Russboz
FS: Marantz AV8801 Pre-Amp
Item: Marantz AV8801 Pre-Amp
Price: $1100
Item Condition: As new
Reason for selling: Selling house and no longer used
Payment Method: Pickup - Cash or Paypal
Extra Info: Includes remote & owners manual discs
Happy to send at buyers expense via pack'n'send or similar
    • By Dacman
      Item Condition: as new Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Noosa Heads State: Queensland Payment Method: Pickup - Cash, Paypal +3% COD bank transfer Only Reason for selling: NLR Further information: Listing for a friend (im located in Melbourne amp is in Noosa Heads). This amp is in as new condition with very few hours on it and most likely still to burn in, comes with original box no remote but one can be added.
      Specifications:
      Maximum output: 100 W × 2 (4O), 75 W × 2 (6O), 50 W × 2 (8O)
      Frequency response: 10 Hz - 30 kHz ±1dB (6O, 1W)
      Harmonic distortion ratio: 0.02% (at 1 kHz, 80% output)
      Input sensitivity, gain: 300 mVrms, 37.3 dB (at MAX volume, 6O, 1kHz, unbalanced input)
      Line input terminals: XLR input : 1 RCA inputs : 3
      Speaker terminal: 1
      Power voltage: 220V AC,50Hz
      Electrical consumption: With no signal : 18 W, during maximum output : 180 W (8 O, 100 Hz)
      External dimensions: 350 mm (width) × 95 mm (height) × 375 mm (depth)
      Weight: 7.0 kg
    • By gillmaverick
      Item Condition: Great Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Korumburra but can deliver to Melbourne South East State: Victoria Payment Method: Cash , Bank Transfer Reason for selling: Upgrade Further information: The SPA2-150 is in excellent working condition & has no visible marks.This power amp was the top of the range model at the time when ATC launched their passive speakers with RRP of $12000 here in Aus. It has both Balanced and RCA inputs. I have been running my Paradigm Tributes with this Amp and It makes them sing. I have just sold my ATC Pre and have the opportunity to upgrade hence putting this on the market. Price is firm. I can deliver to Melbourne South Eastern suburbs.
      SPA2-150 – Discrete Stereo Power Amplifier
      Hand built in the UK. Dual Mono design. 150W into 8 ohms. Balanced. Output Power into 8 ohms: 150W
      Input Sensitivity: 1.2V
      Input Impedance: 10k ohms
      Frequency Response: 5Hz – 200KHz ±0.1dB
      Signal / Noise Ratio: >110dB
      Crosstalk: >105dB
      THD: >95dB/0.0018%
      Dimensions (HxWxD): 146x440x426
      Weight (HxWxD): 26kg / 57.2lbs
      More Information below :-
      The SPA2-150 uses a grounded-source output stage to deliver over 200 Watts per channel, driven by a buffer based on the discrete gain block which enables the SCA2 pre-amplifier to deliver such astonishing performance figures. Used in this way to drive the FET output stage, distortion components are more than 95db down under any conditions, ensuring totally clean and transparent sound with the effortless dynamics for which ATC is justly famous.
      Input to the amplifier utilizes a similar discrete gain block and offers both XLR-Balanced and RCA-unbalanced capability for universal system matching. This input buffer, which completely eliminates integrated circuits, achieves the same levels of transparency as the famous ATC SCA2 pre amplifier.
      The output stage of the SPA2-150 is continuously monitored by microcomputer and a carefully programmed limiter prevents amplifier clipping and protects loudspeaker drive units.
      Front panel indication of limiter operation is provided separately for each channel. Additionally the amplifier is monitored for over-temperature and DC offset.
      Construction is Twin-Mono, with separate high capacity mains transformers for each channel. The FET output stage is very fast and layouts follow best RF practice, with direct signal-paths and direct low-impedance power supplies.
      Remote control of the SPA2-150 is possible using the SCA-R remote controller, or any other standard RC5 device. High quality connectors are used throughout including massive WBT terminals. Styling is complementary to the SCA2 with high quality, peened, stainless-steel covers atop machined aluminium corners.
    • By Huckles
      Item Condition: Used Shipping Options: Shipping is included in price. Suburb or Town: Harrison State: Australian Capital Territory Payment Method: Cash, Paypal Reason for selling: Not required anymore Further information:
      VoightLander MACRO APO-LANTHAR 65mm F2 Asp E Mount.  MINT.  No dings, dents, scratches etc.  Could almost be presented 'as new'.  Crazy awesome performance.  Obviously APO corrected.  One of the sharpest lenses for e-mount, if not the sharpest.   Just don't use it much these days.  Comes with receipt from Mainline Photos.   Original box, documentation, hood.
      Donation will be made to StereoNet if sold here.
    • By davidSun
      Item Condition: Good Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Sydney State: New South Wales Payment Method: PayPal, Cash Reason for selling: NLR 1. Santana Corazon Blu Ray - $20
      2. Beatles Help Blu Ray - $30
      3. David Gilmour DVD -$15
      4. Led Zeppelin Blu Ray - $20
      5. Pink Floyd DVD - $10
      6. Madonna DVD - $10
    • By ETknowsaudio
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: South Yarra State: Victoria Payment Method: PayPal, EFT, pay ID Reason for selling: Studio changes (this ad is in a series of my very first posts here at StereoNET. I was drawn to this forum due to its high quality)
      Digitone FM/digital Synthesizer in excellent condition.
      Purchased from: Store DJ
      Purchase condition: Brand new
      Usage: Light home studio use
      Operation: Fully functional
      Mods: N/A
      Included with sale:
      - Digitone
      - USB cable
      - Power supply (OEM)
      Please let me know if you have any questions.
