Fikub33
SOLD: Burson HA 160D Headphone Amplifier, DAC & Preamp
Item: Burson HA 160D Headphone Amplifier, DAC & Preamp
Price: $475
Item Condition: V. Good
Reason for selling: No Longer Using (sold headphones a while back)
Payment Method: Pickup - Cash, Paypal,
Burson Audio HA-160D Headphone Amplifier
A really sweet sounding, transparent, open and powerful sounding DAC, Pre-amp and headphone amplifier.
In v.good condition. I used this to drive a set of high end Senheiser T1 headphones and it worked a treat. After I sold the headphones I primarily used the unit as a dac and preamp running straight into my power amp and its works really well in that set up as well.
Sold with original box, manual etc. so happy to ship at buyers cost.
Specifications
Input impedance: 47 KOhms
Frequency response: 5Hz (-0.3dB) to 35 kHz (-1dB)
Signal to noise ratio: >98dB at 0dB gain
THD: <0.001% at 6mW/300 Ohms
Channel separation: >70dB/10kHz
Output power: 650mW/300 Ohms, 800mW/60 Ohms
Output impedance: line out 60 Ohms, phones out 5 Ohms
Power dissipation: <25W, internal, regulated power supply
Dimensions: 265 mm x 250 mm x 80 mm
Connectors
Inputs:
1 x USB Connection (Support up to 24bit @ 96Khz with 10ppm low jitter
clock)
1 x Coaxial RCA (Support up to 24bit @ 192Khz)
3 x gold plated RCA (line level input)
Outputs
2 x headphone jacks 6.35mm
1 x pre -out with 10Db gain
Weight: app. 7 kg
Color: silver anodized aluminium
    • By wanta911
      Item: Metrum Acoustics Pavane (level 1)
      Price: $3500
      Item Condition: Excellent
      Reason for selling: Too many DACs
      Preference will be given to local sale as I prefer buyers to know exactly what they are purchasing and have the opportunity to test. If no interest locally, I will post at cost.
      I am the original owner. Bought in February 2016 from Addicted to Audio. The DAC is in excellent condition and has been a wonderful mainstay in my setup. One of the RCA outputs will turn with some light pressure but it has been like that from day one and does not affect playback. Local buyers are welcome to inspect & test, just send me a private message. I am tied up most Sundays until 2:00pm but available after that as well as Monday to Friday evenings and Saturdays.
      Please be patient if sending a message, I do not live at my computer desk.
    • By dles1972
      Item: FS: Elemental Watson Gen 2 Hybrid Tube Mosfet Headphone Amp
      Price: $150
      Item Condition: mint (besides dust)
      Reason for selling: no longer needed
      Extra Info: very nice sounding headphone amp. This replaced my Nuforce HDP headphone amp, it just walked all over it when I was A/Bing them which is no small feat if you take 6moon's opinion of the Nuforce's headphone amp being very good indeed. I have barely listened to headphones in a stationery set up in last few years so it's just not being used. Would be lucky to have put 30 hours on it. Purchased new from Jaben for $320 odd......
      Can ship......
      By trimming down on unnecessary luxuries and focusing on core performance, the Watson is able to operate in a dual mono configuration, with a military grade NOS 6AK5 tubes being the center piece of each channel™'s gain stage. Not only does this deliver rich harmonics typical of single ended class-A valve amps but also reduces warm up time of the valves significantly whilst extending the life of each valve to operate at their peak performance for more than 1000 hours per channel.
      Class A Valve/MOSFET hybrid tube desktop headphone amplifier Supports 30- 600 Ohm impedance headphones. Dual Mono Construction Delivers rich harmonics in single-ended topology. Western Electric Triodes Uses two Bell Lab/Western Electric 6AK5 valve tubes yields and produces excellent high-frequency performance. Smart Power Design Eliminates any 'Pop' sound when switching power on/off. Thus, no concern for pulse energy damage to your headphones. Compact and light-weight Easy handling size and small footprint. Portable.
    • By alexb
      Item: Little Dot Mk II Headphone Amplifier
      Price: $SOLD
      Item Condition: Mint
      Reason for selling: Selling head-fi rig
      Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
      Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
      The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
      Input: Gold-Plated Unbalanced Phono (RCA) Jacks Output: 1/4" Gold-Plated Stereo Headphone out Driver Tubes: 6JI Power Tubes: 6N6 Frequency Response: 20HZ - 50KHz (-1dB) THD+N: 0.1% (50mW into 300 ohms) Suitable Headphone Impedance: 32 - 600 ohms Pre-Amplifier Output Impedance: 10K ohms Power Output: 300mW into 300 ohms 200mW into 120 ohms 100mW into 32 ohms Average Power Usage: 28 watts Dimensions: 210mm (length) by 110mm (width) by 130mm (height) Weight: 2.5 kg or 5.5 lbs.
      The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
      Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
      So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
    • By zakblue
      Item: Emotiva XDA-1 DAC/Digital Preamp
      Price: $250
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal, Bank Transfer
      Happy to ship Australia wide at buyers expense.
    • By CAVL
      Item: JDS EL DAC, ATOM, HIFIMAN HE-4XX, AUDIOQUEST DRAGONGLY RED.
      Price: EL DAC $220 AUD, ATOM Sold, HIFIMAN HE-4XX Sold, DRAGONFLY RED Sold + Shipping.
      Item Condition: JDS EL DAC and ATOM bought on Jun 2019 with 2 years transferable warranty, they have been on my bedside table and are in very good condition, covered when not in use, HE-4XX bought on July from Drop.com has had very little use, I chose another headphones and put this ones in the box, Dragonfly red came in a bundle and box still sealed.
      Reason for selling: Downsizing.
      Payment Method: Pickup - Cash, Paypal, Bank Transfer.
      Extra Info: Equipment will be sent on original boxes once the payment is done.
