SirJack
SOLD: PrimaLuna ProLogue Premium Pre & Power Amplifier
Item:                          PrimaLuna ProLogue Premium Pre-amplifier & PrimaLuna Prologue Premium Power-amplifier
Price:                          $2,500 Firm for both Pre-amplifier & Power-amplifier. Don't want to separate
Item Condition:         Excellent Condition
Reason for selling:   Too much gear, not enough time
Payment Method:     Pickup - Cash, Bank Transfer, PayPal + Fees
Extra Info:  Original Double Box & Remote for Pre-amp.  2 Different Tube cages. Stock PrimaLuna tubes
                    No Box for Power-amp. TUNG-SOL KT120 Power tubes.  Pick up only from Glen Waverley
I believe these are the best Valve amps on the market for durability, reliability, build quality, versatility, value and ease of use
Auto Bias. Bad tube indicator
Fantastic amps for tube rolling. 12U7 signal tubes-the most prolific & inexpensive tubes available
Power amp can use
  • For 12AU7: ECC82, ECC802S, E82CC, 5814, 6189, CV4003
  • For KT88: 6550, KT90. You may also use EL34, 6L6GC, 7581A and KT66 though power will drop
    slightly.
  • For EL34: 6CA7, E34LS, E34L. You may also use 6L6GC, 7581A and KT66 KT120  KT150
PrimaLuna® ProLogue PremiumEL34/KT88 Switch
The ProLogue Premium Stereo Amplifiers—as well as the Premium Integrated and Mono amplifiers—come with an EL34/KT88 bias switch. This means that by the flip of a switch you can choose the optimum bias setting for EL34s or KT88s. No hassle with screwdrivers, no messing around with meters etc. If you swap tubes, simply flip the switch for optimum bias!
And should you use the “wrong” bias setting for the tubes in use, don’t worry. It just means you did not choose the “optimum” bias setting as decided by the PrimaLuna design team. Some PrimaLuna owners even like to “play” with this switch to see what is the optimum bias setting for their circumstances and some go even further and play with this switch while having a mix of EL34 and KT88 within one channel. All is possible due to the PrimaLuna Adaptive AutoBias Circuit.
Power Amp can operate in Stereo or Mono at the flip of a switch
This PrimaLuna ProLogue Premium Stereo Amplifier features:
  • Hand-made construction with the finest point-to-point wiring, using workmanship that is equal to orbetter than any product you can buy at any price.
  • A heavy-gauge, fully-vented steel chassis with a five coat finish. Each coat is hand-rubbed andpolished.
  • Premium parts that include a toroidal transformer for power supply; custom designed -inconjunction with one of the most prestigious transformer designers in the USA- encapsulated output transformers the quality of which fits nicely between standard ProLogue and DiaLoguetransformers; wide bandwidth for great bass and extended highs; ceramic tube sockets; ALPS volume control; Nichicon and Solen capacitors; superfast Philips-diode-circuitry; gold-platedheavy duty WBT style speaker terminals (all speaker connectors are solid shaft, without hole, forbetter conductance, better sound and higher reliability); gold-plated panel mounted input jacks.
  • SoftStartTM circuit for extended life of sensitive components, plus a reduced chance of tube failurefrom thermal shock.
  • A new generation Adaptive AutoBiasTM exclusive to PrimaLuna. This circuit monitors and smoothlyadjusts bias constantly and instantly, reducing maintenance and increasing performance due to the dramatic reduction in distortion. It comes with a new extensive output stage protection circuitry with +B relay to protect output transformers, resistors and high voltage power supply in case a tube fails. In all ProLogue Premium Amplifier models the new generation Adaptive Auto BiasBoard comes with our new BTITM circuit. BTITM stands for Bad Tube Indication (by LEDs), makingtube-life again a bit easier.
  • The ProLogue Premium Stereo Amplifiers as well as the Integrated and Mono amplifiers come with an EL34/KT88 bias switch. This means that with the flip of a switch you can choose for the optimum bias setting for EL34 type of tubes or KT88 type of tubes. No hassle with screwdrivers,no messing around with meters etc. Just switch tubes, switch bias!
  • No more 12AX7 tubes in the ProLogue Premium range of products. Instead of a 12AX7/12AU7 combination in each channel, we use a double 12AU7 combination. Lower distortion levels, higherlevel of sound quality. Distortion levels in the first stage have dropped with a factor of 5 at low levels to at least 20 at higher levels, above 1V.
    Specifications • Power .................................................................................................................................................................................................................. 35 Watts per channel
    Frequency Response
    ........................................................................................................................................................................ 9Hz - 130kHz -3 dB
    THD with AABB
    ............................................................................................................................................................... less than 1% at rated power
    S/N Ratio................................................................................................................................................................................................... 75 dB flat; 92dB WTDA Input Impedance .....................................................................................................................................................................................................................100 kOhm Input Sensitivity .............................................................................. 600 mV (for rated power at maximum volume setting) Maximum Gain ....................................................................................................................................................................................................................................... 28 dB Power Consumption ......................................................................................................................................................................................................... 255 Watts Net Weight ............................................................................................................................................................................................................... 49.5 lbs / 22..5 kg Shipping Weight................................................................................................................................................................................................ 58.4 lbs / 26.5 kg Dimensions ..................................................................... 15.4" x 14.4" x 8" / 390 mm x 365 mm x 202 mm (L x W x H) Shipping Dimensions ................................. 22.7" x 18.4" x 12" / 577 mm x 468 mm x 305 mm (L x W x H) Inputs ........................................................................................................................................................................................................................... 1 pair Stereo RCA Outputs................................................................................................................................................................................................... 4 & 8 Ohm Speaker Taps Tube Complement .................................................................................................................................................................................................................. 4 x EL34
    4 x 12AU7
http://www.tonepublications.com/review/primaluna-prologue-premium-stereo-power-amplifier/
https://hometheaterhifi.com/reviews/amplifier/preamplifier/primaluna-prologue-premium-stereo-tube-preamplifier166/
https://positive-feedback.com/Issue68/primaluna.htm
https://www.upscaleaudio.com/collections/primaluna/products/primaluna-prologue-premium-preamplifier
https://www.primaluna-usa.com/prologue-premium-preamplifier
https://www.stereophile.com/content/primaluna-prologue-premium-line-preamplifier
https://www.stereophile.com/content/primaluna-prologue-premium-power-amplifier
Offer Sent
Interested in the Preamp if you decide to seperate.
I sent you PM to buy. Please check your message.
Edited by leqt1969
Wow.. Bargain!
Sold pending payment & pickup
A steal. Gotta luva de Prima Luna!
Edited by twaino
Gosh what a steal at asking price!
DAMN !!!!!
But yeah I'm not too jealous cuz I have a Prima Luna ;)
Awesome combo for an Awesome price
Cheers :)
