steverb Posted September 24, 2008 Share Posted September 24, 2008 Hi there. Whats the best connector to use from my HTPC to a 1080p TV?? to get the best quality signal throughput my options are svga to svga (dsub??) dvi to hdmi dvi to component component to component (via the little vivo type connector) Link to comment Share on other sites More sharing options...
tkr001 Posted September 24, 2008 Share Posted September 24, 2008 DVI to HDMI IME Link to comment Share on other sites More sharing options...
skamp Posted September 24, 2008 Share Posted September 24, 2008 Second that, definitely go DVI -> HDMI. Link to comment Share on other sites More sharing options...
dts6.1 Posted September 24, 2008 Share Posted September 24, 2008 yep me too, DVI to HDMI... as long as there are no HDCP issues of course!! Link to comment Share on other sites More sharing options...
Griffy Posted September 25, 2008 Share Posted September 25, 2008 I'm using DVI-HDMI cable, looks perfect. Link to comment Share on other sites More sharing options...
jcooze Posted September 25, 2008 Share Posted September 25, 2008 Experiment. Shouldn't be too hard to get two short runs of either cable and try them out. Most people* coudn't discern any difference betwixt a VGA run from my Laptop to my PJ and a DVI-HDMI run. The HDMI cable was a Panasonic 7m cable that came with my PJ. THe VGA was a shielded 10m run, the DVI to HDMI connector was Pudney brand. The laptop is an old Compaq, PJ is the Panny AE900 * (including me) Link to comment Share on other sites More sharing options...
Nigel Beale Posted September 25, 2008 Share Posted September 25, 2008 You won't see much difference if your display isnt correct, or as accurate as it can be. The AE900E requires a reasonble amount of tweaking of WB, I have one myself and it is quite a bit out in any of the standard choices. THis can be one of the fundimental issues with diserning any difference with even cables. Each issue adds to any inaccuracy. Same problem with sound aswell. Link to comment Share on other sites More sharing options...
