sloper Posted May 11, 2019 Share Posted May 11, 2019 Goodaye all l have noticed a distortion on a Aux channel but not on the tuner channel. No componets between the input and selector switch on either. What l want to do is rewire the AUX inputs to the selector switch but are unsure on a suitable wire. Something shielded??? Its in my Sansui A70. regards Bruce Link to comment Share on other sites More sharing options...
audiofeline Posted May 11, 2019 Share Posted May 11, 2019 Why not plug the component currently used on your Aux input into the Tuner input? It should work OK. Link to comment Share on other sites More sharing options...
sloper Posted May 11, 2019 Author Share Posted May 11, 2019 Thats what l have done, but it needs to be fixed. l like everything to work as it should. Proberly put in new sockets while l am at it, it is over 50 years old, Think this wire should be ok?????? https://www.jaycar.com.au/single-screened-audio-cable-sold-per-metre/p/WB1500 regards Bruce Link to comment Share on other sites More sharing options...
Guest Muon N' Posted May 11, 2019 Share Posted May 11, 2019 (edited) Go for some Van Damme coax, Geoff at Aurealis Audio might be able to sell you some. Edid: like this one http://www.van-damme.com/vandamme_product/van-damme-pro-grade-classic-xke-pro-patch-cable/ Nice quality, and you have two conductors one for hot and one for return, and a dedicated screen that you can connect at only the low impedance end. Edited May 11, 2019 by Muon N' Link to comment Share on other sites More sharing options...
