synthz
FS: (PRICE DROP) Parasound JC1 - Power Amplifier Monoblock (x2)
Item: Parasound JC1 - Power Amp Monoblock (x2) 400 watts @ 8 Ohm
Price: 6,500 6200
Item Condition: Used
Reason for selling: NLR. Settling in with tubes amp
Extra Info: PICKUP ONLY - NO SHIPPING. Third owner. Age is around 6 years old. Still current model at their product range because it is just THAT good. I would like to sell these rather than being unused because I'm quite content with my tubes amp. Still have boxes available. Even though these are 400w / 8ohms each, Stereophile did a measurement test and the true numbers are somewhere around568w/8ohms each! Very powerful solid state amps that can drive any speakers on planet earth (even Bose!). I used these to power my Dynaudio C2 and they power them without any sweat, even though Dynaudio C2 are famous for being difficult to drive. Happy to provide demo for serious buyers. The amp was designed by the famous John Curl, read up the story about this amp and you will be convinced that this is a serious piece of engineering and they did not skim with the components inside either. There are minor scuff marks on the chassis which is quite normal for amps at this age.
The JC1 runs in pure Class-A up to 25 watts at eight ohms, with its bias set to high and ten watts into eight ohms with the bias set to low.
The sticker that you see on the back panel is from the first owner from repairing a power button and an LED, so it's a very minor repair.
These amps are still being sold on hi-fi stores in Sydney for $9,000 EACH. So grab a massive bargain, it's a no brainer to get it at this price when you could have spent $18,000 for the pair.
FEATURES:
Premier monaural amplifier
Circuitry designed by legendary John Curl and CTC Builder
Ultra-high bias Class A/AB operation
Exclusive two position bias level adjustment
Balanced inputs with discrete circuits and XLR connectors
Vampire Direct gold-plated OFC RCA input
Dual heavy-duty 24k gold-plated 5-way speaker binding posts
Direct Coupled - no capacitors or inductors in signal path
Complementary MOSFET driver stage and JFET input stage
18 beta-matched 15 amp, 60 MHz bipolar output transistors
1.9 kVA encapsulated toroid power transformer
Independent power supplies for input, driver and output stages
18,000 μF filters for driver stage
132,000 µF Nichicon Gold Tune filters for output stage
DC Servo and relay protection circuits
REL and Nichicon Muse capacitors
Harris hyper-fast soft recovery diodes for all bridge rectifiers
Auto turn-on by 12v trigger or audio signal trigger
Ground lift switch , adjustable turn-on delay
4u Chassis with rear carry handles, rack mounting kit included
Premium detachable AWG 12 power cord with silver solder
THX Ultra2 certified
SPECS:
Continuous power output, 20Hz - 20 kHz:
400 watts RMS x 1, 8 Ω
800 watts RMS x 1, 4 Ω
1200 watts RMS x 1, 2 Ω Class A power output, 20Hz - 20 kHz:
25 watts, bias set to high, 8 Ω
10 watts, bias set to low, 8 Ω Current capacity:
135 amperes peak Power bandwidth:
2 Hz - 120 kHz, +0/-3 dB at 1 watt Total harmonic distortion:
< 0.15 % at full power IM distortion: balanced 16 V rms
< 0.03 % Slew rate:
> 130 V/µsecond Dynamic headroom:
> 1.8 dB Input sensitivity:
1 V for 28.28 V, THX Reference Level Input impedance:
100 k Ω S/N ratio:
>120 dB, IHF A-weighted, bias set to high
>122 dB, IHF A-weighted, bias set to low Damping factor:
> 1200 at 20 Hz Power Requirement :
250 watts idle 1280 watts full power into 4 Ω DC trigger output capacity :
+12 Vdc, 150 mA Dimensions:
17-1/2" w x 7-5/8" h x 20" d, 7" h without feet Net weight: 64 lb.
Reviews:
Stereophile: https://www.stereophile.com/solidpoweramps/774/index.html
Home Theater Review: https://hometheaterreview.com/parasound-halo-jc-1-monaural-amplifier-reviewed/
Enjoy the Music: http://www.enjoythemusic.com/superioraudio/equipment/1103/parasoundjc1.htm
Great amps at a reasonable price, they drive the Wilson Alexia's .9ohm epdr bass without a sweat.
But I have to say, to me there's just something "not right" seeing bare feet in a hiend audio ad, then some say I'm too sensitive?:x
GLWTS
Cheers George
End game amps for me, parts of my system have changes over the years, all except the JC1's. Bargain price, GLWTS Synthzy.
Dam, I,m in Perth
2 hours ago, john70 said:
Dam, I,m in Perth
The double box system is very secure and robust, they would come across the country no problem at all.
At one stage they came from America. :)
I concur with this statement.
I've helped take jc1's out of boxes and are extremely robust.
The two big ticket items i own were sent  from perth and were the smoothest transactions so far. I was more shocked how quick it was sent  also.
To miss out on these at an insane price would be very sad if the location was the only thing stopping you.
Glws mate!
Thank you guys, unfortunately when we had few thunderstorms recently the rain projects in a diagonal angle, so a little bit of the bottom section of the boxes got wet. I'm a bit worried that the integrity of the outer box got slightly compromised and not as strong as before. I'm sure the inner box is still strong though.
I'm a bit reluctant on shipping because i'm worried something will happen during transit, unless maybe the buyer want to risk it?
And I found Interparcel to be the lowest cost, and their "carriers" are the expensive ones.
Cheers George
If the boxes are dry and you are happy to put extra packing tape around the boxes , I doubt you would have a problem .
It simple you just need to strap the box if box is not strong enough no big deal.
Also add some strong bubble wrap with gaffer tape.
These are a huge bargain at this price...if you've ever lusted after jc1s, snap 'em up! I concur with Daz, end game amps, amazing detail, smooth and effortless power.
Yep, I kinda lusting over them, would have got these if they were in Perth, but shipping too costly and fear of damage in transit.
O well that life
    • By peppy
      Item: Fostex T60RP Headphones
      Price: $220
      Item Condition: Very good
      Extra Info: It's in very good condition, didn't use much, condition of the item & pads says it all.
    • By beetle-audio
      Item:  Home Theater start up system. Onkyo & Mirage left,centre and right combination
      Price: $350
      Item Condition: - The Onkyo AV receiver TX-SR373 is used but as new.
                                    - The front Left, centre and right are the part of the Mirage AVS-500 combination, unfortunately no speaker grill but in very good used condition
                                    - Comes with power cord and extra cables.
      Payment Method: Pickup only - Cash or Paypal + charges.
      Onkyo Details:
      https://www.intl.onkyo.com/products/av_components/av_receivers/tx-sr373/index.html
      Mirage:
      http://www.hifi-review.com/152269-mirage-avs-200.html
    • By martin64
      Item: PMC 5.21 speakers in Walnut
      Price: $1700
      Item Condition: 10/10 .Only a few months old .Less than 20 hours played on them
      Reason for selling:Bought as surround sound speakers but due to separation moving to a smaller place and don't have dedicated listening room any more
      Extra Info: These speaker present as in new condition.Will suit buyer after new book shelf speakers. Not even played in.  Huge soundstage and plenty of detail. Inspections and demo welcome. Come listen for yourself what the fuss is about.
       Crossover Frequency: 1.8kHz Dimensions: H 340mm 13.4” x W 162mm 6.4” x D 284mm 11.2” - Incl. binding posts (+9mm grille) Drive Units: LF - PMC twenty5 series 5.5”/140mm long-throw g-weave™ cone with cast alloy chassis
      HF - PMC/SEAS®, 27mm twenty5 series, SONOLEX™ fabric soft dome, Ferrofluid cooled Effective ATL™ Length: 1.72m 5.6ft Frequency Response: 46Hz - 25kHz Impedance: 8 Ohms Input Connectors: One pair 4mm binding posts sensitivity: 86.5dB 1W 1m Weight: 6kg 13.2 lbs ea.
    • By lwd
      Item: Audeze LCD2
      Price: $800
      Item Condition: Excellent
      Reason for selling: Too many headphones
      Extra Info: For sale are my Audeze LCD2 headphones. Shedua wood finish, full leather, Fazor version. Sale includes all original packaging including the industrial strength case. Also included is a 4 metre silver plated cable I bought off ebay for about $250 (original cable also included). I am the first owner, purchased from VAF Research a couple of years ago. These haven't seen much use and have been kept under a dust cover. They really are as good as new. They are also the most beautiful headphones to look at I have ever owned. I will miss them but I don't use them enough to justify keeping them. Currently listed at $1399 at A2A and elsewhere.
    • By engineer
      Item: PMC Twenty5.26 speakers
      Price: $8990
      Item Condition: BRAND NEW - UNOPENED / SEALED BOX
      Reason for selling: RAISING FUNDS FOR UPGRADE (MB2se)
      PMC Twenty5.26 in best finish Walnut.
      BRAND NEW  - UNOPENED / SEALED BOXES.
      BARGAIN BUY!
      Firstly, I love these speakers. When I first heard them, I totally fell in love. They have an amazing open soundstage and are second to none in terms of transparency, pace, imaging and dynamics. They have an incredible ability that tells you so much about the music. Hence the reason why this model is so very well known in the audiophile community.
      The upgrade bug has now totally hit me and now have the opportunity to upgrade. I have also kinda convinced my partner also.
      Can arrange pickup, drop off locally in Sydney or can post Australia Wide (at buyers cost).
      Purchased from Lifestyle Store.
      Any queries please feel free to contact me.
