Tivoli Hi-Fi
FS: Trade In REL Storm III Subwoofer Walnut
Sponsor
Item: Trade-In REL Storm III Subwoofer Walnut
Location: Tivoli Hi-Fi 155 Camberwell Road Hawthorn East VIC 3123
Price: $699 Special SNA Forum Discount $599 LOCAL PICKUP ONLY
Item Condition: Trade-In stock in Good Condition. Comes with Manual & High Level Speaker Cable.
Payment Method: Direct Deposit, Paypal, Cash - Pickup in store, Credit Card including AMEX with no fees or penalties.
Fully inspected and tested prior to sale.
Minor marks on sides, shown in first photo.
A real music subwoofer, improve your system with a REL
  • True 150W (continuous) discrete direct-coupled MOSFET amplifier
  • Downward-firing 250mm long-throw driver with heavy-duty cast chassis
  • Ultra-rigid 30mm cabinet
  • Improved ABC® filtering circuit with 24 musically correct semi-tone increments between 22Hz-96Hz.
  • Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
  • Audiophile grade toroidal transformer
  • Gas-tight Neutrik high level connection for long-term consistency of sound quality
  • High guality, panel-mounted twin phono inputs at OdB and +12dB (low level)
  • High and low level balanced inputs (Neutrik/XLR)
  • Totally discrete input circuitry for high and low level inputs
  • Separate volume controls for high and low-level input adjustment
  • Simultaneous connection of high and low level sources
  • Set-Safe® audibly transparent driver protection
  • Double-sided glass-fibre board with plated-through holes
  • IEC power input socket - non-captive lead for installation flexibility
  • Hand-built in Great Britain
All Trade in items come with a 3 month warranty
For prompt after hours response contact Tivoli Hi-Fi Staff member @jimsan
Edited by Tivoli Hi-Fi
    • By ralphtooby
      Item: REL R305 Subwoofer
      Price: $850
      Item Condition:Excellent
      Reason for selling:Upgrading equipment
      Payment Method: Pickup COD
      Extra Info:Awesome sub in Excellent condition
    • By olegau
      Item: REL-Q150E Powered Audiophile Subwoofer, Melbourne
      Price: 480
      Item Condition:good
      Reason for selling:see description
      REL active 10" subwoofer in Neat Condition and good working order.  The sub amplifier recently was refurbished.  All capacitance were checked to meet criteria.
      Cloth grill in good condition
      Recently Bought a REL R205 sub only because it has the volume panel attached at the front for easy adjusting.  Both subs REL-Q150E and REL R205 provide identical sound. I do not hear any difference. The REL-Q150E goes even deeper to 19Hz compare to the REL R205 25Hz.
      The sub has a 10" Front-Firing Woofer and Sealed-Cabinet Enclosure.
      True 150W (continuous) discrete, direct-coupled MOSFET amplifier Frequency 19Hz – 150Hz Upgraded forward-firing long-throw 250mm (10") steel chassis driver Improved ABC® filtering circuit Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase) Audiophile grade toroidal transformer Slam/depth switch High quality, gas-tight Neutrik Speakon input (high level) High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level) Totally discrete input circuitry for high and low level inputs Separate volume controls for high and low-level adjustment Simultaneous connection of high and low level sources Set-Safe® audibly transparent driver protection Double-sided glass-fibre board with plated-through holes IEC power input socket - no captive leads for installation flexibility Finished in Brittex black in three separate coats with grill Hand-built in Great Britain, three year worldwide warranty Dimensions (mm): 300h x 290w x 380d               The sub got many Awards
      Shipping is fine. Box size is 415(w) x 500(h) x 400(d), weight 16 kgs.
    • By damianclark
      Item: Rythmik F12 SE Subwoofer
      Price: $700
      Item Condition: The actual sub is pristine. The very fine grille mesh has a couple of holes. Easily replaceable if you choose, but barely noticeable
      Reason for selling: Gone for floorstanders in the main rig. Not being used
       This an excellent musical sub. Amazing value even at the RRP
      It's a relist as I got the size wrong last time. This is definitely the correct model (Apologies!)
      I don't have the original packaging, and it's bulky and heavy. Local pickup only.
      Have all the spikes, but I took them off for the photos
    • By Woodear
      Item:          REL Storm III
      Price:        $700
      Item Condition:  Great (On/Off light does not glow)
      Reason for selling:  Surplus to needs
       Only owner since new.  Includes original spikes, manual and original box and inserts.  Great condition.  The green On/Off switch did glow when new but the light stopped working many moons ago.  Used for music almost exclusively on weekends only.  Also used for surround sound, which I gave up after 3-4 years (say 50 movies).
      Includes two cables (only one pictured).  Why two?  I cut the original cable shorter so that it just reached from power amp to the Storm III.  Once cut, I could easily elevate the cable on DIY elevators (big difference in my set up!).  This cable is 2.95 metres (about 9 foot 8 inches) long and has a Speakon plug attached.  The remainder is just cable of 3.05 metres (about 10 foot) long, no plug attached.
      Prefer pick up.   If you want me to courier, the Storm III is huge and weighs some 33 kgs when boxed!  Buyer’s risk if couriered.
    • By Selby Thornbury
      Item: Rel Habitat 1 Powered Sub-woofer White Location: Thornbury, Melbourne. (Local Pick Up Only)
      Price: $500  (RRP $2499) Item Condition: Ex-Display. Excellent Working Order. Some minor marks to finish, but no major dents or deep scratches. Broken Grille  - please note - grille can no longer be sourced as a spare part from REL.
      Reason for selling: Clearance Stock, Discontinued Model.
      Extra Info: Can be viewed in person at the Thornbury retail store before purchase.   Manufacturers Sales Pitch: The Rel Habitat 1 is a powerful slim line sub-woofer of incredible quality.  This sub can be wall mounted or floor mounted & allows wireless communication from the module to the speaker.  It is powered by a massive 150 watt mono-block amplifier and contains 2 x 6.5" drivers and 1 x 10" driver.    Specs and Features:  TYPE: (2) Front-firing active drivers, (1) rear-firing passive ACTIVE DRIVER SIZE & MATERIAL: (2) 6.5 in., 165mm long-throw, steel chassis PASSIVE RADIATOR SIZE & MATERIAL: 10 in., 250mm steel chassis, black cone LOW FREQUENCY EXTENSION: -6dB at 30 Hz INPUT CONNECTORS: High Level Neutrik Speakon, Low Level Single RCA, LFE Single RCA OUTPUT CONNECTORS: N/A POWER OUTPUT: 150 watts (RMS) AMPLIFIER TYPE: Class D WIRELESS CAPABILITY:Longbow, Zero Compression, Individual Discrete D/A and A/D Encoders PROTECTION SYSTEM: Yes - Fully Electronic SET Safe, DC Fault & Output Short MAINS INPUT VOLTAGE: 100-240V Operation FUSES: 1.6A for 230V Operation, 3.16A doe 120V Operation DIMENSIONS (W X H X D): 25 x 16 x 4.5 in. (635 x 406 x 114 mm) NET WEIGHT: 50 lbs. (23kg) FINISH: White Lacquer, 8 coats SUPPLIED ACCESSORIES: Longbow Transmitter, IEC Mains Lead, Neutrik Speakon Cable For Use With Longbow Transmitter and Users Manual.   Condition:  New Open Box Ex Display Unit.  This unit was used for display purposes in a retail environment, minor scratches are present, but no major dents or deep scratches, but has a broken grille.  Broken Grille  - please note - grille can no longer be sourced as a spare part from REL Excellent working condition. Includes Full Manufacturers Warranty   Feel free to ask for more information.
