Glenny
Ondine whatmough monitors
Well it seems Speakerbits has now gone. My suggestion is now trying Attila.
I have been talking to Tom from Speakerbits in Port Melbourne, if that's the people.
were are Attila based?
Thats good news, each time I have gone past speakerbits it has been closed,. the last time it looked as if they were packing up.
Attila is in Thomastown
On ‎4‎/‎05‎/‎2019 at 8:46 PM, betty boop said:
we do realise the ondine was produced by colin what tough in 1984 ! that was 35 years ago ! infact his 2nd only speaker produced to the 201 202 headlined in 1980 thats how far back these go. I am not suprised quite frankly there is not much on these even from whatmough. or driver available this is long time gone. I would take back to likes of speaker bits and tis going to come down to best can do with whats currently available I would suggest.... just as what was done back in 2011 when it visited speaker bits back then....
yes, but know what woofers where originally used. Dynaudio?
that was my point...so long ago who knows....best take to someone as suggested...
http://www.stereo.net.au/forums/topic/250086-withdrawn-or-relisted-fs-whatmough-audio-ondine-monitors/                                The photos clearly shoe the one piece polypropylene cone with the 100mm dome cap  and the 12 locating ridges for the voice coil, of the Dynaudio 24W100 bass speaker.
I can remember working on a pair of Ondine  speakers that had issues with the speakers and the crossover networks, many years ago and all the drivers  used were Dynaudio models.
Must we go around in circles on the identification ?  Glenn will need to find replacement drivers that are close to  the main specifications of the 24W100 and hopefully that fit  the  existing cutout of the cabinet with little or no alteration needed. If he is not happy with the end result, the crossover network could be in need of reworking.
Edited by VanArn
Hi Van
I have actually found a supplier Busi soft which are a supplier of Dynaudio items.
but only problem is they only do replacement of old for new which in this case I don't have the originals because they have been placed with a different woofers, which I am still working on.
Either way Van, I have appreciate your help very much, I wouldn't not got to this point if it wasn't for your knowledge and your in put.
Thanks again.
On ‎18‎/‎04‎/‎2019 at 4:46 PM, houdinifangs said:
@Glenny
yep 😁
hi Houdinifangs
its me again, I have just realised that there is more than one type of Ondines .
would it be to much trouble to ask, can you please take photo of the drivers front view of your Ondines. this much appreciated
Actually, don't bother just realised I can see through the cloth.
Mine are different to yours, how many connection do have at the back? mine just have two, and have ribbon midrange and tweeters. I will post photo of them.
Glenn
Edited by Glenny
I have attached some photos of my Ondines which you can clearly see mine are different to others that have been posted
Anyone that recognises this model, some feed back would be appreciated. Also they are twin voice coils
Glenn
Edited by Glenny
 Glenn, your new pictures reveal an entirely different model to the ones in my experience. The woofer is a Focal 5N402-DB (13cm d ) ; the  tweeter with the Kevlar diaphragm is a Focal model T 120  and the  leaf tweeter could be from  a number of sources.  They all appear to be original for  this oddball assembly and I can appreciate your concern about establishing  the  identification of the speakers used. Replacement 5'' bass speakers of a different make are readily available and you will need to have the Focal tweeter fitted with new surrounds as they suffer from foam rot.
Edited by VanArn
Corrections
4 minutes ago, VanArn said:
 Glenn, your new pictures reveal an entirely different model to the ones in my experience. The woofer is most likely an Audax 13cm; the  tweeter with the Kevlar diaphragm is a Focal model  and the  leaf tweeter could be from  a number of sources.  They all appear to be original for  this oddball assembly and I can appreciate your concern about establishing  the  identification of the speakers used. Replacement 5'' bass speakers of a different make are readily available and you will need to have the Focal tweeter fitted with new surrounds as they suffer from foam rot.
Thanks VanArn
I should of sent these photos at the start, I didn't actually realise until recent that they were different.
thanks heaps, might get somewhere now
Well the StereoNet world  certainly now knows a bit more about the Ondine series and the variations. Note:- I originally assumed that the 5'' speaker was an Audax, but it is a Focal model that used  shared  parts.  I presume the voice coils of the 5'' unit have been wired in series.
do you mean twin voice coils
The twin coils could be wired in parallel for an 8 ohm nominal impedance or in series for  a 16 ohm impedance. There was an arrangement devised by  Focal to implement a form of crossover cct. to cut one coil off earlier to improve the midrange response and this would require a minimum of three  separate leads going  to the terminals.
Thanks Van
