S2 13BT Posted December 12, 2010 Share Posted December 12, 2010 I second that, I have owned a set ATS5 for 10 years and they do represent very good value in this price range. I've had mine 11 years and they're still going strong!! Link to comment Share on other sites More sharing options...
Z2TT Posted December 13, 2010 Author Share Posted December 13, 2010 Listened to Some KEF's in my price range, were alright but nothing better, I'll see if i can chase up some ATS. Link to comment Share on other sites More sharing options...
cheekyboy Posted December 13, 2010 Share Posted December 13, 2010 Hi Z2, did you try WAR Audio as I suggested in an earlier post? I don't know where you are, but Pat's up in the Scarborough Beach area..............anyhow, it's a bit like Adelaide really as nothing is all that far away in Perth. Cheers, Keith Link to comment Share on other sites More sharing options...
peacewise Posted December 13, 2010 Share Posted December 13, 2010 I'd be tempted to look at run out stock across a wide variety of hifi stores, often you'll get floor stock or end of life models at 50% or less of retail, yet still have full warranty. Link to comment Share on other sites More sharing options...
dusty Posted December 17, 2010 Share Posted December 17, 2010 check out ma rx6 if u can stretch ur budget Link to comment Share on other sites More sharing options...
monaro8 Posted December 17, 2010 Share Posted December 17, 2010 Z2TT, you have some very good suggestions here to consider...in the end it's up to 3 factors: 1. your budget 2. your taste in music...this is where the 'synergy' of your amp/receiver & chosen speakers and your listening room are an ideal match 3. your ears Personally, I like to look for a bargain, so I wouldn't hesitate to check out 'good quality' used speakers which when new originally cost a lot more than your $1500.00 budget. There are some very good buys out there from other hi fi lovers who may be 'upgrading' and will sell a decent set of speakers which could fit your budget. I would recommend placing a "Wanted To Buy" advert here in SNA. You will find these guys very helpful and knowledgeable too. Give details of what type of speakers you want to "match" to your system/room set up...I think you would, eventually, pick up a very nice set to suit you. Speakers will play a very important part in 'your ideal sound'...be patient...you will get something really nice. Tha't just my opinion...Good Luck Vanch... Link to comment Share on other sites More sharing options...
Nada Posted December 17, 2010 Share Posted December 17, 2010 are there any used (aka nicely run in thanks very much) Dynaudio's in your price range to listen to for a comparison? Link to comment Share on other sites More sharing options...
monaro8 Posted December 17, 2010 Share Posted December 17, 2010 are there any used (aka nicely run in thanks very much) Dynaudio's in your price range to listen to for a comparison? Yes there are them too... Good one nada. Link to comment Share on other sites More sharing options...
mikrad Posted December 19, 2010 Share Posted December 19, 2010 or you could go for a bit of a drive to Adelaide try out the Krix Phoenix weapons... very highly rated everywhere. http://www.krix.com.au/Product/Detail.aspx?p=44&id=59 $1445/pair Link to comment Share on other sites More sharing options...
TiTerror Posted January 8, 2011 Share Posted January 8, 2011 I have an 8 year old set of Aaron ATS-5's. Picked them up on ebay with matching centre and dual driver sub for $200 (plus some repair work). I have to admit Ive had the pleasure of being around good hifi for some time now ( father had b&w 802's plus plus plus) and the sound that these Aarons transmit are nothing short of extrodinary!! Coupled with quality NAD and sony amperage they with walk all over most of the Jamo stuff out there. HOWEVER! in saying this my brother just listened to the new Aaron ATS-5's and believes something has changed in the design. He believes they sound like crap, to the point he had to ask the salesman if it was a joke or something. Anything paradigm is highly recomended too. All depends on what your ears say really. Link to comment Share on other sites More sharing options...
Biggermal1 Posted August 15, 2015 Share Posted August 15, 2015 Friend of mine has a problem with his Aaron ATS-5 tweeters . Sounds ok with normal music , distorts badly with classical music . Others have done a frequency sweep , and seems ok on that . Had tweeters replaced under warranty , still bad with classical music . Anyone else come across that scenario with them . I haven't had anything to do do with it , just looking for other opinions or experiences ! Link to comment Share on other sites More sharing options...
howze Posted August 15, 2015 Share Posted August 15, 2015 Maybe damage to crossovers, is it on both speakers. But to get the best response from people maybe start a new thread Link to comment Share on other sites More sharing options...
valvesforme Posted February 14, 2019 Share Posted February 14, 2019 I just bought a pair of Jamo c407's and am finding them fantastic. Definitely no need for a sub anymore as I did with bookshelf speakers. Link to comment Share on other sites More sharing options...
Mat-with-one-t Posted February 14, 2019 Share Posted February 14, 2019 I recently bought a pair of Trevor Lees, made in Melb in maybe 1994? Focal tweeters, rear ported. Man they’re great, and they were $400! So, even if budget is $1500, doesn’t mean you have to spend it! My other setup has Osborn Epitomes, and I got them second hand off Gumtree for a steal. There are often speaker bargains out there, especially for floorstanders (where people are downsizing and so on)..... Link to comment Share on other sites More sharing options...
