muzika
Blown Amp! (Classé 15) and Faulty Speaker (Gale 401C)
Oh interesting, good to hear. Valve Audio Predator? Hybrid integrated, that rating was my understanding but I’ve contacted the company to get a copy of the manual for some more details.
Good amp mate. Valve/transistor or Hybrid amp. 200watts into 8 ohms but cant see any spec driving 4 ohm or what the current ability is. Should be fine :thumb:. Listen to the music.
And use common sense.
Appreciate the vote of confidence mate. Amazing what some headroom can do.(Only issue is a hum through the speakers that I’ve put down to a valve that loosened in travel - will be opening up soon to have a look.)
Thanks :thumb:
19 hours ago, Wimbo said:
Can you still replace those Tweeters Oz? I recently bought a pair of "A"s and one of the best speakers I've heard.
Short answer is no,longer answer perhaps if you can find one on ebay or speak to the guy here : http://www.vintagegale.com
who should be able to point you in the direction of modern replacements.
It makes me a bit sick to say but looks like this will be a $600 lesson. 10 output resistors blown, plus some drive transistors, I'm told.
The damage is on the channel which I had unplugged from the speaker but still connected to the amp (d'oh). Most likely the loose plugs touched and shorted, right?
Assuming this amp / speaker pairing is sound and I can get both units back to good health, I'd ideally stick with this setup for a few years to come.
Can anyone see any reason I wouldn't go ahead with this repair job? (...besides 'You're an idiot. Stick to a Bose soundbar you can't destroy.')
It's a good amp by all accounts and worth spending the money on. While he's in there you may as well change out any old/suspect capacitors etc as well as check solder joints etc.
A $600 lesson is one you won't forget!
