Toyboyo
SOLD: FS: AYON AUDIO HA-3 Single-Ended-Triode Headphone Amplifier
Item: AYON AUDIO HA-3 Single-Ended-Triode Headphone Amplifier
Price: $$$#^))
Item Condition: Mint
Reason for selling: NLR
Payment Method: Pickup or Delivery cash/EFT on pick up
From 6Moons:
"Among direct-heated triodes -- and shy of leaving the reservation for types only the truly obsessed have even heard of, never mind listened to -- 45s are legendary and by some considered what 300Bs and 2A3s can only aspire to"
Shipping Dimension: 50.00cm x 50.00cm x 30.00cm      20kg
REVIEWS:
https://positive-feedback.com/audio-discourse/ayon-audio-ha-3-set-headphone-amplifier-focal-utopia-headphones/
http://highfidelity.pl/@main-709&lang=en
From Ayon Audio site:
The HA-3 was developed for headphone lovers searching exclusively the very special music experience.
It impresses with it’s Single-Ended-Triode technology taken to its respective extremes by Ayon in all their products. Selected in-house AA45 Mesh super triodes,
the perhaps most perfect and best sounding low-power triode for headphone amp design, are applied in combination with special super-permalloy wound output transformers.
At the HA-3 deliberately all useless gimmicks have been omitted.
The HA-3 is designed without compromise in its circuitry as well as in its power conditioning;
therefore, a separate top-class power supply was inevitable; on the one hand it guarantees extraordinary voltage and current stability and lowest hum.
With its powerful, airy, and lively play, paired with a superb spatiality with emotional reproduction the HA-3 drives every dynamic headphone to absolutely maximum tonal performance.
From treble in brilliant resolution to absolutely authentic colourful mid-range and a deep resilient bass.
At the same time, it fascinates by its incredible ease, closeness and control at any kind of reproduction that is second to none
Features & Design:
Full-featured pure class-A tube stereo headphone amplifier
Vacuum Tubes : Ayon AA45 Mesh power output tubes
The choice of signal and power tubes have a significant influence on the sound and hence on the inspiration and joy of listening.
This is not only the decision between good and bad tubes but finally the interaction of the different types of tubes and their combination that are used in the various Ayon amplifiers.
Signal Path
We believe that the simplest circuits work best together with the shortest signal path.
The shorter the signal path is, the less possibility of sonic degradation from various sources, including the wire itself.
Even on the circuit boards, the copper traces are kept to a very minimum length.
The completely redesigned circuit board provides a more straightforward and direct approach to the signal paths.
● Logical sequenced soft-start power up for extended tube life
● Ultra short signal path
● Simplest direct circuit path for purest musical sound and high reliability
● No solid state devices in the signal path
● High current and low impedance design that operates tubes in the best areas their curves
● Automatic bias adjustment
● No followers or buffers in the signal path
● Quality parts throughout
Power Supply
The power supplies have been further refined with new components and enhanced AC line noise filtration.
Separate power transformers, chokes and filters provide total isolation between the input and output stages which makes this a pure power source.
We also use electrolytic capacitors with much larger storage capacity to make up for the loss in filtering when using resistors in lieu of inductors.
● Low noise –insulated power transformers
● Power transformer is excellent damped and RFI/EMI shielded
● Innovative power supply provides a high speed energy delivery on transients
● Choke filtered power supply
● Separate and isolated power supplies over each stage of amplification
● High current filament-regulator for pre/driver tubes
● Regulated DC filament supplies with soft start
● AC power line filter to avoid noise and hash from entering into the unit.
Output Transformer
The super-wide bandwidth output transformer’s major strength is that it can deliver the current in the bass,
while at the same time maintaining the speed in the high frequencies, dramatically improving the square wave response of the amplifier.
The effect is a much more natural and relaxed sound with much better clarity, resolution and fluidity.
● Super-wide bandwidth high performance - super permalloy output transformer
● High efficiency with low insertion loss for optimal current and voltage transfer
● Multiple tight layering and coupling for extended frequency response
● Output transformers are sealed with an anti-resonance compound material
Components
The type of parts used therefore must have a synergistic relationship to the circuit they are placed in.
It is this relationship of which type of part to use where, that ranks our products apart from the mass.
● Selected, quality passive components used in all applications
● High speed & high quality audiophile grade coupling capacitors
● Special tube sockets with beryllium- copper spring pins, custom made by Ayon
● High quality – RCA input jack
● Special isolated - internal wiring
● Copper matrix - internal signal cable
● Gold-plated industrial grade PCB
Mechanical Construction
The high grade aluminum chassis impart a richer, more lustrous tonality with a cleaner background and less hash and grain.
All brushed anodized anti-vibration-resonance and non-magnetic chassis’s are fully hand assembled to insure the highest level of craftsmanship.
● Improved heat ventilation chassis
● Custom-made machined control knobs
● All front & rear panel descriptions are engraved
● Chassis finish: black / black
Edited by Toyboyo
Really would like this to go to an SNA member and I will give them a better price.
Edited by Toyboyo
bump... this amp may look simple but the tubes on this make it very special... l
as well as the transformers ....the units weigh in at 20kg
    • By d_caruso
      Item: Genelex Gold Lion 12ax7 tube - gold pins
      Price: $48
      Item Condition: As new
      Reason for selling: surplus
      Payment Method: EFT by mobile
      Extra Info: This is the gold pin version. Current production Russian made tube. Bought new for project but never used.
    • By d_caruso
      Item: Telefunken 1950s red tip medical 12ax7 tube
      Price: $190
      Payment Method: EFT to mobile
      Extra Info: Ribbed plates. Tested as a new tube from person I bought it off. I only tried it out for an hour or so in my phono stage. Clear, detailed Telefunken sound with stacks of separation and a huge soundstage. A really 3D tube in my setup. Very quiet.
    • By mrf0ster
      Item: PrimaLuna EVO 400 Tube Integrated Amplifier (EL34) Black
      Price: $5000.00  ONO (RRP: $6995.00)
      Item Condition: MINT (UNMARKED with ALL ORIGINAL PACKAGING)
      Reason for selling: Change in personal circumstances
      It is with the utmost regret and disappointment that I am selling this tube amp. Due to a change in personal circumstances I can no longer enjoy the sweet sweet sounds. (This amp is only 5 months old.)
      I am open to any reasonable offer.
      Thank you.
      Product Description:
      https://www.primaluna-usa.com/primaluna-evo-400-tube-integrated
    • By robio_d
      Item:  Custom Lampizator Amber 2 R2R & Volume Control
      Price: $4800AUD - Won't go any lower.
      Item Condition: Mint/Near New
      Reason for selling: Change of direction
      Pretty much NIB Custom Lampizator Amber 2. This is no ordinary Amber 2 though, with the same R2R DAC board from the Atlantic, 44khz Super Clock, 5v 5Y3 Rectifier, the Baltic Analog output section with 6N6P tubes, remote volume control with analog in and dual parallel analog outputs, rca spdif, toslink, BNC and USB - The works! I was informed by the NZ dealer that the final tuning was done by Lukasz himself.
      I had this delivered in Feb 2019, with big plans for an entire new system based around the Lampizator, but life circumstances changed and I have downsized my system significantly. It had approx 1 months use and has been boxed since then. I was hoping to put it back in the system, but time to let it go to a home where it will see the use it deserves.
      This is a very flexible and amazing sounding DAC/Pre that can be the control centre of your entire system. The lampizator sound is in full effect: detailed, musical, smooth, big and what I can only describe as expensive sounding. I have fully tested prior to listing and everything is 100%.
      The Lampizator is an absolutely mint condition with both Factory warranty stickers intact, which means there is over 4 years to go on the Lampizator transferable warranty.
      The Power supply is switchable between 230v and 115V so good for the most of the world.
      If you are in the market for a new Lampizator Amber, get this instead and grab $2400nzd of upgrades for free for less than the price of the current Amber. I'll even throw in an extra set of 6N6P and an extra 5Y3.
      Shipping to Aus would be approx $250 AUD.  I'll go halves on PayPal fees.
      Will consider trade/exchange for a banging set of higher power Tube Mono Blocks - for those that would love the DAC but don't have $5k sat around BUT (like most of us) have a bunch of extra gear collecting dust   If you have something post in the comments and I'll check em out.  Looking for 60W plus.  Not looking to spend extra so must be lower, on or marginally over the price.  So no $15k amps unless your willing to drop a $hit ton and give me a nice xmas pressie!
    • By lenticularis
      Item: Alex Cavalli Tube Hybrid (CTH) Headphone Amp
      Price: $240 incl. postage
      Item Condition: 9/10
      Reason for selling: Recouping $
      I've had this amplifier for about a year.
      I've driven both Massdrop Sennheiser HD6XX and Nuraphones (corded) through it, either streaming Spotify and Tidal, or CDs played through a desktop Teac DR-L700. Recently also used with a Schiit Modi 3 DAC.
      It comes with the original switched mode PSU with a US form-factor prongs.  It's my first valve-based / hybrid unit. Its character is both detailed, with a revealing soundstage, but also has that softer relaxing valve character that makes extended listening a pleasure.
      Valve-swapping ('tube-rolling') is of course possible with this.
      The fit and finish of the CTH are exemplary and its neat dimensions means that it doesn't occupy much desk-space.  The surface finish is a satin black that doesn't mark easily from fingers.
      The connections have a quality feel also. It has both a normal 6.3mm jack and a balanced (4 pin XLR) connection.
      The original packaging is good quality and makes for easy and secure posting.
      Drop (formerly known as Massdrop) current pricing is US$250 plus shipping and of cpurse the Gerry Harvey import tax (10% or so).
      Useful links:
      Head-Fi link
      Massdrop link
      Photos: Advertisements without photos of the actual item will not be approved.s
