DamonsHIFI
Arcam FMJ AVR 850 High End Flagship Receiver RRP $9500
Item: Arcam FMJ AVR 850 High End Flagship Receiver
Price: pending SOLD
Item Condition: Excellent
Reason for selling: Help Fund an upgrade in Speakers.
This receiver is easily the best Receiver/Processor I have owned. Still the current model, supporting Dolby Atmos, DTX etc & via update, IMAX Enhanced.
Also utilises Dirac Live room correction.
Contact me if you would like the chance to own one of the best home theatre Receivers ever built.
Payment Method: Pickup - Cash, Paypal,
Bank transfer.
Dolby Atmos & DTS:X 7.1.4 decoding
4K (UHD) HDMI2.0a with HDCP2.2
7 HDMI inputs, 3 HDMI outputs, ARC compatible
Dirac Live for Arcam room correction
Spotify Connect enabled
Cirrus CS42528 audiophile DAC
Class G power amplification
Ethernet, RS232 and IR control
Free MusicLife iOS UPnP and control app
Technical Specifications
Continuous power output, per channel, 8Ω/4Ω (AVR850)
2 channels driven, 20Hz - 20kHz,
2 channels driven, 1kHz, 0.2% THD - 130W/210W
7 channels driven, 1kHz, 0.2% THD - 100W/180W
Residual noise & hum (A-wtd) -
Audio Performance (Stereo line inputs)
Signal/noise ratio (A-wtd, stereo direct) - 110dB
Frequency response - 20Hz—20kHz ± 0.1dB
Video Inputs
HDMI - x7 (6 x HDMI2.0a, HDCP2.2, 1 x MHL compatible)
Video Outputs
HDMI - Z1 x2 (out1 ARC, HDMI2.0a, HDCP2.2, out2 HDMI2.0a, HDCP2.2), Z2 x1 (HDMI2.0a, HDCP2.2)
Audio Inputs
HDMI - x7, Coax SPDIF - x4, Toslink - x2, RCA Phono - x6,
3.5mm aux, USB input, Ethernet Client, Internet Radio, ARC (from display)
Audio Outputs
7.1.4 Pre-amp output - 12x RCA Phono
Zone 2 output - RCA Phono
Radio Tuner
FM / DAB / DAB+ (in appropriate markets)
Supported Surround Modes Include
Dolby Atmos, Dolby Surround
DTS:X, DTS-HD Master Audio, DTS-ES 6.1 Discrete, DTS-ES 6.1 Matrix, DTS 5.1, DTS Neural:X, DTS Virtual:X, IMAX Enhanced
General
12V Trigger x2
IR in x2
6V rSeries PSU x1
Power consumption (max) - 1.5kW (approx. 5200 BTU/hour)
Power consumption (standby) -
Dimensions & Weights (AVR850)
W x D (inc. speaker terminals) x H (inc. feet) - 433 x 425 x 171mm
Weight (net) - 16.7kg
Weight (packed) - 20.0kg
IMG_2740.thumb.jpg.38571762cd643bb4d1c41e908e1ce152.jpgLRG__DSC5204.thumb.jpg.64b89a6bf2c7e1d81e4fed8216c2675a.jpgIMG_2639.thumb.jpg.1b98838da6d95e4439b4057c33b60a21.jpgIMG_2637.thumb.jpg.b8e00115ffbf13c6a2ddd420eefd41e8.jpg
Awesome receiver, very lively yet punchy and accurate. Buyer won’t be disappointed,  Damon looks after his audio gears and they are in top notch.  Glwts
I bought an Anthem AVM60 pre only a few months ago. Wish this was available then. Would have loved to have this as my preamp
    • By Josipg
      Item: Rega Aria MM / MC Phono Stage
      Price: Withdraw
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal as friend or 3% fee
      Extra Info: I purchased the unit new back in Aug 18, has had minimal use - Includes original packaging, manual and power cord.
    • By RedDogs
      Item: Thorens TD160 turntable with SME 3009 Series II Improved arm
      Price: $1320
      Item Condition: Mostly good
      Reason for selling: Not being used
      Payment Method: Pickup - Cash, Paypal (+3.0%), COD Only
      For lovers of vintage turntables, a Thorens TD160 classic turntable. A piece of audio history….
      I’ve used this 1970’s Thorens TD160 with a Ortofon 2M Black moving magnet cartridge with pleasing results.
      Below are the changes/improvements I've made to the turntable along the way -
      Installing an SME 3009 Series II Improved arm and arm board.
      Added dampening to the suspending chassis
      SME arm serviced with new rubber supports. Chassis springs and dampers removed and cleaned.
      Replaced underneath masonite plinth with thicker MDF.
      Also -
      Original SME arm also included with arm board. The original arm is still functional but the small anti-skating auto dial is broken. Anti-skating can still be manually adjusted. SME arm is far superior!
      All original internal turntable fittings with pictures included should you wish to convert to original setup. I have a complete set of pictures showing the original setup which is actually fairly simple. Happy to talk you through it.
      Please note there is damage to the rear corner of the Perspex cover. Unfortunate, but doesn’t affect sound.
      Should mention that the Thorens arm raiser post isn’t required as the SME arm has it own lift mechanism. Hence, I cover two small screw mount holes in the Thorens deck with a small level. As seen in the pics.
      There is still room for improving the turntable as I’ve never replaced the original cables or plugs and the rubber legs are still original.
      I don’t have the original box but could pack effectively if you wanted to arrange courier pickup and insurance. Insurance would be advisable.
    • By L K
      Item: GROOVETRACER® COUNTERWEIGHT – CUSTOM MADE FOR ZU/DENON DL-103 (165 GRAMS)
      Price: $229 (with free postage to metro areas within Australia)
      Item Condition: As new (excellent condition, with box and installation instructions)
      Reason for selling: No longer need (have changed cartridge)
      Payment Method: Pickup (Cash, PayPal), Delivery (PayPal)
      Extra Info:  As new, excellent condition. Well looked after. Comes with box, Allen key and installation instructions.
      New price: AU $329 (including AU $40 International postage)
      This Groovetracer® counterweight is a higher mass version of the universal model counterweight manufactured by Groovetracer for Rega tonearms. It is a custom version made for ZU Audio to balance the Zu-DL-103 model line of cartridges. Its total mass is 165 grams.
      The main body is CNC machined from 6061-T6 Aluminum and the weights are machined from non-magnetic stainless steel. The weights are damped internally and the body is decoupled from the endstub by a Delrin bushing and secured to the end stub with a No-Mar set screw.
      A precision machined stainless steel endstub is also included with the counterweight assembly to ensure a precise fit, however it is not mandatory to change the stock end stub if it provides a good fit with the Groovetracer counterweight.
      Black anodize colour.
      REVIEWS
      From Positive Feedback online review, Issue 45. Written by Ed Kobesky:
      "Music showed greater general finesse, with more micro detail throughout the spectrum. Bass tightened up significantly, and though I didn't note any additional depth, what was present was definitely more nuanced. "
      From ToneAudio online review,  Issue 3. Written by Jeff Dorgay:
      "Here’s what makes the Groovetracer products the best: attention to detail and precision tolerances."
    • By plbm2013
      Item: ipad 12.9 3rd gen 256gb wifi celullar
      Price: $1550($50 to sna if sold here)
      Item Condition:brand new sealed
      Reason for selling:unwanted Christmas fift
      Extra Info:sealed box , cash on pick up.
    • By Ericcklau
      Item: WHAM MAKE IT BIG EPIC 32 3P-574 Picture Disc Japanese Press
      Price: $35
      Item Condition: NM
      Reason for selling: no longer needed
      Extra Info:  NO Obi and Insert Japanese Press.
      Item: ERIC CLAPTON BEHIND THE SUN DUCK P-13069 Japan Press
      Price: $25
      Item Condition: NM
      Extra Info:  With Obi and Insert Japanese Press
      Item: WHAM! LAST CHRISTMAS EPIC 12 3P-575 Japanese Press
      Price: $35
      Item Condition: NM
      Item: BON JOVI NEW JERSEY MERCURY 25PP-258 Japanese press
      Price: $50
      Item Condition: NM
      Reason for selling: No longer needed
      Payment Method: Pickup or By Post - Cash, Paypal Only
      Extra Info: Japanese Pressing With OBI and Insert
      Item: Japanese Pressing KENNY LOGGINS NIGHTWATCH MASTERSOUND VINYL LP
      Price: $15
      Item Condition: NM
      Item: US Pressing MICHAEL JACKSON SCREAM EPIC
      Price: $10
      Item Condition: NM
      Extra Info: US Pressing
      Item: US Pressing JANET I GET LONELY VIRGIN
      Price: $8
      Item Condition: VG+
      Item: MICHAEL JACKSON THRILLER EPIC 25 3P-399 Japaneses Press
      Price: $35
      Item Condition: NM
      Extra Info:  with Obi and Insert Japanese Press
      Item: MADONNA LIKE A VIRGIN SIRE P-13033 Japanese Press
      Price: $20
      Item Condition: NM
      Price: $15
      Item Condition: NM
      Item: LINDA RONSTADT MAD LOVE ASYLUM P-10799Y Japan Press
      Price: $25
      Item Condition: NM
      Item: AEROSMITH GREATEST HITS CBS/SONY 20AP 3129 Japanese Press
      Price: $65
      Item Condition: NM
      Item: Japan Pressing CYNDI LAUPER MONEY CHANGES EVERYTHING PORTRAIT
      Price: $10
      Item Condition: NM
      Extra Info: Japan Pressing with OBI and Insert
