wolfz
Meier Corda Classic
Item: Corda Classic Headphone Amp
Price: $ 410
Item Condition: used / exellent
Reason for selling: using all in one amp/dac
 A few tiny marks (edge), not easy to see, no original box. Normal retail price new is $800.
A very good sounding amp with two crossfeed stages and two gain settings. Tried a number of headphones with this amp ( HD800, SIG Pro, Alessandro MS Pro, HD600 & 650, T1, DT880 ).
Every headphone sounded good with this amp esp. the Beyer T1.  The DT880 was  lacking a bit bass.
Tech Data copied from Meyer:
Sure, from the outside the CLASSIC looks very modest and plain. However, technically and sonically this is the best and most advanced amplifier that we've ever build.
Of course this amplifier also uses the concept of active balanced headphone ground. Within this concept each headphone connection wire carries an additional signal such that the sum of the potentials of the wires equals zero. This strongly minimizes the energies stored and released in the electrical fields inside the headphone cable when an audio-signal is applied. The influence of the wire on the sound is thus reduced.
Moreover, with active ground pollution of the internal signal ground by strong driving currents is eliminated and the power-supply-rejection-ratio at the output stages is strongly improved. Thus the best conditions are given for a clean and undistorted sound.
Active balanced headphone ground offers most of the advantages of a true balanced headphone setup without the need of balanced connections. It can be used with any conventional dynamic or magneplanar headphone.
The volume control is technically very sophisticated. The position of the potentiometer is measured with the use of an AD-converter. The output of this converter is then used to switch a bank of relais to set the proper volume level. There are a total of 64 levels which allows for very small stepsizes and a very analog feeling. The advantages of this concept are strongly reduced channel-imbalances and a much cleaner and more detailed sound. The use of a conventional stereo-potentiometer does add its own sonic signature which is now prevented.
The amplification section is build around AD797 opamps biased into class-A. For the output stages BUF634 buffer amplifiers are used. These integrated circuits are very fast and thus allows the output signals to follow the input signals very closely. The amp is DC-coupled and any capacitors found in the signal path are of the highest quality polypropylen and polystyrol.
A very extensive powersupply, a large number of power-regulators, and a total filter capacity of 80.000 microF (!!) assure the best working conditions for any part of the circuitry.
The built-in crossfeed filter is a frequency-extended version of the natural crossfeed found in previous CORDA amplifiers and provides even better imaging. It also offers three intensity levels (Stereo, medium, high). To compensate for the psycho-acoustic bass-loss a separate switch allows to slightly increase lower-frequencies.
Technically the CLASSIC is an extremely advanced headphone amplifier and offers excellent value-for-money!
Edited by wolfz
Its not FF version.
    • By theoldnic
      Item:  Antenna
      Price: 70 aud + postage 15
      Item Condition: NEW
      Reason for selling: I make them (no ABN)
      https://www.ebay.com.au/itm/19-FM-SW-am-long-range-90km-antenna-aerial-outdoor-home-tower-caravan-marine/283469174136
    • By Winter
      Item: Power cord
      Price: $125 posted
      Item Condition:8/10 age only
      Reason for selling:Upgrade
      Extra Info:Bought from Clarke audio (Dallas) a few years ago. Apparently these cords came with the 333/332/331 when bought new.
    • By dwbasement
      Item: as above
      Locatuin: Sydney, pick up only at Picnic Point NSW2213 after hours or weekends, can be arranged pick up at Ultimo NSW2007 office hours
      Condition: good working condition
      Price: $75
      RFS: moving to an apartment
      Payment: as usual
    • By countcrisp
      Item: Pioneer SC-LX901  &  SC-LX701
      Price: $3000 & $2000
      Item Condition:  New BNIB
      Reason for selling: no longer needed
      New Pioneer SC-LX901 and Pioneer SC-LX701 AV Receivers. Brand new in box never used or taken out of box.
      Was going to use them in various rooms but have gone in another direction.
      Pioneer SC-LX901  $3000
      Pioneer SC-LX701  $2000
      Shipping Aust wide can be organised if needed
    • By Angelomatthews
      Item: David Bowie & George Michael CD's (Japan/UK)
      Price: $60 for all 3.
      Item Condition: Good
      Reason for selling: Don't listen to them
       - David Bowie CD Let's Dance Japan Black Triangle
       - David Bowie Ziggy UK (1990) Bonus Tracks Version
       - George Michael 1990 UK by JASRAC Japan.
