LWA Staff
Bowers & Wilkins ASW 500 Subwoofer
Item: Bowers & Wilkins ASW500 Subwoofer
Location: Len Wallis Audio HQ, 64 Burns Bay Road, Lane Cove
Price: Was $350 StereoNET Special $250
Item Condition: Very good secondhand condition
Payment Method: Credit Card, Cash, Paypal, COD Only
Shipping: Anywhere in the known universe, POA
Extra Info: Superb value 10" active sub with 70watts of power perfect for small to medium sized rooms
    • By wolfz
      Item: Corda Classic Headphone Amp
      Price: $ 380
      Item Condition: used / excellent
      Reason for selling: using all in one amp/dac
       A few tiny marks (edge), not easy to see, no original box. Normal retail price new is $800.
      A very good neutral sounding amp with two crossfeed stages and two gain settings and two times line in.
      Tech Data copied from Meyer:
      Sure, from the outside the CLASSIC looks very modest and plain. However, technically and sonically this is the best and most advanced amplifier that we've ever build.
      Of course this amplifier also uses the concept of active balanced headphone ground. Within this concept each headphone connection wire carries an additional signal such that the sum of the potentials of the wires equals zero. This strongly minimizes the energies stored and released in the electrical fields inside the headphone cable when an audio-signal is applied. The influence of the wire on the sound is thus reduced.
      Moreover, with active ground pollution of the internal signal ground by strong driving currents is eliminated and the power-supply-rejection-ratio at the output stages is strongly improved. Thus the best conditions are given for a clean and undistorted sound.
      Active balanced headphone ground offers most of the advantages of a true balanced headphone setup without the need of balanced connections. It can be used with any conventional dynamic or magneplanar headphone.
      The volume control is technically very sophisticated. The position of the potentiometer is measured with the use of an AD-converter. The output of this converter is then used to switch a bank of relais to set the proper volume level. There are a total of 64 levels which allows for very small stepsizes and a very analog feeling. The advantages of this concept are strongly reduced channel-imbalances and a much cleaner and more detailed sound. The use of a conventional stereo-potentiometer does add its own sonic signature which is now prevented.
      The amplification section is build around AD797 opamps biased into class-A. For the output stages BUF634 buffer amplifiers are used. These integrated circuits are very fast and thus allows the output signals to follow the input signals very closely. The amp is DC-coupled and any capacitors found in the signal path are of the highest quality polypropylen and polystyrol.
      A very extensive powersupply, a large number of power-regulators, and a total filter capacity of 80.000 microF (!!) assure the best working conditions for any part of the circuitry.
      The built-in crossfeed filter is a frequency-extended version of the natural crossfeed found in previous CORDA amplifiers and provides even better imaging. It also offers three intensity levels (Stereo, medium, high). To compensate for the psycho-acoustic bass-loss a separate switch allows to slightly increase lower-frequencies.
      Technically the CLASSIC is an extremely advanced headphone amplifier and offers excellent value-for-money!
    • By wolfz
      Item: Burson Playmate (Basic)
      Price:  $400  (recom. retail $600 ).
      Item Condition: excellent, near new
      Reason for selling: not the ideal combination with my speakers
      Extra Info: Playmate:   dac / pre amp / headphone amp.
      Bought a few month ago from Burson Australia.  Comes with all original packaging , cables etc. & power supply,
      Proof of purchase.      Amp sold.
      For tech details please see: https://www.bursonaudio.com/products/playmate/
    • By Audio Connection
      Item: Musical Fidelity M6 DAC
      Price: 1,800.00
      Item Condition: Excellent
      Reason for selling: Clearance
      Payment Method: Pickup - Cash, Credit card on pick up. Direct deposit
      Extra Info: Can freight at extra cost
      The M6 DAC offers simply outstanding performance using the very latest, cutting edge conversion technology. Its flexible input connections allow any music lover to experience a level of emotion and detail in their music that is, so often, unrecoverable.
      Alongside the traditional AES and SPDIF connections (XLR and Coax/Optical respectively), the M6 features an asynchronous USB input connection suitable for a wide array of computer sources. In addition, the Bluetooth receiver allows many portable music devices to connect and play music too.
      Comes with remote control and manual
    • By Famo
      Item: Monitor Audio Subwoofer Repair Or Parts
      Price: $35
      Item Condition:Monitor Audio Sub needs plate amp repaired or replaced. Otherwise in very good condition
      Reason for selling:
    • By Famo
      Item: Transmission line cabinets 8-inch 2-way
      Price: $25
      Reason for selling: NLR
      Extra Info: 8-inch 2-way Transmission line cabinets. Very Solid. About 1-metre tall
