Paul Spencer
I bought a packet of assorted holes from Mitre 10 but runs out of the larger ones. I’ll get another pack tomorrow and puts some more on.
would benefit from holes in the side of the case above the board, because convective cooling would pull more air in from the side(s) to passively rise out of the case, than would fit past the "block" provided by the motherboard
along the edge as shown by the red arrows
plan b would be to macguyver a bigger 'sink over the cpu - what's holding in on ? because a touch of epoxy with arctic silver paste will be more efficient, and as it looks like you have height to spare, simply increasing the height of the fins could almost double your radiant area
so, the gold one was recovered from a very old video card, and is 1.5" square by 9/16" high (imperialist measure) - council pickup was my source, but
if you really want to go bunta, zalman made awesome and beautiful passive sinks for northbridge coolers on motherboards back in the day, but these guys are seriously tall, although the base of the beautiful pale blue fan is smaller than the gold one
cheap and easy sources (slow delivery)
https://www.aliexpress.com/item/32998838853.html
https://www.aliexpress.com/item/32950514537.html
copper is more efficient than aluminium; this seems perfect
https://www.aliexpress.com/item/4000110224085.html
but you'll need either thermal tape or an adhesive :
https://www.pccasegear.com/products/4712/sekisui-5760-thermal-tape  - a wise choice
https://www.computeronline.com.au/products.php?C_ID=1&S_ID=259&PROD=43538  - once that's used, it's there for eternity !
hope that helps
3 hours ago, mwhouston said:
I’ve posted this on the Pi Moode thread.
There's a Pi Moode thread?
Upgraded to Pi4 4GB but they run hot.
 Me too, and yes, hotter.  My whole case is a heat sink.  Helps a lot.
 Using Moode 6.4 now, very good.
Me too.  Volumio don't seem to ever fix things. Moode is very well supported.  There's a fix in 6.4.1 already, when it is released, for a problem I was having
2 hours ago, RankStranger said:
Notice any audible difference with the 4?
Too subtle to be sure.  Certainly not worse.
hope that helps
I used sticky sillipads to bond the HS.
28 minutes ago, aussievintage said:
Guys you need a case like this  https://core-electronics.com.au/argon-neo-raspberry-pi-4-case.html
The whole case is a heatsink.  My case is just warm, and the Pi runs nicely 24 hours a day in the hot QLD summer.
Argon NEO Raspberry Pi 4 Case CE06587 (Image 12)
Argon NEO Raspberry Pi 4 Case CE06587 (Image 1)
 Sexy. The only case available for my Pi+DAC combo is this abomination
Yes, I know. My eyes, too. So my plan is to build it into a project box with a cheapish dual-output 5V linear power supply like this one https://www.aliexpress.com/item/32861366138.html and maybe a wee screen to have a snazzy little home-made streamer box
@aussievintage What’s your audio output?
I just switched to a Topping D10, from a Fiio E10K.
1 minute ago, mwhouston said:
What would you like to know? :)
silicon is more an insulator than a conductor of heat
thermal tape is the win
but the guys above suggesting a metal case are on the money, especially if there is a conductive thermal bond from the case to the cpu
my little khadas tone board is in a hefty aluminium case with minimal air flow., but the case itself allows any collected internal heat to dissipate very effectively
Edited by scruffy1
2 hours ago, scruffy1 said:
a khadas tone board :)
I just keep quiet for now until someone explains what just happened :)
7 minutes ago, Muon N' said:
Better yet just use a paste specific for the job and use Arctic Silver Thermal Adhesive :)
Edit: It's conductive so be careful with application.
https://www.umart.com.au/Arctic-Silver-Thermal-Adhesive-7-Gram-Kit_21773G.html
already linked to arctic alumina in my earlier post - it's non-conductive  ;)
Guest Muon N'
Does it perform as well?
Will have to excuse me as I'm a Arctic Silver tragic from way back :lol:
Likely not of a difference to be too concerned in this application.
Acually, I would have expected it to be somewhat conductive to electricity, as well as heat. But in the Description on your link it states:
Quote
* Negligible Electrical Conductivity: Arctic Silver thermal adhesive was formulated to conduct heat, not electricity.
1 hour ago, bob_m_54 said:
Got a shock the other day while working in the backyard. I dug away some soil to find a hole there. I’ll bet the backyard is riddle with them.
i too have arctic silver on all my cpus (and gpus too, where it matters), but there's plenty of recent competitors that can top it
current top dog is allegedly thermal grizzly kryonaut (if price is unimportant, i guess)
https://www.gamingscan.com/best-thermal-paste/
i have a tube of liquid metal that i have left untouched due to oh&s concerns 😨
@aussievintage
what am I missing ?
That's a fake Topping D10. The Chinese are now copying their own products.
47 minutes ago, krakatana said:
@aussievintage
what am I missing ?
Oh I see.  However that was the result of a quick search I did.  I didn't look closely. That isn't the one I bought,  I actually bought one that has the Topping name on the top left, not Aimpire.    I hope I didn't get a fake.
Any pointers on how to identify a fake?
Guest Muon N'
Yeah, well in the computer hobby we always avoided getting it anywhere it should not be, so a better safe than sorry attitude :)
Maybe they have changed the formula since those days I was into performance computing.
  • Recently Browsing   1 member
