5 minutes ago, Red MacKay said:
I need a little help lads...
About 3 months back I saw some bare boards for Hirage 30W ClassA amps, both here and on Fakebook.
These were made by someone in NSW and the boards were distinctive as they were white.
Possibly the guy who made them had the name Roberts.
I have searched wide and far and can't relocate the link I had anywhere and I just can't find them again.
If someone can point me in the right direction here, that would be most appreciated before I spend more hours looking.
That would be me, pm me :)  I had them, and the Person that made them is Garreth Robers, him and i worked on the boards together.
Edited by itsparks
  • Replies 7.1k
Popular Posts
Stereo Subs & Two Way Monitor Build   It’s been slow going on my two way monitor with stereo sub build but I’ve finally finished finished one of the two subs!!!   The subs are 10inch CSS drive
Thanks Pete Sure! Pretty much just used common spray acrylics (cans) for the whole job. Not shy of using 2k but just trying to save on costs.  After the cabs where routed i gave th
Finally finished my 6sn7 preamp. 😀 not a bad outcome considering 50% material was recycled. Thanks a lot mwhouston for schematics.
Jeez - it's a small world!
Thankyou Mr Sparks and Tony.  I spent over two hours last night and found nothing.
Have a mate who is interested in maybe making a Hirage and is asking for options.
I already have a pair of Jim's Audio boards, but wanted to explore these too...
Thanks again.
last mod to the xover, old Mundorf cap to get back the depth of the soundstage and lower resistance inductor for tweeter
final version together with lower bass xover
  • Like 4
“La Ruse”, all finished with new PS. Regulated 12V 250HT. I added bituminised heavy Al to the base of the preamp for resonance suppression. Sounds big and bold as I posted above. So much music from small tubes.
You have heard of Altecs voice of the theatre - VOTT.
He is my version - VOTA, voice of the audiophile. Altec 511B horns (powder coated and dampened) suspended in a dampened 5 ply box. FaitalPro compression drivers. These will sit on the large sealed box with Altronics 12” poly cone - 95 db efficient and with an fs=25hZ (so low).
This combo should produce far more and deeper bass than the original VOTT at a tiny fraction the price. Xovers are complete to roll the horns in at 1100hz - 3rd order on the horns, 2nd on the woofer. System efficiency should be about 95db. Brake out your SETs. Not here a DIY 300W Holton and tube preamp to power these.
  • Like 4
Never drink and get on eBay. This arrived today. 100Wpc chip amp complete with PS on board. Just add big Tranni. The HS would struggle to handle 30W. I have much bigger ready to go.
Quoting myself. It’s part of a total system for another SNAer.
7 minutes ago, mwhouston said:
Break out your SETs. Not here a DIY 300W Holton and tube preamp to power these.
As long as the XO does cause a very unflat impedance.
dave
Not sure I agree.  A class AB amp needs less heatsinking.  I have a 200W per channel amp (6 output transistors per channel) with similar sized heatsinks (only slightly bigger, but mounted the wrong way with fins horizontal !!) and it never has a problem.
I’ll give it a go. If your wrong you owe me a HS!
  • Haha 1
Nice - are these to be your mains now or for another member?
Interested to hear the performance on the different 12” woofer. I certainly like the size of the cabinet.
At this point staying with my 20 year old Jaycar polies in 60ltr sealed box. BUT, extremely tempted. Keep my much smaller 60ltr boxes BUT drop in these extremely impressive looking Altronics polies. There is a big bonus for me. The Altronics drivers are 95db efficient mine are 92. Yes, yes I know it’s only 3db BUT when you regularly roll in DIY 2W SE UL tube amps, every db counts. For $115 X 2, I may just go and get me some. 1 hour round trip. Thursday is looking good.
Edited by mwhouston
$115 for 2 wow. Worth experimenting with. Maybe I should buy these and two plate amps and cut another hole in the baffle of my boxes.
Agree in part. Make yourself a Holton amp to drive them. Best of both worlds. But agree, cheap enough to try. I’m being pushed to do the same. Can they compete with my old Jaycar polies?
Call your Altronics store first and get them to hold a pair. Annoying to arrive and zero stock.
Cheers yeah what I’d really like to experiment with if I had the time was fabricating some bass bins. Now if I just had a cathedral, I reckon a pair of these a side would do nicely...
you may need a good size room for the bigger boxes but I’m not convinced. The horns image is extremely tight. I’ll have the whole system up and going in a day or two.
For boxes look around for local cabinet makes. Our SNA member I’m making a compete system for did. Based on what he told me I thought it good value.
Sounds good. Will watch for your impressions.
I have to get 105db Italian FaitalPro compression drivers to balance with 95db efficient poly woofers. Also room and owner issues to deal with. From calcs I have a pad worked out and can eval at home. But when it goes to another room???
Ah a bit to work out then. Lucky owner though
They are down to ~$90 at the mo and delivery is free. Just ordered two. Should be here in the week.
Hi mate,
Will get back to your pm, have been busy
Seems still $115 each up here (cheap)
Could be interested in going in with you Ash depending on results if your keen to get a little knocked off?
Edited by Bunno77
Could be keen for two mate.. would depend on
1. How big the boxes are Mark, if I’m going to lug them around for a while before building 😂
2. How will I integrate these into my current crossovers of yours Mark... ??
I only got the new owner to build them this size to fit under the horn boxes. I think 60ltr, sealed, would do.
Very good driver for a subby ‘cause it will go so low. That requires seperate amp (commercial class D would do) and electronic Xover. Done it all before and feed it from your preamp.
That little heatsink is PLENTY for a little chip amp..
True when most of use only use about 20W at good listening levels. It will be a while before it gets built I have an F5 to complete.
True about good listening levels.  However, that 200W/ch amp I mentioned was thrashed - used as the power amp in a PA system.  It got warm, but never faltered.
Should see how hot my Little Aleph mini's get with 24V rails & only 2 output devices :P lol ! DAMN  HOT!
VOTA - Voice of the Audiophile - is complete and playing woofers are tight and require about 100hours to really get going. Imaging and soundstage is crazy good. Playing Britten big orchestral classical pieces up loud. Feels super real.
  • Like 7
Edited by Hawkeye
Lost it first time
Looks great all it needs is a coat of paint Red maybe
That’s your call.
Sort of finished my "full-range" speakers today. They just need legs/stands of some sort (the ones pictured are very temporary). I’ll do a full build thread at some point soon with some detailed photos. They’re Seas FA22s in a 60ish litre cabinet. They image like crazy but aside from that they sound a bit rough. The drivers are brand new so I guess they’ll loosen up a bit. Pretty happy with how the cabinets turned out. Not perfect but pretty good for my first real woodwork in 20 years
  • Like 7
Man, really like them. I have wanted to do similar for a while. Who did your cabinets?
thanks. I did them. Started at the end of 2019 so it’s been a fair project. I’ll do a build thread soon.
I have lots of photos :)
Edited by RankStranger
I want to build the same enclosure but with this driver. When in stock I can pickup locally.
https://www.soundlabsgroup.com.au/p/V-3020-BG20/BG+20+-+8+Ohm
