Woody982 Posted May 6, 2019 Share Posted May 6, 2019 Hi all, my order was royally stuffed up... I ordered 2 pairs of BLACK Dali Zensor 7's, and recieved one pair black and one pair walnut, and to top that off, I was sent two right black speakers.... So I'm just wondering if it actually matters if you have two right speakers connected in a left and right channel on the amp? I can't find anything about it online, but I'm guessing that it wouldn't really matter?? Thanks guys Link to comment Share on other sites More sharing options...
proftournesol Posted May 6, 2019 Share Posted May 6, 2019 Your music will sound... right 1 1 Link to comment Share on other sites More sharing options...
AudioGeek Posted May 6, 2019 Share Posted May 6, 2019 Where did you order from? Sounds like they just sent whatever was left out the back.... Link to comment Share on other sites More sharing options...
Woody982 Posted May 6, 2019 Author Share Posted May 6, 2019 Just now, AudioGeek said: Where did you order from? Sounds like they just sent whatever was left out the back.... I ordered from Grays online through ebay Link to comment Share on other sites More sharing options...
Administrator Marc Posted May 6, 2019 Administrator Share Posted May 6, 2019 Do Grays Online do anything right? In this case, I guess they did it very right! 1 Link to comment Share on other sites More sharing options...
Woody982 Posted May 6, 2019 Author Share Posted May 6, 2019 Just now, Marc said: Do Grays Online do anything right? In this case, I guess they did it very right! I'd laugh if I wasn't so pissed off haha 1 Link to comment Share on other sites More sharing options...
Ittaku Posted May 6, 2019 Share Posted May 6, 2019 Asymmetrical speakers have a left and right, but ones that are symmetrical have no left and right and can be used interchangeably. That said, if you are describing them as two right speakers, that means there is a difference between the left and right speakers (likely in terms of symmetry and which side of the baffle the drivers are offset) so it will make a difference. Link to comment Share on other sites More sharing options...
Woody982 Posted May 6, 2019 Author Share Posted May 6, 2019 Is there an easy way to determine wether they are actually symmetrical or asymmetrical? Or would it just be a subtle difference Link to comment Share on other sites More sharing options...
rocky500 Posted May 6, 2019 Share Posted May 6, 2019 (edited) You will be fine. As ittaku mentions, its only when you have speakers with offset drivers/tweeters like this one Edited May 6, 2019 by rocky500 1 Link to comment Share on other sites More sharing options...
Woody982 Posted May 6, 2019 Author Share Posted May 6, 2019 Oh, yeah think they are both in the same spot (in the middle) 1 Link to comment Share on other sites More sharing options...
