I meant if I wanted the right surround to be a little bit behind the couch to give a bit more passing space then the left surround wouldn't be in line with right surround
not sure if did have a look at the dolby recommendation I posted earlier ? . :)
it says 90 degree which is directly side on to as far back as 110 deg looking at the shots of your right and left I cant see to be honest what the bother is ... unless you are creating problems for your self :P ... ie more reasons not to :D
I would quite simply plonk the one on the left and match the one on the right to suit :) even if directly bang on the couch you will be fine just lift height enough to be above shoulder as mentioned before. my surrounds are either side of couch at 90 deg and work fine.
Your room looks great. How high from the floor is the bottom of the Krix Dynamix ?  Looks like your ceilings are decent height, mines just standard 2.4m.
They're ~189cm from the floor - ceiling is 2.7m.
