reflux075
Changing My Room Acoustics
Hi peeps,
I have recently changed speakers and after a few months of moving them around to try and get the best placement I have discovered something quite frustrating.
The bass gets cut off ONLY at my listening position. The moment I stand up from the couch, the bass is all there, sit back down and the bass is gone.
I have tried moving the speakers right back against the wall, I have tried moving the speakers reeeeally forward, and it does not help.
I know my setup is not ideal but I don't really have to much chance of rearranging the room, peace with SWMBO is much better than bass.
I'm thinking I need some sort of room treatment?
I have never done any of this before and would appreciate some suggestions as I do not know my bass traps from my reflectors.
Some pics of my listening area below.
Given you cannot re-arrange the room because of WAF, I doubt you can do room treatment to address your bass null at the listening position.  Bass traps work best on corners and are large, but often not acceptable in a shared room. Alternately, adding a sub or two wth DSP can improve things.
Ideally, you should measure your room and understand it before taking the next steps. But you can also hire someone like @Red Spade Audio (who is Melbourne) to advise you on what can be done.
Measuring Euipment, Subwoofers, Integration, EQ, Positioning, Room Treatments.
Had a similar situation recently where listening position was terrible but move a metre and all good. unfortunately the seating position couldn't change.
Speakers have been in a few houses and never a problem until this house.
Measuring, EQ, sub, placement, some absorption panels and nothing helped. Spun everything 90 degrees onto a different wall and it's back to being pretty much perfect. Can plonk speakers anywhere, sit anywhere and it is really nice.
The other issue is in your hands
If your description is correct then agree with those above that treatment is unlikely to help your bass deficiency at the listening position. I have listed some strategies which you can do yourself loosely in order of cost and difficulty.
If you can move things more than you have already then that may be worth trying first . One "hack" is to place the speaker at the listening position and play some music and stand in the various positions you have available for speakers to go and find the spots with the best bass and plonk the speakers there. Whilst not perfect its probably as good as it will get without moving to stage 2.
Stage 2 is to get a sub and plonk it somewhere and see if it helps. A better way would be to do the same as above except with sub at listening position and try various possible spots for the sub. THeoretically it could be anywhere, front side back as long as the crossover freq is low enough. if that is not good enough move to stage 3
Stage 3 is to measure the room using a measuring microphone and software, determine what frequencies are missing from the listening position  and then set up a sub and remeasure and adjust sub settings and position until optimal. still not happy? time for stage4
Stage 4 would be to also use something like Multi sub optimiser software (oh yeah , need another sub) which will calculate the optimal settings for your subs  (oh yeah , need dsp as well),
There are also commercial bass management units, I havent tried those but many here have, hopefully they will chip in on their usefullness for your situation.
Of course you could call in someone to measure and suggest for you
Thanks for all the suggestions everyone! I will make my way through all of them. I was trying to avoid getting a sub, just sold mine actually haha. It might be the easiest option for me right now though.
There is another option.  Speak to Peter at DeepHz about one of these
http://www.deephzaudio.com/DSPeaker product index.html
The Anti-Mode 2.0 is used by a number of people here and may do the job.  If you have the budget, go for the Anti-Mode X4.   The DSPeaker products are easy to use.  Peter is in Melbourne and does offer home demos.
Thanks for the mention Snoop!
It's likely the problem is with the listening position relative to room boundaries. Bass traps won't significantly improve the situation within practical limits.
Best options:
1. One or more subs in strategic locations to fill in the missing bass. Keeping in mind that subs can come in different shapes and sizes to fit the space.
Here is one example of that approach:
Black line in this example are very large mains with dual 12" woofers. The sub used here was tiny in comparison with a 10" driver. The right position (and a little EQ) here delivers what physics (and bad luck) prevents the much bigger mains from delivering.
2. "Nearfield" sub, placed right behind your listening chair.
Due to proximity, the room has less impact on the response of the sub, which tends to reduce those big dips. This solution might sound simple but I typically consider it a last resort when all else fails, because it can also tend to localise. In other words, you may actually hear bass coming from behind you, which is distracting when it happens. Many subs will not work in that position for this reason, so it's an option you'd want to trial before buying.
3. EQ to your mains.
If you have sufficient headroom, in some cases EQ added to your mains can resolve the issue well enough. In most cases, you simply won't have the headroom.
Some choose a "coffee table sub." This can work with with either approach 1 or 2. Here is an example of a coffee table sub that worked well:
Black = front corner sub
Red = same sub hidden under an existing coffee table to the right of the main couch
This was a home theatre room and using a coffee table sub to the side filled in the missing midbass region around 40 Hz. The bass in movies became dramatically more dynamic as a result.
Key point is that measurements show you very clearly what is happening and they also point to workable solutions for your specific room. It's also a very good idea to use them to integrate the solution chosen or validate the results of any correction system used.
If you stand up and the bass comes in 'full' could it be a consideration to sit the speakers on a solid plinth to hear how that changes the bass. This will very likely affect the upper frequencies and screw up the dispersion but could possibly 'tilt' the speakers back to aim 'down' to the seating area.
Maybe try 300mm lift?
Thanks @Snoopy8 and @Red Spade Audio, I was hoping to avoid DSPs and EQs and Subs if possible. I guess I wanted to know if room treatment will help my issue but I guess it will not really help.
@WasM, you are the second person to suggest I try aiming the speakers down, I will try this but need to maybe change the front spike shoes as I don't have much to play with on the front spikes after leveling the speakers.
Also don't think I can raise it by 300mm, seems like quite a height increase!
I did try some extreme toe in suggested by someone and it did help the bass but I also got a splashiness with the top end on some songs that was not there before. Can't win haha.
One can only try... and since it takes a small effort at no $ I would have a go.
Grab some spare wood, bricks or anything suitably sturdy to elevate the speakers, then adjust toe in and angle.
With bass problems, you have to move speakers and or listen position a lot to generate a difference.
Doing this by ear is difficult. As a bare minimum you could use a pink or white noise LF signal on both speakers at the same time and walk around the room and map the spots that show the most stable reading.
Room boundaries produce problems at 1/2, 1/4, 1/6 of the room dimensions and speakers needs to be placed in such a position to try and fix a problem, and seating positions need to be moved away from such dimensions.
Try and find out which arrangement gives you the least nulls/dips, as those can't really be EQ-ed. Peaks are easier to deal with using EQ.
Have you tried a non semitrical setup? As that can help dealing with near room boundaries that are speaker-wall related.
As you've heard the general rule for getting bass right in a room is positioning, then room treatment. Positioning can also include using one or more subs and getting their position right.
This is the arrangement I use:
http://www.barrydiamentaudio.com/monitoring.htm
It's called 'The Thirds' but you could also do 'the Fifths' and the results should be similar. Try it as an experiment just to hear what it can do.
Room treatment for bass involves large boxes of the order of 40cm square sitting in two or four of the wall-wall corners.
None of the above seem practical for you.
One possibility is to move the speakers (and listening chair if possible) to their ideal location just for listening, and then store them out of the way when not in use. Place them on some sort of roller bearings (such as used for washing machines for example).
If you can't do any of this then DSP is the only other solution. The Anti-mode has been mentioned. There are also various forms of MiniDSP that could suit you. Whilst in principle you may not like DSP/EQ but any possible detrimental effects (I use a Behringer DEQ2496 and find no ill effects despite what others say!) will be far outweighed by a good DSP implementation.
That is a lovely space you have there.
I am thinking you are gong about this the wrong way. Forget all the rest and get a system that was made to work in a typical multipurpose compromised home listening space like you have. Look at the Kii three or similar where you can place the speakers right against the back wall. You can get rid of amps etc and reduce the box count while getting better sound quality.
Room treatments, DSP etc are fantastic tools, but can be hit and miss unless you really know what you are doing and prepared to spend time measuring and testing. For a space like that they can also present aesthetic challenges.
Agree Kii would reduce box count but not sure putting it in back wall will work?  It is still a speaker and placement is still important to get the best sound.
Thanks for the nice compliment @AudioGeek
I do not think I am ready for active speakers just yet, I am loving my tube pre and power amp setup ATM.
I did hear the Kii3s at the HiFi Show and did not like their sound, I prefer a warmer sound, like the Meridian actives at the show.
    • By deakinxd
      Hey guys,
      I have recently decided to embark on a DIY bass trap build.. It seems most people in Australia have used the Polymax Absorb XHD 100mm batts. I have just contacted my local insulation store and they stated that the Polymax will take at least 2-3 weeks to build and get shipped to the Gold Coast. The guy I spoke to suggested the Bradford Supertell Glass Wool http://www.bradfordinsulation.com.au/commercial-and-industrial-insulation/underslab/industrial-board-blanket/supertel which they have in stock and sell for $230 for 2 pack of 3 x 1.5m (100mm thick). I have no idea about the performance of this product and I was wondering if anyone could shed some light as to whether it will be similar in performance to the Polymax (particularly in the low end obviously).
      Thanks in advance for any help!
    • By mwhouston
      I have never seen a scientific study on the matter or even read an in depth discussions by respected reviews but what do you think is the most critical comment in any system? I could be funny and say the room or listening area. But I think we all accept, regardless of treatment, construction or design the room plays a huge part in the final balance of your overall sound. But let's ignore the room. And look at the gear.
      I'm going to cut to the chase here and say I agree with one comment I read quiet some time back that the most important component(s) is both ends. Yes more than one (not counting the room). If your media player sound is not upto scratch the final sound will never be "perfect". Looking at the other end, regardless of the rest of the audio chain if your speakers are rubbish the rest of the gear doesn't matter. So I do believe that it is both ends which are critical. I have even read that most preamps and powers (and cables if you think about it) will do a reasonable job. Provide you have top notch gear at both ends you have s good system. Right?
      Now I have to say that the biggest change and improvement I have heard in my system has come about by changing my power amp. The bit that is not meant to matter. Well it does. At lest it does for me. I have had some fab. comments from many others how good my system sounds will all my other gear in place. I loved it too and thought it unbeatable. The sound I like in my listening room. But the replacement of my power amp with a DIY Sure Electronics based Class D amp has totally change the sound of my system. And for the better by a mile. The power amp had in place was a very expesnive DIY 300B so no slouch.
      When I upgraded the Xovers in my DIY 2-way speakers to a third order I felt a huge lift in soundstage, focus and clarity. But still the single biggest change I have ever experienced is the inclusion of this 500W Class D amp I call ROBUSTO. Is it just the massive power or is it the new, now matured, technology?
      Let me know what you think is the most critical gear in any system.
    • By Sub Sonic
      Hi All,
      Having recently bought a Dayton Omnimic V2 measurement system (thanks to site sponsor Paul Spencer/The Loudspeaker Kit), I thought I'd start a discussion thread for those learning how to use it.
      It certainly seems like a capable piece of kit, but I have a long way to go to become proficient in it's use. Hopefully other forum users could help those of us who are keen to learn, helpful tips and hints as well as pitfalls for the unwary.
      The kit comes with the USB microphone, a very small tabletop mic stand, 6' USB lead, case, software disc and test tones disc. The test tones are tailored specifically for use with the system. There is a 60 page Help Manual on the software disc which seems pretty comprehensive.
      Discussion of other measurement systems or methods are also welcome.
      Regards,
      SS
    • By slightlybrown
      Good morning … just a quick introduction … well probably long and rambling if the truth be known !
      I've spent over 35 years in the music industry, as a recording engineer, studio designer, commercial and domestic installer/system designer, and most recently, vinyl record cutter.
      I've never been musical in the "read, write & perform" sense, but have a deep appreciation of music, and how music & "sound" can affect us physiologically and emotionally.
      That's led to a bit of a life long quest:  To get that special "musicality" out of each and every audio system. To more than adequately recover the beauty, detail, weight and musicality of every performance for the benefit of our very hearts and souls.
      If I had an official title, and should the word even exist, I'd be an "acoustician" first and foremost, having realised many years ago, that the room is actually part of the system.
      With that in mind, as well as system components and their optimization I practice optimization on the room itself, and room acoustic qualities (or down falls !)
      I hope I can assist some members grappling with "boomy bass" and "floppy bottom" isues ....
      Karl.
