gat474
Speaker sensitivity comparison
This might be simple but a quick google search revealed various opinions and even arguments.  I'm trying to work out which is the most sensitive speaker comparing the two different measurement values.
4 ohm speaker with a sensitivity of 92 db at 1 watt at 1 metre vs
4 ohm speaker with a sensitivity of 84 db at 2.83 volts at 1 metre.
Both are car speakers.
Is there a simple answer or is it all in the maths?
No difference between '1 watt at 1 meter' and '2.83 volts at 1 metre'.
2.83 volts = 1 watt of amplifier power.
Thanks for the answer. I did read that but there seems to be lots of differing opinions.
So, in terms of sensitivity between these two car speakers one’s very inefficient compared to the other.
Yeah, 84 is pretty low, and 92 is much better in terms of sensitivity, if the manufactures specs are correct.
Yeah, we’ll I doubt the accuracy of the specs to be honest. Who would sell a car speaker that was so inefficient and expect people to buy it against something with a much higher rating?
Soinds like some marketing magic to me.
2.83 volts = 1 watt with respect to an 8 ohm load. Power will be greater than 1 watt (double, or 2 watts) into a 4 ohm load at 2.83v.
SS
So, if both measurements are for four ohm speakers does that make any difference?
SS
Ah, very true, and these are both 4 ohms.
The lesser one is then much lesser than the stated 84db sensitivity if this is the case? Maybe 81db?
Edited by Muon N'
81 dB is very low, I own atc’s which are inefficient but are much more sensitive than 81 db.
