Dogman1553552716 Posted September 14, 2008 Share Posted September 14, 2008 Any thoughts/pitfalls etc on this turntable? http://www.trademe.co.nz/Browse/Listing.aspx?id=175730396 Link to comment Share on other sites More sharing options...
Ernie1553552694 Posted September 14, 2008 Share Posted September 14, 2008 The Grado Signature cartridge is $999 new. Worth bidding for that alone... Link to comment Share on other sites More sharing options...
Dogman1553552716 Posted September 14, 2008 Author Share Posted September 14, 2008 $999 new? Bloody hell, those new stylii are going to cost a fortune then!!!! Calling turntable guru Michael W...are you out there...any ideas? Link to comment Share on other sites More sharing options...
Ernie1553552694 Posted September 14, 2008 Share Posted September 14, 2008 Dogman;72592 wrote: $999 new? Bloody hell, those new stylii are going to cost a fortune then!!!! Calling turntable guru Michael W...are you out there...any ideas? It would need to be factory retipped. Not uncommon for higher-end cartridges of a lot of other brands as well... Link to comment Share on other sites More sharing options...
Dogman1553552716 Posted September 14, 2008 Author Share Posted September 14, 2008 I thought it was a MM cart, so could just replace the stylus...or is it a MC cart? No, seems like its a moving "IRON" cart...whatever that is....confused.... Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2008 Share Posted September 14, 2008 Dogman;72592 wrote: $999 new? Bloody hell, those new stylii are going to cost a fortune then!!!! Calling turntable guru Michael W...are you out there...any ideas? Bit hard to tell from the grotty picture but that appears to be a really old Grado Signature, seller says it was $600 new. Brand new would probably set you back $1k or so... Dogman;72594 wrote: I thought it was a MM cart, so could just replace the stylus...or is it a MC cart? No, seems like its a moving "IRON" cart...whatever that is....confused.... Those early Signatures did have user replaceable stylii that was cemented in place with a black putty-like substance. New Signatures in the wooden body are not user replaceable. I haven't played with a PT TOO but did try an older PT back in the mid-80s. First up, the name of this table is thoroughly reprehensible. :mad: If you want to know why, look up World War 2 history. The table itself was pretty good, back then a breath of fresh air compared to the ubiquitous Linn Sondek LP12. High tech materials. Aluminium sub-chassis, acrylic platter. + Old school design. Belt-drive, 3-point suspension, lightweight sub-chassis. + Bodgy implementation. Easy external spring adjustment but no height adjustment for support feet, no platter clamp, poor speed stability, mediocre suspension. = Sonic curate's egg. Clean and reasonably neutral, noticeable HF rise, thinning midrange, lightweight bass. Fairly good soundstaging but lacking depth and dimensionality. Not as toe-tapping as a Linn of similar vintage. If the TM one is a PT TOO it should be a lot better than the earlier models. A Rega arm is a better match than heavier arms. Could be worth pursuing if the price doesn't go crazy (eg. stays below $1k)... Link to comment Share on other sites More sharing options...
Dogman1553552716 Posted September 15, 2008 Author Share Posted September 15, 2008 Thanks for the info Michael. As usual a veritable fount of information!!! Cheers Link to comment Share on other sites More sharing options...
