oztheatre
BenQ W5700 4K Cinema Projector & Majestic Screen Package
Sponsor
Item: BenQ W5700 and Majestic Screen Package.
Price:  From $5579
Item Condition: Brand new
Payment Method: Pickup, direct deposit, cards 1%.
Extra Info: Call for further info, book in for demo etc
 Free upgrade: up to 140 inch 16:9 Majestic Evo4K screen for forum members only.
The all new BenQ W5700 4K DLP Cinema Projector and Majestic Screen package is now available.
With bonus Peerless geared mount valued at $399!
NOW ONLY $5579 delivered to your door anywhere in Australia.
The all new BenQ W5700 4K Cinema Projector is now here in the Oz Theatre showroom.
AVS forum owners page and reviews here - https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/3050402-benq-w5700-ht5550-4k-100-dci-p3-projector-announcement-ownera-s-thread.html
Projection calculator here -  (note W5700 is the HT5550 in the USA)
If you need assistance feel free to call direct 0402 424 177
True 4K UHD Projector with 100% DCI-P3/Rec.709 and HDR-PRO| W5700
W5700 brings both 100% of Rec. 709 and DCI/P3 colour gamuts. At $3999 AUD, the W5700 is the least expensive projector on the market that can reproduce full DCI-P3 colour. Impressive!
  • True 4K UHD resolution with 8.3M pixels
  • BenQ CinematicColor™ for cinema industry’s 100% DCI-P3/Rec.709 color space
  • HDR-PRO™ projector-optimized HDR technology (HDR10/HLG support)
Super-Wide 100% DCI-P3 Color Rivaling Digital Cinemas
The motion picture industry’s loftiest color standards guarantee accurate reproduction of cinematic HDR colors across 4K UHD devices as filmmakers intended. Enhancing optimal colors for precise picture quality, BenQ CinematicColor™ technology achieves 100% of digital cinema industry’s super-wide DCI-P3 color space, which is 1.26 times of the Rec. 709 color space. With DCI-P3, you can enjoy richer, more lifelike colors than ever possible on a 1080p Full HD TV.
Factory Calibrated Out-of-the-Box Color Accuracy
Using special instruments and software, W5700 is tested and adjusted for precise D65 color temperature, gamma, black level, white level, neutral grey, RGBCMY color tracking, hue, saturation, brightness and output based on DCI-P3 and Rec. 709. All data from multiple interfaces is compiled for individual factory calibration reports, guaranteeing 100% Rec.709 and DCI-P3 color accuracy with Delta E<3* to reproduce authentic colors of Hollywood films.
ISFccc® Certified Visual Calibration
With the Imaging Science Foundation’s highly reputed ISFccc® calibration built-in, W5700’s image and color performance can be customized for any space, along with preset light balance modes for day and night.
Hyper-Realistic Video Quality with HDR-PROTM
Optimized for projection, BenQ exclusive HDR-PRO technology enhances the 4K HDR viewing experience. Employing enhanced tone mapping, HDR-PRO offers greater contrast range to bring out every detail from 4K Blu-rays as well as streaming content for unparalleled cinematic enjoyment.
Authentic Cinema Reproduction for Dark Rooms
The Art and Craft of True 4K UHD
4K UHD True 8.3 Million Pixel Perfection
Producing 4K UHD 3840x2160 resolution with 8.3 million distinct pixels for each frame, W2700 utilizes the new generation 0.47” single-DMD DLP technology to minimize the projector’s sleek, compact profile for modern lifestyles. With four times the resolution of Full HD 1080p, 4K UHD reduces pixel blur for awe-inspiring clarity and crisply defined fine details.
Precision 10-Element 8-Group All Glass 4K-optimized Lens Array
Super-high resolution 10-element lens array is structured into eight groups with metal barrel and cell framework, far outshining 1080p projector technology with greater light penetration for long-lasting 4K intensity with heart-stopping color performance, clarity, and sharpness across the entire screen.
Balance of overview here https://www.benq.com/en-ap/projector/cineprime-home-cinema/w5700.html
Main Specifications
Resolution 4K UHD (3840 x 2160)
Brightness (ANSI lumens) 1800 ANSI Lumens
Contrast Ratio (FOFO) 100,000:1 (w/ Dynamic Iris)
All Specifications Display
Projection System DLP
Resolution Support VGA (640 x 480) to 4K UHD (3840 x 2160)
Display Color 30 Bits (1.07 billion colors)
Native Aspect Ratio Native 16:9 (3 aspect ratio selectable)
Light Source Lamp
Light Source Wattage 245W‎
Light Source Life Normal 4,000 hours
Economic 10,000 hours SmartEco 8,000 hours
Optical Throw Ratio 1.36 ~ 2.18 (100" @ 3 m)
Zoom Ratio 1.6X
Lens  F/# 1.81~2.1, f 14.3(Wide) ~ 22.9(Tele)
Lens Shift Vertical: ± 60% / Horizontal: ± 23%
Keystone Adjustment 1D, Vertical ± 40 degrees
Image Size 60" ~ 200" / 300" (Clear Focus / Maximum)
Horizontal Frequency 15K-102KHz
Vertical Scan Rate 23-120Hz
Picture Picture Mode
*** ISF Disabled: Bright / Vivid / Cinema (Rec. 709) / D. Cinema / Silence / 3D / User 1 / HDR / HLG
**** ISF Enabled: Bright / Vivid / Cinema (Rec. 709) / D. Cinema/ Silence / ISF Night / ISF Day
Color Wheel Segment 6-Segment (RGBRGB)‎
Color Wheel Speed 2D: 96Hz ; 100Hz ; 120Hz
3D: 100Hz, 120Hz
Rec.709 Coverage 100%
DCI-P3 Coverage 100%
Interface HDMI x2 (HDMI 2.0b & HDCP 2.2)
USB Type A x1 (5V/2.5A power supply) x1 (USB 2.0 Media Reader/ Firmware upgrade)
x1 (USB 3.0 Media Reader/ Firmware upgrade)
USB Type mini B x1 Firmware upgrade
Audio out (3.5mm Mini Jack) x1
LAN (RJ45) x1 RJ-45 LAN input jack (10/100M)
RS232 (DB-9pin) x1 RS232 In (D-sub 9pin, male)
DC 12V Trigger (3.5mm Jack)
x1 (3.5mm Jack)
IR Receiver
x2 (Front/Top)
Wired Remote in (3.5mm Mini Jack) x1
Special Feature HDR
Yes (HDR10, HLG)
Motion Enhancer (MEMC) Yes
ISF Night/ Day Yes
LAN control Yes
CinemaMaster Video + Yes (4K Motion Enhancer, 4K Pixel Enhancer, Color Enhancer, Flesh Tone)
Compatibility HDTV Compatibility
480i, 480p, 576i, 576p, 720p, 1080i, 1080p, 2160p
Power Power Supply VAC 100 ~ 240 (50/60Hz)
Typical Power Consumption Max 405W, Normal 330W, Eco 247W
Standby Power Consumption 0.5W Max. at 100 ~ 240VAC
Network Stand-by Power Consumption <2W
Acoustic Noise (Typ./Eco.) 32dBA / 26dBA
Operating Temperature 0~40 degrees (Celcius)
Dimension and Weight Dimensions (W x H x D)(mm) 492 x 168 x 349
Net Weight (Kg/ lbs ) 6.5kg / 14.3lbs
Accessories (Standard)
Remote Control w/ Battery
Remote Control w/ Battery x 1 (RCV016)
Power Cord (by region)
Power Cord (by region) x 1(3m)
User Manual CD Yes (27L)
Quick Start Guide Yes (9L)
Warranty Card (by region) Yes
Lens cover x 1
Accessories (Optional) Spare Lamp Kit
Optional Universal Ceiling Mount
Optional: Ceiling mount (CMG3)
3D Glasses Optional
OSD OSD Language
Arabic/ Bulgarian/ Croatian/ Czech/ Danish/ Dutch/ English/ Finnish/ French/ German/ Greek/ Hindi/ Hungarian/ Italian/ Indonesian/ Japanese/ Korean/ Norwegian/ Polish/ Portuguese/ Romanian/ Russian/ Simplified Chinese/ Spanish/ Swedish/ Turkish/ Thai/ Traditional Chinese (28 Languages)
*** Default picture mode is Cinema (Rec. 709)
**** When ISF is enabled, default picture mode is ISF Night.
    • By oztheatre
      Item: BenQ W2700 and Majestic Screen Package.
      Price:  From $3999
      The all new BenQ W2700 4K DLP Cinema Projector and Majestic Screen package is now available.
      NOW ONLY $3999 delivered to your door anywhere in Australia.
      The all new BenQ W2700 4K Cinema Projector is now here in the Oz Theatre showroom.
      The all new BenQ W2700 4K Cinema Projector is nearly here!
      AVS forum owners page and reviews here https://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/3021904-benq-w2700-ht3550-announcement-ownera-s-thread.html
      Projection calculator here https://www.projectorcentral.com/BenQ-HT3550-projection-calculator-flash.htm (note W2700 is the HT3550 in the USA)
      True 4K UHD HDR-Pro Projector with DCI-P3/Rec.709| W2700
      True 4K projector UHD resolution with 8.3M pixels
      BenQ CinematicColor™ for Industry DCI-P3/Rec.709 color space
      Reproduce Details for Cinematic Senses with True 4K HDR Get ready for true 4K HDR with cinematic wonder like you’re in an authentic digital home cinema. For audio-video enthusiasts who want to take in every little detail for truly cinematic experiences, enjoy the super-wide DCI-P3 color space with film-like texture and playback as directors envisioned, BenQ W2700 4K HDR CinePrime Projector with CinematicColor™ technology ushers awe-inspiring movie magic into your personal AV room.
      Super-Wide DCI-P3 Color Rivaling Digital Cinemas Enhancing optimal colors for precise picture quality, BenQ CinematicColor™ technology reach American film industry’s 95% super wide DCI-P3 color space, covering far greater visible spectrum than Rec. 709. With DCI-P3, W2700 perfectly reproduces authentic cinematic quality with wide and precise color accuracy as how the directors have originally envisioned.
        Factory Calibrated Out-of-the-Box Color Accuracy Using special instruments and software, W2700 is tested and adjusted for precise D65 color temperature, gamma, black level, white level, neutral grey, RGBCMY color tracking, hue, saturation, brightness and output based on ITU-R Rec.709. All data from multiple interfaces is compiled for individual factory calibration reports, guaranteeing 100% Rec.709 with Delta E<3*, also implement an optimal DCI-P3 color table by BenQ exclusive CinematicColor technology to reproduce authentic colors of Hollywood films.
      ISFccc® Certified Visual Calibration By incorporating the Imaging Science Foundation’s highly reputed ISFccc® Certified Visual Calibration, the image and color performance can be customized for any space, along with pre-set light balance modes for day and night.
      Hyper-Realistic Video Quality with HDR-PROTM Optimized for projection, BenQ exclusive HDR-PRO technology enhances the 4K HDR viewing experience. Employing enhanced tone mapping, HDR-PRO offers greater contrast range to bring out every detail from 4K Blu-rays as well as streaming content for unparalleled cinematic enjoyment.
      Precision 10-Element 8-Group All Glass 4K-optimized Lens Array Super-high resolution 10-element lens array is structured into eight groups with metal barrel and cell framework, far outshining 1080p projector technology with greater light penetration for long-lasting 4K intensity with heart-stopping color performance, clarity, and sharpness across the entire screen.
      Balance of overview here https://www.benq.eu/en-eu/projector/cineprime-home-cinema/w2700.html
      Main Specifications Resolution 4K UHD (3840 x 2160)
      Brightness (ANSI lumens) 2000 ANSI Lumens Contrast Ratio (FOFO) 30,000:1 Speaker Chamber Speaker 5W x 2 All Specifications Display Projection System DLP Resolution 4K UHD (3840 x 2160) Resolution Support VGA (640 x 480) to 4K UHD (3840 x 2160) Brightness (ANSI lumens) 2000 ANSI Lumens Contrast Ratio (FOFO) 30,000:1 Display Color 30 Bits (1,07 billion colors) Native Aspect Ratio Native 16:9 (6 aspect ratio selectable) Light Source Lamp Light Source Wattage 245W‎ Light Source Life Normal 4,000 hours Economic 10,000 hours SmartEco 15,000 hours
      Optical Throw Ratio 1.13 - 1.47 (100" @ 2.5 m) Zoom Ratio 1.3X Lens F/# = 1.9 - 2.47, f = 12 - 15.6 mm Lens Shift Vertical 100%~110% Keystone Adjustment 1D, (Auto) Vertical ± 30 degrees Projection Offset 105% Clear Image Size (Diagonal) 40"~200"  Image Size 30"~200"  Horizontal Frequency 15K-135KHz Vertical Scan Rate 23-120Hz Picture Picture Mode Bright / Vivid TV / Cinema (Rec. 709) / D. Cinema / Silence / User 1 (HDR / HLG / ISF Night / ISF Day / 3D*)
      Color Wheel Segment 6-Segment (RGBRGB)‎ Color Wheel Speed 2D: 96Hz ; 100Hz; 120Hz  3D: 120Hz
      DCI-P3 Coverage 95% Audio Speaker Chamber Speaker 5W x 2 Interface HDMI X2 HDMI (2.0a/HDCP2.2) USB Type A X1 (5V/2.5A power) X1 ((Media Reader, FW download) USB Type mini B X1 (FW download, service) Audio out (3.5mm Mini Jack) X1 (mini jack) DC 12V Trigger (3.5mm Jack) X1  (3.5mm Jack)  IR Receiver 2 (Front/Top) Special Feature Motion Enhancer (MEMC) ISF Night/ Day Yes
      CinemaMaster Video + Yes CinemaMaster Audio+2 Yes Compatibility HDTV Compatibility 720p 50/60Hz, 1080i 50/60Hz, 1080p 24/25/30/50/60Hz, 2160p 23/24/25/30/60Hz
      3D Compatibility‎ Yes Power Supply VAC 100 ~ 240 (50/60Hz) Typical Power Consumption Max 350W, Normal 340W, Eco 280W Standby Power Consumption 0.5W Max. at 100 ~ 240VAC Acoustic Noise (Typ./Eco.) 30/28dBA (Silence mode) Operating Temperature 0~40 degrees (Celcius) Dimension and Weight Dimensions (W x H x D)(mm) 380 x 127 x 263 Net Weight (Kg/ lbs ) 4.2 kg / 9.2 lbs
      Accessories (Standard) Carton Yes Remote Control w/ Battery x 1 (5J.JKC06.001) Power Cord (by region) x 1 (3m) User Manual CD Yes (27L)
      Quick Start Guide Yes (21L) Warranty Card (by region) Yes Lens cover Yes Accessories (Optional) Spare Lamp Kit Yes (5J.JKC05.001) 3D Glasses YES OSD Language Arabic/ Bulgarian/ Croatian/ Czech/ Danish/ Dutch/ English/ Finnish/ French/ German/ Greek/ Hindi/ Hungarian/ Italian/ Indonesian/ Japanese/ Korean/ Norwegian/ Polish/ Portuguese/ Romanian/ Russian/ Simplified Chinese/ Spanish/ Swedish/ Turkish/ Thai/ Traditional Chinese (28 Languages)
      * In 3D Mode: Resolution is 1920x1080 in 3D Mode.
      ** The Contrast is measured by Full On Full Off standard.
      *** Lamp life results will vary depending on environmental conditions and usage.  Actual product's features and specifications are subject to change without notice.
    • By oztheatre
      Item: The all new native 4K Sony VPL-VW270ES 4K Cinema Projector (new 2019 model with all new lens) and Majestic Screen package is now available.
      Genuine Australian stock! This model is available in black or white.
      Groundbreaking price for native 4K cinema projection!
      RRP at $10,317 based on package with 100 inch Majestic Screen at full RRP.
      With 2 RF 3D Glasses and premium Majestic Evo4K Screen and top of the line Peerless geared projector mount!
      Priced From: $8289 inc GST and delivery Australia wide.
      Payment Method: Pickup - Direct deposit, cards 1%.
      Extra Info: This model doesn't have the lens memory feature that the 570ES has, however it has motorised zoom, shift and focus so you could use a 235 screen, it would just take a little longer to switch between formats when required.. perhaps 30-40 seconds using the remote. Otherwise a 16:9 format screen would mean no changing sizes or messing around with the remote.
    • By oztheatre
    • By oztheatre
      Item: Majestic 135" 16:9 fixed screen with Evo Ultra 4K and Fidelio velvet frame
      Price:  $1949 delivered
      Payment Method: Pickup - Cash, Visa and mastercard @ 1%. Direct deposit.
      Extra Info: Lifetime warranty, free shipping Australia wide with cope sensitive freight.
      Frame size: 3140 x 1831
      Viewing area: 2990 x 1681
      Reviews here
      PM with any questions, request for samples etc.
