Gestating large sensitive passive 15" augmenting subs
My nearly-4-year 4-way speaker project has reached a plateau. A little Tassie GTG today made me reflect that it's all been worth (some of) the struggle.
The design and build thread is:
The most recent photo:
But this is a hobby, and this is SNA. Things must proceed. The words "so, it's basically the same as last time" really touched a nerve today (just kidding, you-know-who ?). This must never happen again!
I've played a few low tones and walked around the space - 10 x 6 m, with 3.2 m concrete ceiling, and noticed nulls, halfway along room, at the sides. Not huge, but a bit of a sag around 50-55 Hz.
It's a passive system. No DSP. The design aimed to maximize bass extension by doing what few seem to do: use a large vented box. These are 240 litres, with twin 102mm diameter vents.
So the new intention is to build 2 subs (stereo of course) to augment the bass, and place them in the "null" areas. This can hopefully coincide with the same distance from the listening position, so there are no time-delay issues.
The best option would seem to be in the joint of wall/ceiling, behind the listening position, a bit more than half-way back into the room. How to get them there was an unresolved discussion today. They will be around 320 litres internally, and likely approach 100 kg each; securing them is the easy part, getting them there is another thing. A "sub-crawl" would necessitate a reversal of gravity.
I initially thought the best driver would be the same as my 15" SBA woofers, but I was recently tempted by some gorgeous Acoustic Elegance TD15H drivers, so decided to model them in WinISD.
It was all settled for a couple of days, then I simmed the SBA's more recent "long-throw" version of my woofer. It's a bit confusing, as the TS parameters are very similar, including X-max.
The 3 drivers in this graph are:
SB42FHC75-6      black (mine)
SB42FHCL75-6     red (new long-throw)
Acoustic Elegance TD15H   blue
These all have LP (hi-cut) filters applied. The black one is the same as my 4-way woofer, cutting off at 100 Hz, as with its present passive 4th-order filter.
The blue trace, the AE driver, was very appealing, but both are completely blitzed by the (red) FHCL, so I've ordered 2 of these. Also, the 3" voice coil and greater power handling* (*Edit: wrong - see later posts) appealed.
The red and blue traces have a 60 Hz 2nd order filter applied. Of course, this can be adjusted in real life to match the 4-ways and the room.
The box sizes are 300 to 320 litres, all vented.
So I can't be saved from the spend, but maybe your comments can help me with the next stage - designing the boxes for the wall-ceiling corners? As a cube, internally they could be around 700mm each way, but I anticipate angled baffles, from 45 degrees to whatever into the room. Looks like they'll need to be about 1.6m "wide".
Edited by BioBrian
wrong link, error re power handling
  • Like 3
  • Replies 617
Popular Posts
Just a quick announcement that twins were painlessly born today, to a badly-presented but relieved BioBrian and his wonderful StereoNetter cohorts. I'd really like to gratuitously thank all staff, but
It's an odd experience when I find someone referring to something I wrote that I can't remember.   When you compare different kinds of subs, there are two experiences. The first is the easy
Both boxes now all trimmed, ready for final sand and varnish. Don't think I'll need DuraTex after all...   Worst problem has been lack of handles to move them.   110 kg each, so wi
Thanks Brian for having us to visit at such short notice.
Thoroughly enjoyed the company and the music, definitely better sounding with the door open.
This is the latest photo I have of your system, apples and herbs.
Will eagerly await the new sub configuration whatever it is.
Sphere calculator?
https://www.calculatorsoup.com/calculators/geometry-solids/sphere.php
These links may help with positioning?
https://amcoustics.com/tools/amroc
https://www.bobgolds.com/Mode/RoomModes.htm
http://www.sengpielaudio.com/calculator-roommodes.htm
Best of luck with them, to quote @Upfront "don't be shy", yell if I can assist.
6 hours ago, Wozza_Lee said:
sub built long and thin, almost like a pillar mid wall
This would certainly help with finding the best spot, and could be an interesting feature, as you say. I've sort of been led to believe that box shape (hence internal reflections) is almost irrelevant at these frequencies (bottom 2 octaves: 20-80 Hz). This would allow freedom not to be found in the upper octaves, where baffle step is also an issue.
I should say that there's fairly aggressive competition for wall-space though, and forget the floor!
The wall-ceiling junction looks most likely at the moment, as there are grooves in the Bondek ceiling for "Bon-nuts", which take heavy weight, and can be slid along the grooves if needed, to find the right placement.
I'm kind of hoping that the triangular box shape could match future room treatments, such as a continuation of the box-shape along the corners, but made of fluffy stuff with adjustable reflectivity surfaces. This could be material, holy plywood, metal, slats, etc, on their front surfaces. It may be too shallow for effective bass traps, but it's a thought at the moment.
Russell, it was very refreshing to have you and Linc down yesterday. Thank you (both) for all your advice and discussion. Nice pic from your phone, too.
Your post above has given me quite a lot of food for study! It's the first time I've come across these mode calculators, etc. And I thought I was just building a couple of subs ?.
Still wondering about the spherical enclosures - that would surely test the notion of box-shape-being-irrelevant. They could be stunning, especially if made of concrete and dangling from the ceiling (and you walk into one in the dark). New meaning to the phrase "balls in the air"? To get the 330 litres, with bracing, vent, and reasonable wall thickness, they'd need to be about 1m diameter. That's a statement.
It was kind of disturbing that the speakers sounded better with the Rolladoor open. That's not going to work well in winter. Or spring/summer, with all the bird noise. I'll try to get around to organizing all the mattresses and insulation into more correct places at some stage. The last 2  queen mattresses, that are currently leaning in one side of the room, seem to have swallowed some life out of the mid-range, but that's really hard to be sure about. I think they need to move to hanging vertically, somewhere out from the back corners.
If the door is acting as a limp mass membrane, maybe it needs tuning. It should be doing something towards diffusion, with all those horizontal folds. I've tried hanging batts in the middle there, but need to do some more serious tests.
One day we should have a REW party, with somebody who knows how to do it (not me).
I think the new subs need to happen first. They might have a future in somebody's home one day. Form will follow function, but I'll try to keep the shape a bit useable, hopefully.
Does anybody have experience using Green Glue to laminate speaker box panels?
I used to think its benefits would be negated by having to have joins at the edges, but even in the middle of panels it may help.
And I used to think it stayed sloppy forever, but someone recently said it sets hard.
I use rubberised adhesive (most contact adhesive is rubber based and will stay flexible).
Although wall thickness really isn't that important with a sub (as you said frequencys down that low are 15-18 meters long).
Its all about braces, for a sub that size I would have a skeleton with 2 vertical and 2 horizontal braces full size of the inside of the cabinet interlacing
Your chart doesn't show that.
What frequency range do you intend the boxes to cover up to.  If it's ~100Hz or lower with a relatively steep cutoff (eg. 24db/octave) - then the shape and angle of the bafle is of much less (if not zero) relevance.
Yes - don't bother trying to laminate two boards together with an "elastic" material if the purpose is to achieve some type of damping or vibration resistance.... and the frequency of operation is <400Hz.
Use extensive bracing to "lock the walls in place".     Like "B&W matrix" bracing .... but you don't need to quite go that extreme IMHO.
Also, the 3" voice coil and greater power handling appealed.
"greater power handling"?
The AE TD15H-8 - 500W (cont).
The SB42FHCL75-6 - 300W.
I got better results using significant bracing. Think B&W Matrix.
You and I have a very different idea of 'blitzed'. By the time it's in room, you won't be able to tell the difference based on those sims. Also remember, that the sims assume the drivers are completely linear throughout their excursion based on their T/S or small signal characteristics so cannot and do not take into consideration the surround, spider and motor linearity. A driver can have a specified Xmax, but only a fraction of that usable because of said non-linearity.
Do you actually have a measurement system?
OK, this looks like I made a glaring error - thanks Russell. Brain overload.
I think either driver would suit the intended purpose in this case. I came away from the search thinking that because of the frequency performance of the AE drivers, they were less of a pure sub. This was supported by a post from Paul Spencer back in 2015 about the TD18H still needing a "sub" below.
Edited by BioBrian
word missing
@davewantsmoore and @A9X, thanks for your posts re my comment "completely blitzed". I know I have a tendency for overstatement and cheap theatrics, but to me the SB42FHCL version looked better in WinISD.
As a passive driver sub, I want something that will produce 20 Hz with the least effort, and the least overshadowing by, say, 30 Hz.
The 3 traces were for drivers in the same sized vented enclosures, so include output from vents. Not sure about response using more than 2.83 V, but maybe you guys can see this.
In the same graph, the "L" says it puts out 3dB more at 20 Hz, and nearly 5 dB at 10 Hz (not that I'm bothered about 10 Hz).
Could you please explain what I'm not getting? Does it mean WinISD is not fit for purpose?
It may be not too late to cancel the SB order, as Wagner apparently didn't post them on Friday.
Another issue that's come up since ordering is from reading a comment by @almikel, also I think from 2015, that has pointed to the SB "L" having an Le of 2.1 mH, and the AE 5 times lower, this having a significant effect on lower frequency response. My error here is that I had thought 2.1 was pretty low.  Not sure of the implications here.
I think this part is in hand - my previous builds didn't raise any doubts, from memory.
Awesome footage of the B+W building! Putting the hard-ish foam in the back is interesting.
Link?   Would like to see that!
Still thinking on how to build spheres, just for fun.
based on those sims
... but the sims shown are only the "transfer function magnitude" tab .... which tells nothing .....  ie. we don't know that drivers higher/lower on there will be actually higher/lower in SPL.
That being said, I'd expect all drivers to hit zero on the  "transfer function magnitude" view .... so given they're not, then I don't know what is going on.    Perhaps the mentioned HPF and LPF have caused that.
Anyways... the proof in the pudding is on the SPL tab
.... and also the power handling tab ;)
... and if they have significantly different Xmax or construction, then perhaps the max power/SPL tabs.
My comment wasn't about the power handling.    It was that the picture you posted - doesn't (necessarily) show that one driver is better than the other.    You need to look on the SPL tab.     The transfer function magnitude screen isn't showing what it seems like you think it is  ;)
No  (unless I've missed something, in which case, sorry).   Do this:
Set each driver to 2.83v
Turn off all EQ/filters
Go to the SPL tab
Post pic.
Go to the SPL tab
Post pic.
Red - SB42FHCL (new toy)
Black - SBFHC (old toy)
Aqua - AE TD15H
All with no filters, set to 2.83V (thanks Dave, didn't know I could do this)
And "Max Power":
OK.
See how at 200Hz, the AE driver is ~1dB lower than the others?  (which is about what you'd expect given their datasheet specs)
What this is telling me, is that your box for the AE driver is poorly designed.  (ie. it should be ~103dB @ 30Hz) .... and the same issue (but less impacting) for the "new toy" driver.
Re: which driver is better?
I'd say the decider 100% comes down to how hard they will be driven.    There are reasons to think that the AE driver will perform a lot better under significant power and excursion.
https://www.audioxpress.com/article/test-bench-the-sb42fhcl75-6-15-subwoofer-from-sb-acoustics
Hi Dave, thank for your attention to this again.
My design criterion is to get max volume (efficiency) at 20 Hz, so the boxes/vents have been tuned to achieve this. Whether it's good or poor, that's what I've used WinISD to present.
I found a couple of driver data entry anomalies, which I've corrected - let's see if that sticks? Also, it kept changing the 2.83 V back to 2.8, so I've let it.
This new pic is just the 2 drivers of interest - red still the SB42FHCL, blue is AE TD15H. Does that look more like what you were expecting?
Also, not sure if you saw this, but they will be cut off around 60-80 Hz, just being augmenting subs.
I have no interest in them doing stage reinforcement - just clean quiet hi-fi noises, like bass drum and organ at easy listening levels.
Please let me know if "poor" is going to give bad or destructive results.
Still no word from Wagner re my order...
Thanks for having us Brian. Always a pleasure listening to your system, although briefly! Really enjoyed just sitting and having a chat. My place next time. Will PM you when I work out a time and date.
Thanks again mate.
I don't use this version of winisd (I'm stuck on the older one).... but I suspect it is just rounding what it is displaying to x.x
It's complicated.
The inductance slows the change in current in the voice coil.    This means that the current can't change quickly .... this means the driver can't play high frequencies....  This is why an inductor, rolls off higher frequencies.
The other, and more problematic issues .... is that as the voice coil moves in and out ..... the amount of inductance (the Le parameter) in the driver varies.    If you looked at the impedance of the driver vs frequency .... while the driver was moving, the impedance curve would wobble around.
This created non-linear (harmonic and intermodulation) distortion .... which increases with increasing excursion.
It's one of the reasons why I said it's expected the AE driver would work better at high power (ie. high excursion)
"Poor" is perhaps being a bit of a doomsayer.
This issue you'll face is that:
The small vent (making it bigger will make it too long) causes turbulence and compression...  that winisd doesn't model.
You will need multiple filters to make the driver behave.
  • Perhaps - a high pass (otherwise there's a theoretical risk of damage at very LF, even at home levels)
  • A filter in band to cure the rolloff stating below ~200Hz.    In my sim I just did, I was able to get away with a simple 6dB/octave filter.
  • A low pass filter
All of them will require enormous values.... not to mention the bass is still uncorrected for any issues in room.
There are a lot of reasons to consider if a sealed box will work.   Typically you would only avoid a sealed box if you wanted to lower power and/or excursion for your desired max SPL....  but with drivers like these, they are within their comfort zone.
With the AE driver you only need 120w and half of xmax to get to 105dB@ ~20Hz
OK what about this.
SB42FHCL driver. 320 l box. 150 x 348mm vent (dare that to chuff!). 36W input. 60Hz LP filter (imagine around 18mH C-coil (rated to 2000W), and 100-300uF parallel cap as 2nd Order:
Personally, I'd want a steeper cutoff.    (It's too loud at 200Hz)
... but more so, the idea of putting 36w (perhaps even double that) through a huge inductor and a capacitor... on the way to my speaker driver - doesn't seem like a very good plan.
People argue about the distortion these components create even when they are much smaller, and the energy transfer is much lower.    If we accept the views (I'm not 100% sure) that there is something to these people claims  (for example, different components sound different) .... then using them at all - let along in this situation - seems like a bad strategy.
Quote
dare that to chuff!
It's only 6 and a bit litres.  ;)
Quite a while since I've been back here...other priorities...but I think @davewantsmoore has covered it - lower inductance affects the upper end, not the lower end...
...but on my previous investigations of the Acoustic Elegance range of drivers, if looking to produce down to 20Hz without DSP, and you can manage a large box, the IB15 was the only driver I ever found that could get to 20Hz in a sealed cabinet without EQ - it was a big box though (around 240litres) - not surprising for a driver designed for Infinite Baffle alignments.
Around the same time I went to the darkside and started using EQ with sealed cabinets, so I never tried the IB15s - I ended up with TD18s instead - tiny boxes and loads of EQ - but requiring a sub underneath.
The IB15s are proper sub territory, but need a big box or Infinite Baffle...
...in your scenario have you considered Infinite Baffle?
Just a thought...
Mike
Thanks for your post, and welcome back! Hope those pesky distractions aren't too disruptive for too long.
Interesting about the IB15. I didn't follow through with the idea of this in a vented box. A little swayed by the presence of a pair of used TD15Hs for sale locally.
I was going to respond to one of Dave's posts about baffle shape, which would elicit much the same words as this:
My intended wall-ceiling box placement, with a 45 degree angled baffle, would effectively be an infinite baffle - ie no baffle step loss, in fact I'd expect a net gain over IB (on a flat wall) - approaching "corner placement" - huge room gain.
But IB implies a virtually infinite air space behind the baffle, doesn't it? It's all looking fairly similar though - my vented box size is 320 litres, so I'm guessing they won't get many Watts thrown at them.
The 105 dB is also a little loud!!   But yes, I could do the same as my other SB42 woofers (vented 240 l) - use a 4th order passive. Easy. I'd call that fine-tuning, and I suspect room-tuning will predominate those decisions.
Not sure that the parallel capacitor sound 'thing' is an issue with large bass drivers - much more a tweeter issue. Happy to do some tests. There is a new generation of electrolytic caps, but Jantzen Cross-caps aren't that much dearer (I have a couple of 150 uF here).
Huge inductors?  No idea how they affect sound.  Not at all, from my listening. From all the emotive stuff on "damping factor" threads, I have sort of gleaned that R is the only relevant issue there, and these C-coils have almost none. Thick, short wire. Phase and group delay may be important, but that's unfortunately something I'll have to swallow with these design parameters.
I had modelled the vents using 2 lengths of 102 mm ID sewer pipe, as in my previous build. At the GTG on Saturday, we played a 24/192 version of "Hotel California" through them, appreciably louder than my normal tolerance, and I held a tissue over one of the vents. It only flapped about a centimetre. I have zilch worries about a 150 mm vent chuffing, as its area is larger than the 2 x 4" pipes (177 cm^2 vs 163 cm^2).
Further on "passive" inductors - did you see what I think I saw, of the mH values on @acg's line-level filters?? I seriously want to know more about this approach.
Edited by BioBrian
GTG on Sat, not Sunday. Wish sun'd been there.
I've been learning how to play harmonica - a fantastic distraction!
correct - but drivers designed for IB alignments can work in sealed boxes if the box is big enough - when you sim a driver meant for IB in a sealed box you'll see it peak before roll off - the bigger the box the lesser the peak...
...if you're considering a 320 litre vented box and haven't purchased a driver yet, then consider the AE IB range, and run them in a large sealed box...or proper IB - they don't have to be on a flat wall to be IB...most IBs have a manifold (that the drivers mount on), with the manifold exiting outside.
IMHO I would avoid ported alignments if sound quality is the goal - too many things go awry as SPL changes - much less so with sealed or IB subs.
Mike
Not in a max SPL sense.
If you think about what you measure on a SPL meter with music .... You need to add the crest factor of your content on top.    Is that 4dB?  10dB?  30dB????  ;)
Otherwise what happens, is that on the "short, sharp, loud" bass tones ....  You get some sort of linear or non-linear distortion....  which typically results in either a raised noise floor (from non-linear), or a reduced level (from linear) .... both results in "indistinct" bass.
No, it isn't a "damping factor" thing.
They're directly related to the frequency response in this instance ..... so, just the FR is important.
Yes, I guess that's my point.  :)
I didn't mean to imply that was the primary problem.    It's more a "compression" issue, when you look at how the driver responds at LF vs time.
Yes.    You'll see some comments from me in his thread  ;)
At the frequencies you are talking about, the concept "of baffle step loss" is kinda nonsensical.    At LF essentially anywhere in the room you place the subwoofer it is approaching being "in the corner".
Yes.
The practical effect of doing that is reduced power requirements vs SPL at LF.
Looking at the drivers frequency response in a box, before you have shaped the response to your needs - is not the right way to evaluate a driver.
Need to mould their response to be the same (whatever your target is), then look.    A lot of the differences will go away, others will become more obvious.
It's pretty simple Brian, you jam the filter at the input of the amplifier where the voltages are much smaller, let's say 2V max (4V in my case) and use the input impedance of the amplifier as the load for the filter rather than the reactive impedance of a speaker level crossover network and transducers.  Then you direct connect your transducer to the amplifier.  It keeps the filter component values much smaller, so tiny caps and inductors.
In some circumstances you may even be able to build part of the filter into the amplifier itself.  For example an interstage coupling capacitor can be sized such that it creates a first order high pass filter at the desired frequency.  Couple that with a low pass filter  before the amplifier and you have a bandpass filter.
I've not yet read your thread Brian but the speaker photos on the front page look excellent.
    • By W47ty
      Item: svs sb1000
      Price Range: neg
      Item Condition: New or Used
      before I dive headlong into adding "what sub next" into my hifi madness I have assessed this one as being a good place to start.
      got one you don't need or like HMU
      Chris
    • By leemich4@bigpond.com
      Item Condition: Good used Shipping Options: Pickup available and you can audition. Suburb or Town: 2570 State: NSW Payment Method: EFT Reason for selling: Redundant A good surround sound speaker starter package. The sub has recently been serviced. Further information:
      PLEASE READ
    • By Matcat
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Norwood State: SA Payment Method: EFT, Cash on Pickup Reason for selling: not in use love to keep this excellent passive pre-amp but going in another direction atm
      had a tube cd player hooked up to this;  very revealing detailed sound, great at low volume
    • By rhcp_steve
      Item: SVS SB2000 sub
      Price Range: $900
      Extra Info: Brisbane based but will consider interstate purchase
    • By Naz.shr
      Item Condition: As new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Cash, Paypal Reason for selling: Going a different route Further information:
      Bought recently from another SNA member. Great sub for both HT and 2ch music, needs no introduction.
      Shipping available with original packaging.
      Donation to SNA on successful sale.
      PLEASE READ
