craig.g
Relist. Price Drop. DEVIALET 120
Item: Devialet  Exxpert 120
Price: 3500
Item Condition: Excellent
Reason for selling: Upgraded. No longer requried
Extra Info:  I am selling my Devialet 120 as i have upgraded to a Devialet 200. I purchased the 120 in October 2018 and used it until December 2018.
It is in excellent condition and sounds beautiful. I purchased it from Len Wallis Audio, it was a trade in and had 1 previous owner, who looked after it very well, as i have. It comes with Remote, Manual, and all original packaging and boxes and can be shipped at buyers expense. This is a very good amp at a reasonable price. Please contact me for any further info.
 Hi Martin, not as far as i know, i have never used a sub woofer so i am unsure.
  I will try and find out and get back to you.
  Craig.
The sub-out or preamp out (same thing) is an optional extra (I had it fitted to my 120).
If you scroll through the menus on the unit (using the remote) there should be something that says if it is installed or not.
I’m not home at the moment so I can’t tell you exactly which menu it is under. Will have a look later
Edited by Sir Sanders Zingmore
I'm using a REL subwoofer with my Devialet by connecting the high level output of the subwoofer to the speaker ends of the Devialet. I've read REL subwoofers are good in blending with speakers but any active subwoofer with high level (speaker level) output should be fine working with Devialet.
Another way like the previous owner said is to install the optional board which may not easy to find now. Last time I checked there is one store in US selling it for a few hundred dollars.
Yes thats one but my paradigm only have Rca inputs..
Looks like an awesome amp
    • By Josipg
      Item: Rega Aria MM / MC Phono Stage
      Price: Withdraw
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal as friend or 3% fee
      Extra Info: I purchased the unit new back in Aug 18, has had minimal use - Includes original packaging, manual and power cord.
    • By RedDogs
      Item: Thorens TD160 turntable with SME 3009 Series II Improved arm
      Price: $1320
      Item Condition: Mostly good
      Reason for selling: Not being used
      Payment Method: Pickup - Cash, Paypal (+3.0%), COD Only
      For lovers of vintage turntables, a Thorens TD160 classic turntable. A piece of audio history….
      I’ve used this 1970’s Thorens TD160 with a Ortofon 2M Black moving magnet cartridge with pleasing results.
      Below are the changes/improvements I've made to the turntable along the way -
      Installing an SME 3009 Series II Improved arm and arm board.
      Added dampening to the suspending chassis
      SME arm serviced with new rubber supports. Chassis springs and dampers removed and cleaned.
      Replaced underneath masonite plinth with thicker MDF.
      Also -
      Original SME arm also included with arm board. The original arm is still functional but the small anti-skating auto dial is broken. Anti-skating can still be manually adjusted. SME arm is far superior!
      All original internal turntable fittings with pictures included should you wish to convert to original setup. I have a complete set of pictures showing the original setup which is actually fairly simple. Happy to talk you through it.
      Please note there is damage to the rear corner of the Perspex cover. Unfortunate, but doesn’t affect sound.
      Should mention that the Thorens arm raiser post isn’t required as the SME arm has it own lift mechanism. Hence, I cover two small screw mount holes in the Thorens deck with a small level. As seen in the pics.
      There is still room for improving the turntable as I’ve never replaced the original cables or plugs and the rubber legs are still original.
      I don’t have the original box but could pack effectively if you wanted to arrange courier pickup and insurance. Insurance would be advisable.
    • By L K
      Item: GROOVETRACER® COUNTERWEIGHT – CUSTOM MADE FOR ZU/DENON DL-103 (165 GRAMS)
      Price: $229 (with free postage to metro areas within Australia)
      Item Condition: As new (excellent condition, with box and installation instructions)
      Reason for selling: No longer need (have changed cartridge)
      Payment Method: Pickup (Cash, PayPal), Delivery (PayPal)
      Extra Info:  As new, excellent condition. Well looked after. Comes with box, Allen key and installation instructions.
      New price: AU $329 (including AU $40 International postage)
      This Groovetracer® counterweight is a higher mass version of the universal model counterweight manufactured by Groovetracer for Rega tonearms. It is a custom version made for ZU Audio to balance the Zu-DL-103 model line of cartridges. Its total mass is 165 grams.
      The main body is CNC machined from 6061-T6 Aluminum and the weights are machined from non-magnetic stainless steel. The weights are damped internally and the body is decoupled from the endstub by a Delrin bushing and secured to the end stub with a No-Mar set screw.
      A precision machined stainless steel endstub is also included with the counterweight assembly to ensure a precise fit, however it is not mandatory to change the stock end stub if it provides a good fit with the Groovetracer counterweight.
      Black anodize colour.
      REVIEWS
      From Positive Feedback online review, Issue 45. Written by Ed Kobesky:
      "Music showed greater general finesse, with more micro detail throughout the spectrum. Bass tightened up significantly, and though I didn't note any additional depth, what was present was definitely more nuanced. "
      From ToneAudio online review,  Issue 3. Written by Jeff Dorgay:
      "Here’s what makes the Groovetracer products the best: attention to detail and precision tolerances."
    • By plbm2013
      Item: ipad 12.9 3rd gen 256gb wifi celullar
      Price: $1550($50 to sna if sold here)
      Item Condition:brand new sealed
      Reason for selling:unwanted Christmas fift
      Extra Info:sealed box , cash on pick up.
    • By Ericcklau
      Item: WHAM MAKE IT BIG EPIC 32 3P-574 Picture Disc Japanese Press
      Price: $35
      Item Condition: NM
      Reason for selling: no longer needed
      Extra Info:  NO Obi and Insert Japanese Press.
      Item: ERIC CLAPTON BEHIND THE SUN DUCK P-13069 Japan Press
      Price: $25
      Item Condition: NM
      Extra Info:  With Obi and Insert Japanese Press
      Item: WHAM! LAST CHRISTMAS EPIC 12 3P-575 Japanese Press
      Price: $35
      Item Condition: NM
      Item: BON JOVI NEW JERSEY MERCURY 25PP-258 Japanese press
      Price: $50
      Item Condition: NM
      Reason for selling: No longer needed
      Payment Method: Pickup or By Post - Cash, Paypal Only
      Extra Info: Japanese Pressing With OBI and Insert
      Item: Japanese Pressing KENNY LOGGINS NIGHTWATCH MASTERSOUND VINYL LP
      Price: $15
      Item Condition: NM
      Item: US Pressing MICHAEL JACKSON SCREAM EPIC
      Price: $10
      Item Condition: NM
      Extra Info: US Pressing
      Item: US Pressing JANET I GET LONELY VIRGIN
      Price: $8
      Item Condition: VG+
      Item: MICHAEL JACKSON THRILLER EPIC 25 3P-399 Japaneses Press
      Price: $35
      Item Condition: NM
      Extra Info:  with Obi and Insert Japanese Press
      Item: MADONNA LIKE A VIRGIN SIRE P-13033 Japanese Press
      Price: $20
      Item Condition: NM
      Price: $15
      Item Condition: NM
      Item: LINDA RONSTADT MAD LOVE ASYLUM P-10799Y Japan Press
      Price: $25
      Item Condition: NM
      Item: AEROSMITH GREATEST HITS CBS/SONY 20AP 3129 Japanese Press
      Price: $65
      Item Condition: NM
      Item: Japan Pressing CYNDI LAUPER MONEY CHANGES EVERYTHING PORTRAIT
      Price: $10
      Item Condition: NM
      Extra Info: Japan Pressing with OBI and Insert
