surprisetech
SOLD: FS: Rotel RX-850A Receiver with FM issue
Item: Rotel RX-850A
Price:  $20
Item Condition:  Good physical condition apart from text fading around the power button. Amplifier section and AM reception in good working order, but FM reception is intermittent.
Reason for selling:  No longer required.
Extra Info:   This was the heart of my garage system for a few years until the FM problem came along and it was replaced by a separate amp and tuner of similar vintage.
I intended to try and repair the FM issue, but haven't got around to it and I need a clean out.  At power up there is no FM but on a good day after about 5-10 minutes the FM will start working again.
Happy to post at buyers expense.  Can also deliver to Melbourne Outer Eastern suburbs for a small fee.
I'm interested in this depending on postal cost to Brisbane.
    • By PKay
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Artarmon or Forestville State: New South Wales Payment Method: cash, EFT, Paypal as friend Reason for selling: Not used Further information:  I am selling this amp for my brother - it is in excellent codition with very little use. Postage is available as my brother has the original boxes but local pick up is preferred.  See 3rd picture for little mark which is hardly visible.
       Review from TNT
      There has always been an inherent rightness about the idea of an integrated amplifier. The efficiencies are impressive, the compromises mostly imagined. With the modern additions of display and a properly implemented remote control the integrated becomes all the more appealing. Now there are integrated and then there are integrateds: The sometimes classic (Naim) and sometimes overrated (fill in the blank) British offerings are not what I have in mind. For some reason, the Brits just don't seem to get the fact that an integrated needs real world power to be of real world use. Rotel is a company that knows how build high powered amplifiers, so when I found out that their flagship RA-1070 was said to be happy driving a tough 4 ohm load, I was quick to request a sample.
      The RA-1070 is the latest in a spate of offerings wherein the product's look and performance really threaten a redefining of the high end. There was a time when such a product would have cost well over $2000. While the old guard high end companies have product lines that continually reach higher and higher, the larger mid-level companies seem willing and able to supply more music for the dollar. It may be time to ask why...
      This is a very attractive piece of gear. My review sample is silver and black, but the 1070 can also be had in the more traditional all black. The faceplate of the unit is cleverly designed to suggest a more hefty look through the use of substantial black aluminum handles. In fact, the silver center section of the face is quite thin (as is the top cover) yet the unit looks and feels quite solid. A large motor-driven volume pot dominates the face. When operational, there's an illuminated section that indicates its relative rotational position. In an interesting nod to the days of tone & loudness controls, there's a four position contour control which allows for accentuation and attenuation of bass and treble. I left that control in the off position for all of the evaluation period. The rear panel is well laid out with proper 5-way binding posts situated near the center of the panel making it easy to connect even the most unwieldy cables. The usual IEC 320 connector is used, but in an odd twist, this Rotel floats the ground: This is very likely of no concern in typical use, but could be an issue in systems requiring a specific grounding scheme or extensive use of truly balanced devices.
      The RA-1070 uses a relay as a turn-on/off stabilization device and also as a protection device in case of overheating or shorted cables. The relay can be clearly heard when powering the unit up and down. With the exception of the speaker and contour control switches, all of the RA-1070's functions can be controlled by the superb remote. This is truly a wonderful remote...it can readily learn the remote codes for all of your other gear and allows you to use the Rotel remote to control an entire system. It is also possible to customize the unit's display to indicate associated equipment by specific name rather than type. The only negative that I should mention is that while it is possible to turn the somewhat bright display off, the unit isn't designed to remember that setting. So, the very next time the Rotel is turned on the display again needs to be turned off. This is a real shame as the display off setting is very well implemented. With the display in the off position, the display momentarily illuminates whenever a control is changed. Once the change is complete the display goes out. On a teeny-tiny but slightly tacky note: The motorized volume pot indicates that the RA-1070 is in mute by flashing its position indicator. While effective, I find this solution better suited to products of a lesser pedigree than Rotel.
      Sound
      The Rotel RA-1070 is a very suave sounding piece of gear. Right out of box it has a sound that is relaxed and assured. There are absolutely no hi-fi dramatics to this amp just a competent and musical presentation. The unit looks like it sounds like it functions...sensibly, controlled and without fanfare. The essential test of tone and timber that I like to use first is the Byron Janis. The piano is clear and open with a slightly soft presentation. It is less than muted but less authoritative than it should be. Overall tonality is quite good bordering on excellent. At well over 100 watts into 8 and 4 ohm loads, it sounds even more powerful in use than the ratings would indicate.
      Iris DeMent's voice is possessed of its usual plaintive clarity if again just slightly softened. There was no aspect of the voice's fundamental or attack that was lacking but rather a subtle sense of shading toward the warm and dark. Now, on the period strings of the Corelli, the sound was quite open and pure with an excellent sense of space and air. The guitars of Krushevo were also recreated with an appropriate portrayal of acoustic speed and timbre.
      It is sometimes possible to go too far in one direction and I felt that the Rotel RA-1070 was less prone to this softening when used with my usual digital reference rather than the also excellent RCD1070. It may be that my system's overall resolution requires just a bit more raw musical information that the Rotel combination can create. More than anything, this is likely to be a matter of personal preference and perhaps most importantly the room/system interface. In any event, I appreciate the RA-1070 more when using my reference digital rig and analog.
      Ah, analog
      I will rue the day that there are no more phono stages. One of the most appealing qualities of the Rotel RA-1070 is its lovely phono stage. It is really quite excellent. The Sonny Landreth pressing quickly reveals the essence of a phono stage. First of all, it is dead silent. A noisy phono stage will overlay a hum over the blackness of the virgin vinyl. The phono stage of the 1070 is fully capable of differentiating a good pressing from one made from old combs. The Landreth LP has some wild dynamic swings from cut to cut. The Rotel really handles the range with aplomb. In contrast to the linestage's less assertive style, the phono stage of the 1070 is incisive and full of verve.
      As I got the Rotel RA-1070 ready for the return trip to Rotel, I had to make my system ready for some fairly large, typically high end separates. I was miserable. Not only was I going to miss the functional simplicity of the Rotel and its remote I was already missing the elegance of having all of the voltage gain and current swing in one box. Here I was on my hands and knees looking for interconnects and power cords while trying to fit the new separates into the swollen component rack. There, on the floor, the Rotel RA-1070 was staring at me as if to say, there is an easier way!
      There's just no arguing the fact that using an integrated amplifier makes for a more simple system. What the Rotel RA-1070 proves is that such convenience does not have to come with an unbearable loss of musicality. The 1070 is comfortable with tough loads and very easy to listen to and there is just no way to complain about its design and functionality. Maybe someday I will retire from reviewing. When I do, it will hopefully be an easier and simpler time...a time, I hope, of music. When that day comes it would be a pleasure to spend my time listening to the Rotel RA-1070, the bother and hassle of separate components just a distant memory. Until then, I trust that you'll get out and try to hear the 1070. You may find that the simple life of the Rotel RA-1070 is for you. Highly recommended.
      © Copyright 2003 M. L. Gneier - https://www.tnt-audio.com
      HTML by: Andrea De Marco
      SPECS
      AUDIO
      Response Bandwidth 4 - 100000 Hz Signal-To-Noise Ratio 102 dB Total Harmonic Distortion 0.03 % AUDIO SYSTEM
      Type amplifier Subcategory audio components Functions amplifier Sound Output Mode stereo Additional Features A/B/A+B speaker switch Tone Control Yes POWER DEVICE
      Power Consumption Operational 400 Watt HEADER
      Brand Rotel Product Line Rotel Model RA-1070 Packaged Quantity 1 BUILT-IN DISPLAY
      Type fluorescent MISCELLANEOUS
      Color black Color Category black AMPLIFIER
      Input Impedance 33 KOhm Input Sensitivity 1.5 V AMPLIFIER OUTPUT DETAILS
      Output Power / Channel 100 Watt Output Impedance / Channel 8 Ohm Frequency Response 20 - 20000 Hz Total Harmonic Distortion (THD) 0.03 % Channel Type main Channel Qty 2 INPUTS & OUTPUTS
      Headphone Jack Yes REMOTE CONTROL
      Type universal remote control Remote Control Technology infrared ACCESSORIES
      Remote Control Type Universal remote control - infrared Features LCD display, learning AUDIO SPECIFICATIONS
      Type Amplifier Frequency Response 4 - 100000 Hz Signal-To-Noise Ratio 102 dB POWER
      Form Factor internal BATTERY / POWER
      Type power supply CONNECTIONS
      Qty 1, 2, 3, 4, 7 Type audio line-in, audio line-out, headphones, network, phono input, preamplifier out, remote control, speakers output, trigger Connector Type RCA x 2, RJ-45, banana/spade x 2, phone stereo 6.3 mm Connector Location front, rear DIMENSIONS & WEIGHT
      Width 16.9 in Depth 14.2 in Height 4.8 in Weight 22.71 lbs GENERAL
      Manufacturer Rotel of America
    • By Naz.shr
      Item Condition: Good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal, Cash on pickup Reason for selling: Surplus Further information: fantastic sounding integrated amp Rotel RA-971 mkii
      1x set of pre-outs suitable for active subwoofer or add on power amp
      Power output: 60 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 100kHz
      Signal to noise ratio: 95dB (line)
      Dimensions: 440 x 92 x 347mm
      Weight: 6.5kg
          This was one of the last amps Rotel made in the classic 90s slabby black/austere casing, and it's a gem.  Rated 5 stars by What Hi*Fi and highly praised by a lot of other press.  These are now very rare. I also have the original owners manual
      A review by Australian Hi*Fi can be found here:  http://www.rotel.com/sites/default/files/RA-971 MKII Australianhi.pdf
    • By Naz.shr
      Item: Budget CD Player in good working order
      Price Range: 150 - 350
      Item Condition: Used
      Extra Info: Looking for a good condition used CD player from reputable brands - NAD, Rotel, Marantz, Denon etc. Currently using a cheap Sony cd player model CDP-397 and looking to upgrade to a better player. Bought a 5 disc sony player recently and had to get rid of it as it produced a loud hum.
      I am in Perth (6060) Thank you.
    • By JaJo
      Hi folks, I currently have a Rotel RCD 965BX CD player (coupled to a HK 6500 integrated amp and a pair of JBL L80t3 speakers), and considering buying something new, namely the Rotel RCD 1572 at around 1,200 AUD. Will it be a better CD player (uses a Wolfson DAC)? Do I need to spend that much to upgrade? Grateful for your thoughts. Thanks a lot, Jaime
    • By RBN1
      Item Condition: Excellent - Both Unit & Remote Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Western Suburbs Melbourne State: Victoria Payment Method: Reason for selling: Have moved to Primare seperates Further information:
      Both the unit and remote control are in excellent condition. Comes with original Remote control, printed manual and power cable.
      Extra Info:  The RSP-1570 has 4 x HDMI 1.3 inputs all with 1080p/24 Hz compliance, including 3D bypass, a dual 32 bit DSP processor and 24 bit/192kHz burr brown DACs. It supports Deep Color and xvYCC video options. Comes updated with all the latest firmware for Video Scaler, Audio and Processor. It also features separate speaker/sub crossover and delay settings, “lip synch†delay, 8ch analogue multi-input with sub pass-through or sub redirect feature and pure analogue bypass mode. 6 assignable 12-volt triggers, multiple IR connections and multi room zone outputs.
      Features & Specifications:
      Decodable input signals: Dolby Digital, DD-EX, DTS, DTS-ES, DTS 96/24, DTS ES 96/24, 192k LCPM, Dolby TrueHD, DTS HD Master.
      Dual Sub Outputs
      Pure analogue bypass mode
      DVD-A auto detection
      “Lip synch†delay
      Audio Inputs: 3 coaxial, 4 optical, 8 analogue stereo, 1 analogue multi-channel (7.1 with bass management)
      Video Inputs: 4 HDMI (ver. 1.3) 3 component, 3 composite, 3 s-video
      Audio Outputs: 1 coaxial, 1 optical, 3 analogue stereo
      Video Outputs: 1 HDMI, 1 Component, 3 composite, 3 s-video
      Pre-Outs: 10 at 1v (dual centre outputs, dual subwoofer outputs)
      RS232 Port
      4 independent Zones
      Dimensions: 144 mm H x 431mm W x 335mm D
      Weight: 9.6 kg
      Colour: Silver finish.
      Full details and specs:
      http://rotel.com/sites/default/files/product/infosheets/RSP1570_InfoSheet.pdf
      Owners Manual:
      http://rotel.com/sites/default/files/product/manuals/RSP-1570-OM.pdf
      Reviews:
      http://www.soundandvision.com/content/rotel-rsp-1570-surround-processor-and-rmb-1575-amplifier#1AFhwpMMBZRHvUxw.97
      http://hometheaterhifi.com/reviews/receiver-processor/processors/rotel-rsp-1570/
      http://www.avrev.com/home-theater-preamplifiers/av-preamps/rotel-rsp-1570-7.1-processor-preamplifier-.html
      Dimensions Drawing:
      http://rotel.com/sites/default/files/product/drawings/pdf/RSP-1570.pdf
