kfb21Audio
Kevin from Perth
HI
I have had the following audio gear in storage for several years and have now brought it out to review usage or sell (wife very keen on second option :O) )
The gear is Cyrus II Amplifier with PSX power supply and a pair of Celestion SL12Si speakers
I have hooked everything up and it all works but doesn't seem to sound the same as when last used.
However as the only audio source I have is my phone via headphone jack I am not sure what might be the source of this problem.
Given everything is working what kinds of things might need to be refurbished/ replaced to compensate for the years of storage.
Thanks for any advice
This is exactly the problem. No mystery involved.
It would be best to find a decent source in whatever form you prefer. Streamer/dac/ turntable or CD. Keep an eye out for listings in the forum classifieds, but even with new gear it need not be costly for a quality source.
HI Rantan,
So you think the unused time in storage is unlikely to have had a damaging effect. That's good news. This was quite expensive gear when I bought it so its a shame to think it might have decayed
Kevin
Welcome Kevin, I hope your gear comes back to it's former glory and gives lots of pleasure again.
I look forward to your posts.
Sometimes corrosion on the connectors can have an adverse affect on the sound.  Also the climate or the conditions under which the equipment was stored.  I always recommend full plastic wrap and back in the original packaging if possible, removing batteries from the remote controls and always in a cool dry location.
Electrolytic capacitors can deteriorate with age, but I'd investigate other reasons before doing a re-cap job on the amplifier or speakers.
To remove any corrosion from input or output sockets / jacks I recommend DeoxIT.  Works really well and a kit will last you for years.
https://www.jaycar.com.au/deoxit-contact-cleaner-rejuvenator-solution-kit/p/NS1436  I use it regularly on older gear that comes in for repair or restoration.  Inexpensive and cost effective solution to problems related to corrosion (within limits) or noisy contacts / switched etc.  I'm sure you will see similar recommendations from other experienced service persons on this forum.
Alan R.
Not familiar with the SL12'S but we sold a lot of SL6/Cyrus combo's back in the day and it was a synergistic combination.
I would not sell the system as it would, imho, cost a large amount to replace it with something better. The Cyrus amps take up so little space and so as others have said a decent source will brings the system bang up to date in the sound quality stakes.
Usually it is the speakers that seem to annoy women folk :)
There are a couple of good techs in Perth that could give the amp combo a once over regarding the electrolytic and checking bias etc and these day's I tend to recommend Mike at Liquid Audio having benefited from his advice on a number of my own projects.
