Rtd999
SOLD: FS: Primaluna Dialogue Premium Integrated
Item: Primaluna Dialogue Premium Integrated Amplifier with over $1k of extra tubes
Price: 3200
Item Condition: Excellent
Reason for selling: Change of direction
Extra Info: 1st owner of this lovely amplifier that works flawlessly.  Just over a year old. Includes the following tubes for you to find the sound you like (I've mostly been using the KT120's with nos Mullards -
Matched quad Gold Lion KT77
Matched quad Gold Lion KT88
Matched quad Tung-Sol KT120
6 x Primaluna 12AU7
4 x nos Brimar CV4003
2 x nos 1960's Blackburn Mullard ECC82
2 x nos 1964 RCA Cleartop 12AU7
2 x PSVANE 12AU7 -TII
Remote control & gloves for tube handling also included as well as a few spare fuses.  I have the original box, but would prefer pickup due to weight.  Can send at buyers risk using Pack & Send.  Last package I sent around this weight was just over $200 with insurance etc.  Cheers
Wow... That's LOTS of extra tubes! Love my prologue integrated... GLWTS!
    • By aris
      Item: Yamaha A-S1000 Integrated Amplifier (Black)
      Location: Melbourne (Local pickup only, I don't have the box).
      Price: $700 (was $850).
      Item Condition: Good
      Reason for selling: Clearing out the 2nd system
      Specifications are available on Yamaha's site - https://au.yamaha.com/en/products/audio_visual/hifi/a-s1000/index.html
      At 105W in to 8Ohm (220W into 2Ohm) this has no trouble driving Harbeths and PMC's.
      Note, I'm not the first owner (I purchased through a local (Melb) seller on SNA about 12-18 months ago).
      I'm currently running Harbeth Compact 7ES-3 with this amplifier, and it really is a great match.
      The amplifier has MM and MC phono stage, currently using a Rega Planar 3 (MM) very nicely.
      I don't have the original remote, but use a universal Logitec to good effect, which I'll include in the bundle if the buyer wants it (nothing fancy, does the job - volume, input selection etc).
      There is one minor dint along the top faceplate (see 1st photo, above the Balance knob).
      One of the great features is the Direct Input, which allows you to run a pre-amp into it (I'm using a RME DAC to good effect).
    • By synthz
      Item: Primaluna Dialogue Premium Pre-amplifier
      Price: $2,550 (RRP $4,195)
      Item Condition: Great
      Reason for selling: NLR
      It's pretty hard for me to let this go, but rather than being unused it's probably better to have a new home. My power amp is using XLR/Balanced only connection so I had to use my other preamp. All tubes are standard stock primaluna tubes. It's going to be hard for you to get this quality gear at this price, it's almost half price from the RRP of $4,195.  I'm the 2nd owner. Still have the original box.
      The PrimaLuna brand has been making waves in the High end Audio industry for producing premium built products that perform to a standard well beyond their peers at the same price point. The PrimaLuna Dialogue Premium Pre-Amp is a wonderfully detailed and warm sound with plenty of treble extension and air. The soundstage that this tube pre-amp presents is huge! This is an excellent valve pre-amp that is super quiet/low noise, a nice dash of the famous tube warmth all with fabulous frequency extension both in lowest bass power and highest, airiest treble. Featuring dual pre-outs, Home Theatre bypass functionality and an awesome sound here is your chance to save a bundle.
      Website:
      http://www.primaluna-usa.com/dialogue-premium-preamplifier
    • By DubbyMcDubs
      Item: Cayin CS-88A Integrated Valve Amplifier
      Price: $2,750 ono
      Item Condition: Mint, As New
      Reason for selling: Upgrading/Change of direction
      Payment Method: Pickup - Cash, EFT, Paypal + 2.6%, COD Only
      I have owned this amp since July this year. Originally purchased in preparation for a setup with Klipsch Cornwall III speakers, however I went a different route and ultimately purchased Revel M106’s. While this is an exceptional sounding valve amplifier it is not really matched well with the Revel’s and I will be upgrading to a Benchmark system. The build quality is exceptional, regardless of price. Selling to help fund the upgrade.
      This amp is in mint as-new condition, with no more that 5 hours use on it total. I have all of the original packaging and accessories. 19 months warranty remaining.
      Retails for $3,499. Selling $2,750 ono
      Happy to post if buyer pays postage, but realize its a very heavy item.
      Specifications
      Power Output: 25 Watts per channel (Triode) 45 Watts per channel (Ultra-Linear) Frequency Response: 10Hz - 42kHz (-3dB) Total Harmonic Distortion (THD): 1% (1kHz) Signal to Noise (S/N) Ratio: 93dB Line-Level Inputs: Two Phono Input (MM) Pre-Amp Input: One stereo preamp input – allows the CS-88A to be used as a power amp only Construction: Hand-made construction with silver point-to-point wiring Power Supply: Specially designed toroid transformer for the power supply Pre-Amplifier: Two 6SL7 and two 6SN7 valves are used in the preamp stage Four KT88 valves are used in Class AB1 push-pull output stage Triode and Ultra-linear selection via remote Bias Adjustment: Easy valve bias adjustment using the top mounted bias meter Rear Panel Switch: Switch easily between the supplied KT88 output valves or optional EL34 valves via a convenient rear panel switch Remote Control Soft Start Function: 30 second soft start function - extends the life of internal components and valves Memory: CS-88A stores last usage settings once turned off Volume Control: High-quality Japanese ALPS motorised potentiometer (volume control) Silver Plating: Heavily silver-plated signal cables are used throughout Cover: An easily removed cover is provided for protection from hot valves Speaker Binding Posts: Accepts Banana plugs or spade terminals Output Impedance: 4 Ohms and 8 Ohms Power Cord: Standard IEC that can be easily upgraded. Dimension (WxHxD): 420 × 195 x 382 mm Net Weight: 28kg
    • By DubbyMcDubs
      Price: $2,800
      Retails for $3,499. Selling $2,800
      Specifications
    • By mrf0ster
      Item: PrimaLuna EVO 400 Tube Integrated Amplifier (EL34) Black
      Price: $5000.00  ONO (RRP: $6995.00)
      Item Condition: MINT (UNMARKED with ALL ORIGINAL PACKAGING)
      Reason for selling: Change in personal circumstances
      It is with the utmost regret and disappointment that I am selling this tube amp. Due to a change in personal circumstances I can no longer enjoy the sweet sweet sounds. (This amp is only 5 months old.)
      I am open to any reasonable offer.
      Thank you.
      Product Description:
      https://www.primaluna-usa.com/primaluna-evo-400-tube-integrated
