AlurkA
How does one compare Class A power ratings with A/B
Andy,
Yes you are 100% right the version at DiyAudio is a 20 watt amp and there is a 50 watt version also.
I have built the 20 watt version and is a wonderfull sounding amp easy to build, no adjustments, and NO Unobtainium parts.
If i  remember correctly there is a 35 watt version using a higher rail voltage with different out put devices that was mentioned in the thread.
Hugh talks about the AKSA commercial version in post #3155 DiyAudio thread.
Steve.
my unison research s6 valve jobbie though rated at 30-35 w class A pulls in the order of 270-300w :)
not checked how hot gets.... ive always been of believe they pull constant power... any watts not used in music is shed as heat....
Seems about right.   For ~35w output....  with each channel pulls about 4x that power from the wall = 280w
