gazza80 Posted May 2, 2019 Share Posted May 2, 2019 Hi, I recently bought a LG 4K B8 Oled TV and already had a Sonos play base. The remote for the LG TV does not seem to interact with the Sonos so I am left having to adjust sound through my phone which is not ideal. Is there a way around this. I believe I might need an infrared remote. Can anyone recommend. Thanks Link to comment Share on other sites More sharing options...
Guest thathifiguy Posted May 2, 2019 Share Posted May 2, 2019 1 hour ago, gazza80 said: Hi, I recently bought a LG 4K B8 Oled TV and already had a Sonos play base. The remote for the LG TV does not seem to interact with the Sonos so I am left having to adjust sound through my phone which is not ideal. Is there a way around this. I believe I might need an infrared remote. Can anyone recommend. Thanks If the LG TV uses an RF remote (becoming increasingly more popular) then it won't work. Link to comment Share on other sites More sharing options...
Jason_695 Posted May 3, 2019 Share Posted May 3, 2019 Hi. Best to make a quick call to Sonos Support on 1800 680 234 or (03) 9874 0800 - they are an excellent team and always very helpful. A bit hard to explain in writing here but I will try as Sonos App on your phone has a way of linking to your TV remote to adjust volume. Begin by turning on your TV setup (incl attached Sonos); it needs a couple of mins to get itself organised. In Sonos App in lower RH corner select [More] then select [Settings] from the long list and [Room Settings] from the even longer list. Select your TV room name and touch it to reveal a menu of setup controls in which scroll down to the last section which is 'TV and Remote'. Selecting [Remote] there is a menu item for [Remote Control Setup and you just follow the simple instructions. For what it is worth in my setup the 3 radio buttons are enabled (but this was likely the default as I doubt I touched them). Hope this helps. 1 Link to comment Share on other sites More sharing options...
Jason_695 Posted May 4, 2019 Share Posted May 4, 2019 Please see my seperate reply if I have mucked up the process of replying. Link to comment Share on other sites More sharing options...
